float and int with PIC18F4550
neo19
PostPosted: Thu Apr 17, 2014 8:48 am     Reply with quote
I'm using PCW VER4.134 with PIC18F4550.
My problem is the following: from a CAN I get 2 value:
VHCAN (Most significant data byte) and VLCAN (Least significant data byte).
I would like to convert VHCAN and VLCAN to get my voltage value through USB.
So for example: input voltage in the CAN = 24.6V
This code is working very well, I can read 24.6V through USB COM
byte    VHCAN=0,VLCAN=0;
VHCAN=192;  //to simulate the CAN
VLCAN=48;
printf(usb_cdc_putc,"%2.1fV",((float)VHCAN*16+((float)VLCAN/16))/4095*4.096*8);     // 12bits=>4095    Vref=4.096V 2.75V=>2749 divisor by 8
But as I have 8 channel of CAN, I would like to put the value inside a table:
This is not working:
float    M_V[8];
VLCAN=48;
M_V[0]=((float)VHCAN*16+(float)VLCAN/16)/4095*4.096*8;
printf(usb_cdc_putc,"%2.1fV",M_V[0]);     // 12bits=>4095    Vref=4.096V 2.75V=>2749
I can read 2.0V through USB COM. I think I have a trouble of cast.
I tried lots of think without result...
Could someone help me?
Thanks a lot
Fabrice
PostPosted: Thu Apr 17, 2014 10:23 am     Reply with quote
I made a test program for your routine, I installed vs. 4.134, and I ran
the program in MPLAB simulator. I used the UART1 feature of MPLAB for
output (not USB CDC). So this method tests your code. It works.
I got this output:
24.6V
Test program
#include <18F4550.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
#use delay(clock=20M)
// Dummy routine to send output to MPLAB
// output window, instead of to USB CDC.
int8 usb_cdc_putc(int8 data)
putc(data);
byte VHCAN=0, VLCAN=0;
float M_V[8];
VLCAN=48;
printf("\r");
neo19
PostPosted: Fri Apr 18, 2014 1:45 am     Reply with quote
Dear PCM programmer,
I've tested your code and it's working. Shocked
I'm very disturbed because inside my whole software it's not working.
I'm going to integrate this code in my global program and I will tell you if it's ok or not.
Thanks,
Fabrice
neo19
PostPosted: Fri Apr 18, 2014 3:39 am     Reply with quote
So I tested again in my whole software.
I realized that I had another subroutine which generated trouble on my M_V[].
Terrible!!
Thanks again for your help.
