#fuses
rusty_shackleford
#fuses
PostPosted: Tue Sep 16, 2014 3:08 pm     Reply with quote
I wonder if there is a list of the #fuse abbreviations for each device and what they mean. a cheat sheet of some kind.
stinky
PostPosted: Tue Sep 16, 2014 3:22 pm     Reply with quote
They correlate pretty closely to the Configuration Word(s) in your device's datasheet. That combined with the device header file have been the magic cheat sheet for me.
PostPosted: Tue Sep 16, 2014 3:57 pm     Reply with quote
Do you have the CCS IDE compiler (PCW, PCWH, PCWHD, etc.) ?
If so, look for fuses.txt in the CCS directory.
If you don't have it, do a web search for this:
datadynamics fuses.txt
A company that sells the compiler in Japan has posted it.
jeremiah
PostPosted: Tue Sep 16, 2014 6:03 pm     Reply with quote
It's also worth noting that if you have the IDE, there is an option to display all the fuses for your particular chip with a description of what they are for.
It's View Configuration Bits in the most recent IDE version.
