Measuring pulse width using CCP
Goto page Previous  1, 2, 3
Aragon
PostPosted: Fri Oct 24, 2014 9:40 am     Reply with quote
thanks, I will check out the header file.
Aragon
PostPosted: Fri Oct 24, 2014 1:05 pm     Reply with quote
I had a look at the header file and I made a small change to the code. But it still doesn't work. in the header file they mention
//#define CCP_USE_TIMER3 0x100 OBSOLETE, SEE TIMER-3
// OR in one of the following to use timer 3 with a CCP unit
#define T3_CCP2 0x8
in the void main program
setup_ccp2(CCP_CAPTURE_RE | T3_CCP2);
setup_timer_3(T3_INTERNAL | T3_DIV_BY_8);
I thought this would have setup timer3 and ccp2 correctly but no luck.
PostPosted: Fri Oct 24, 2014 2:15 pm     Reply with quote
It's in the setup_timer_3() section. It says to OR it in with parameters
for that function, not with setup_ccp2().
It says:
// Constants used for SETUP_TIMER_3() are:
Aragon
PostPosted: Mon Oct 27, 2014 7:52 am     Reply with quote
Thanks PCM Programmer,
I took a look at the header file and I realised the answer was right infront of me. I got the Timer3 to finally work. Had to edit the header file to
#define T3_INTERNAL 0x8D
PostPosted: Mon Oct 27, 2014 8:10 am     Reply with quote
Had to edit the header file to Quote:
I don't understand your thought processes. All you have to do is follow
the instructions in the 18F2620.h file. It says to OR the constants
together. You don't edit the file. You just do this:
setup_timer_3(T3_INTERNAL | T3_CCP2);
Oh..., I just figured it out. You took the instructions literally.
Don't do that. Let the compiler do the work, as shown above.
That's how CCS wants you to do it.
Aragon
PostPosted: Mon Oct 27, 2014 9:18 am     Reply with quote
Thanks,
I changed the header file back to the original. I used
setup_timer_3(T3_INTERNAL | T3_DIV_BY_8 | T3_CCP2 );
Timer 3 works good.
PostPosted: Mon Oct 27, 2014 9:47 am     Reply with quote
This is one of those 'so obvious', but then you realise it isn't, things. Smile
The line in the header saying to 'or' together, is implicitly understood by everyone, who has at some point learnt to use the C 'or' instruction, or seen it used in the examples, but isn't immediately clear unless this is the case.
It's a bit like the old 'training' example, of the foreman coming on site, to find a man driving screws with a hammer. So he says "you don't do that, you use a screwdriver". Returning a while later, he finds the man hammering the screws in with the screwdriver.....
To anyone who knows how to use a screwdriver, it seems 'daft', but when you think about it, if you have never used a screwdriver, the extra explanation of how to use a screwdriver, was essential!.....
PostPosted: Mon Oct 27, 2014 10:39 am     Reply with quote
gee, and I thought screwdrivers were only for removing screws!
Jay
Aragon
PostPosted: Thu Mar 05, 2015 12:52 pm     Reply with quote
I Apologise again for REVAMPING this post for the 3rd time. This has been a side project that I don't get to spend alot of time on. I have completed the hardware part and also completed the software. I have been trying to fix a bug for over one week and I thought it was time to ask for help. The code is below. The part i am stuck at is it appears the "Pulse Measurement" is not working. I tried different loops for that part of the program. I used mplab sim and was watching the ports as the program was executing. In the simulator i noticed that the measuring of the pulse was not working. Can someone please guide to the right direction.
#include <18F2620.h>
#fuses INTRC, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP,
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
SETUP_ADC_PORTS( ALL_DIGITAL );
int8 capture_rising_edge1;
int8 capture_rising_edge2;
int8 got_pulse_width1;
int8 got_pulse_width2;
int16 ccp_delta1;
int16 ccp_delta2;
#define MS_2 250
#define MS_3 375
#int_ccp1                     //Interrupt Name
  void isr_ccp1()               //Interrupt Function
static int16 t1_rising_edge;
//If current interrupt is for rising edge.
if(capture_rising_edge1)
   setup_ccp1(CCP_CAPTURE_FE);
   capture_rising_edge1 = FALSE;
   t1_rising_edge = CCP_1;
   setup_ccp1(CCP_CAPTURE_RE);
   capture_rising_edge1 = TRUE;
   ccp_delta1 = CCP_1 - t1_rising_edge;
   got_pulse_width1 = true;
#int_ccp2
   void isr_ccp2()
static int16 t3_rising_edge;
if(capture_rising_edge2)
   setup_ccp2(CCP_CAPTURE_FE);
   capture_rising_edge2 = FALSE;
   t3_rising_edge = CCP_2;
   setup_ccp2(CCP_CAPTURE_RE);
   capture_rising_edge2 = TRUE;
   ccp_delta2 = CCP_2 - t3_rising_edge;
   got_pulse_width2 = true;
void main()   ///
int16 local_ccp_delta1;
int16 local_ccp_delta2;
int16 pulse_width_ms1;
int16 pulse_width_ms2;
got_pulse_width1 = FALSE;
got_pulse_width2 = FALSE;
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
enable_interrupts(INT_CCP1);
setup_timer_3(T3_INTERNAL | T3_DIV_BY_8 | T3_CCP2);
enable_interrupts(INT_CCP2);
output_low(PIN_B0);               //set RB0 to LOW
output_low(PIN_B2);               //set RB2 to LOW
output_low(PIN_B3);               //set RB3 to LOW
output_high(PIN_B1);            //set RB1 to HIGH
output_high(PIN_B4);            //set RB4 to HIGH
output_low(PIN_C3);               //set RC3 to Low
output_low(PIN_C4);               //set RC4 to Low
input(PIN_A2);                  //set RA2 as INPUT
input(PIN_A3);                  //set RA3 as INPUT
input(PIN_C1);                  //set RC1 as INPUT
input(PIN_C2);                  //set RC2 as INPUT
if (input (PIN_A2) == 1) {                //Check, is RA2 high?
   output_high(PIN_B0);            //set output RB0 to HIGH
if (input (PIN_A3) != 0)
      output_high(PIN_B2);
   output_high(PIN_B3);
   output_low(PIN_B4);
do {
   if(got_pulse_width1)
   disable_interrupts(GLOBAL);
   local_ccp_delta1 = ccp_delta1;
   pulse_width_ms1 = local_ccp_delta1/125;
    //printf("%lu ms \n\r", pulse_width_ms);
if(local_ccp_delta1>MS_2 && local_ccp_delta1<MS_3)
   output_high(PIN_C3);
   output_low(PIN_C3);
while (local_ccp_delta1>MS_2 && local_ccp_delta1<MS_3);
do {
   if (PIN_C3 != 1)
   output_low(PIN_B0);
   output_low(PIN_B0);
while (true);
output_low(PIN_B0);
if (input (PIN_A3) != 1)
do
   if(got_pulse_width2)
   local_ccp_delta2 = ccp_delta2;
   pulse_width_ms2 = local_ccp_delta2/125;
//   printf("%lu ms \n\r", pulse_width_ms2);
if (local_ccp_delta2>MS_2 && local_ccp_delta2<MS_3)
   output_high(PIN_C4);
    output_low(PIN_C4);
while (local_ccp_delta2>MS_2 && local_ccp_delta2<MS_3);
do {
    if (PIN_C4 != 1)
   output_LOW(PIN_B4);
   output_low(PIN_B4);
while (true);
do
  if (PIN_C3 != 1)
        output_low(PIN_B0);
      output_low(PIN_B1);
   if(input (PIN_A3) != 0)
        output_low(PIN_B0);
      output_low(PIN_B1);
while(true);
PostPosted: Thu Mar 05, 2015 1:15 pm     Reply with quote
Before we look at your code, describe the pulse. Post the voltage levels,
rise time, shape, positive or negative-going, pulse duration, and repetition rate.
Also describe the connections between your pulse generator and the PIC.
Post the Vdd voltage of your PIC.
And post your CCS compiler version.
Aragon
PostPosted: Thu Mar 05, 2015 3:56 pm     Reply with quote
-The Pulse is a square wave (High = 2.643mS & Low = 7.033mS). duration = 9.676ms
-its a positive raising edge, I am getting a 5VD going in the CCp1 and CCP2, Instead of the pulse signal. The signal generator is controlled by the RB0 pin on the PIC18 to output the signal. The signal is there for the first 3 seconds and then turns off. RB0 is 0.5vdc instead of being 5 vdc.
-The pulse generator is on the same circuit board as PIC18F2620. The Pulse generator is PIC12F675. The output pulse from the PIC12 goes to CCP1 on the PIC18.
-the VDD voltage of the PIC is 4.91V
-The CCS Compiler is V8.70
PostPosted: Thu Mar 05, 2015 6:16 pm     Reply with quote
Your program doesn't work because you took a bunch of code from
various programs and dumped it all into one program without thinking
about how the CCP works in capture mode. I've written a program
that shows how to do it. I hope you can understand it.
Using a test setup similar to yours, with a 2nd PIC board providing the
test signal, I get the following output on TeraTerm from the CCP capture
board. The pulse duration is a little low, probably because the internal
oscillator is used on the capture board, and it's not precisely 4.000 MHz.
2.633 ms
2.633 ms
2.633 ms
2.632 ms
2.632 ms
2.632 ms
2.633 ms
2.633 ms
2.632 ms
Test program:
#include <18F4520.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
int8 capture_rising_edge;
int8 got_pulse_width;
int16  ccp_delta;
#int_ccp1
void ccp1_isr(void)
// If current interrupt is for rising edge.
if(capture_rising_edge)
   capture_rising_edge = FALSE;
   capture_rising_edge = TRUE;
   ccp_delta = CCP_1 - t1_rising_edge;
   got_pulse_width = TRUE;
float pulse_width_ms;
int16 local_ccp_delta;
got_pulse_width = FALSE;
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
set_timer1(0);
clear_interrupt(INT_CCP1);
   // Check if we captured the pulse width.
   // If so, display the pulse duration.
   if(got_pulse_width)
      local_ccp_delta = ccp_delta;
      pulse_width_ms = local_ccp_delta / 1000.0;
      printf("%7.3f ms \n\r", pulse_width_ms);
   delay_ms(500);  // Slow down update rate on TeraTerm
Notice how short this program is, compared to your program. More code
does not equal success. A short program that is completely understood,
equals success.
Page 3 of 3
