USB CDC with 24f
cagabit
USB CDC with 24f
PostPosted: Thu Jan 08, 2015 10:52 pm     Reply with quote
Trying to implement USB CDC with 24FJ128GB206, compiler 5.015
Having 20Mhz crystal set the fuses :
#fuses NOWINDIS,NOWDT,ICSP3,NOWRT,NOPROTECT,NOJTAG
#fuses NOIESO,NOWPFP,NOWPDIS,NOWPCFG,NOPR,NOIOL1WAY,NOOSCIO,NOCKSNOFSM
#use delay(clock=32M,USB_FULL)
#fuses HS, PR_PLL, PLL5,PLL96MHZ
But nothing happens in the device manager, on the PC !?
Suspected with the HS fuse but best choice is that i think ?
Dont think any problem with the hardware, used the same circuit to connect USB HID but with XC16 compiler, without any problem.
Any guidance will be my light Shocked Very Happy
PostPosted: Fri Jan 09, 2015 2:16 am     Reply with quote
Your fuses should complete _before_ your delay statement. As it stands, the compiler may have chosen a different pattern to give the oscillator you want, and you then override this....
Do a search here. There was a thread perhaps two months ago, with the poster having problems getting USB to work on one of the PIC24 'OTG' chips.
It's here:
<http://www.ccsinfo.com/forum/viewtopic.php?t=52758&highlight=usb+otg>
I'm not sure if he ever resolved this?.
cagabit
PostPosted: Fri Jan 09, 2015 4:34 am     Reply with quote
Your answer is great Ttelmah, thank you.
For future reference:
First, I missed the init sub of USB i think, I was trying to init with the code,
usb_cdc_init();
which was the only acceptable solution for me when trying CDC with the PIC18F2550. But from the post you linked it should be,
usb_init_cs();
And IT IS OK NOW ! Windows shows the COMx port without problem.
Also before this corrected the order or the FUSES and the DELAY line like,
#FUSES CKSFSM
PostPosted: Fri Jan 09, 2015 10:17 am     Reply with quote
Good.
Shows the power of some of the records here on the forum. Smile
Have fun.
