overmindx
| icd-u64 rev 3 firmware |
Posted: Tue May 06, 2014 9:19 pm |
I have created a bootloader which is based on ex_bootloader. Everything is working great. I am able to use my bootloader to download firmware codes to my chips.
Recently, we purchased a couple of rev 3 icd-u64 which has a firmware version of 2.96. Now when i used this to put my bootloader to the chip. I was still able to use it to download the firmware code using the bootloader however, the interrupts are not working anymore.
Moreover, when I upgrade my rev.2 icd-u64 to firmware 2.96, it suffers the same fate. So i have to downgrade it again to 2.91. I tried to downgrade my rev3 icd's but it cant detect the lower firmware versions.
My question is has anyone successfully tried to use the ex_bootloader and used the interrupts on the firmware code using rev3 icd's? if so, can you share it with me?
bryan |
