Controller increases its temperature
stoyanoff
PostPosted: Sat Apr 19, 2014 6:05 am     Reply with quote
Greetings! I have one dsPIC30F5015 soldered to a board. It works fine, but for few minutes the corpus temperature reaches 40 degree C. I'm stopping it every time when it becomes so hot. This is happening even when the controller does nothing...
Where could be the problem?!
Thanks!
dyeatman
PostPosted: Sat Apr 19, 2014 8:22 am     Reply with quote
Have you tied any I/O lines to Vcc or Vss? Without more info it's a wild guess.
Google and Forum Search are some of your best tools!!!!
PostPosted: Sat Apr 19, 2014 8:41 am     Reply with quote
bad trace underneath the PIC acting as a heater ?
bad PIC ?
shorted pins ?
hth
jay
stoyanoff
PostPosted: Sat Apr 19, 2014 9:01 am     Reply with quote
What info do you need?!
I can't find any shorted traces. Vcc and GRD are connected correctly.
I've noticed something - when I stop the PPL there is no heat! My standard program is using HS2_PLL16 and 10MHz quartz = 80MHz oscillator. When I change this to HS - everything is OK.
Any suggestions?!
PostPosted: Sat Apr 19, 2014 10:04 am     Reply with quote
bad power supply ? IE: large AC ripple on Vdd ??
'scope will see this....
drawing at straws though....
This PCB..is it a new design, if so, wire up another see what happens ??
hth
jay
stoyanoff
PostPosted: Sat Apr 19, 2014 10:06 am     Reply with quote
It`s new design, but I ordered only 1. My power supply is done by book. I`m using lm2575 with the appropriate peripheral..
gpsmikey
PostPosted: Sat Apr 19, 2014 10:28 am     Reply with quote
Floating digital inputs? (like in the linear range??)
mikey
mikey
stoyanoff
PostPosted: Sat Apr 19, 2014 11:06 am     Reply with quote
It's not from the power supply. I powered the pcb through PicKit 3 - it's the same.
What is the connection between the oscillator setting and the inputs (floating digital inputs)?! I don't have floating inputs. Every input in usage is connected to 4.7k pull-up resistor or to optocoupler`s LED ...
PostPosted: Sat Apr 19, 2014 5:20 pm     Reply with quote
This is really a question for the Microchip forum. In fact they have already
discussed it in these threads:
Regarding dsPIC30F6015 IC Heating Problem -
https://www.microchip.com/forums/tm.aspx?m=530353
Overheating while running in XT w/PLL 16,XT w/PLL 8 mode -
http://www.microchip.com/forums/m196508.aspx
dsPIC30F1010 overheating issues -
http://www.microchip.com/forums/m380158.aspx
Question about 30F5015 -
http://www.microchip.com.edgekey.net/forums/m711847.aspx
