pic 18f6722
amit
pic 18f6722
PostPosted: Sun Mar 09, 2014 7:45 am     Reply with quote
i am using the pic18f6722 for the first time. I tried a simple LED toggle program using CCS, but it wont work.
i tried putting some value on one of its port, which works fine.
so i concluded that the delay_ms() function is not working in it. i tried internal oscillator, external oscillator of 4MHZ, but nothing seems to make the delay function work.
if someone would have simple code blinking a led with delay_ms(), working on internal oscillator or external oscillator 4MHz, it would be very helpful.
thankyou in advance.
PostPosted: Sun Mar 09, 2014 7:48 am     Reply with quote
Please show us your program so we can debug it.Select the 'code' button in the line that says 'message body', before and after you 'cut and paste' your program. Also tell us which version of the compiler you have.
Also, please delete the 2nd thread that you have. I suspect you might have pressed the 'submit' button twice(easy to do !).
hth
jay
amit
PostPosted: Sun Mar 09, 2014 8:00 am     Reply with quote
this is the file i used for testing
#include "main.h"
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
   // TODO: USER CODE!!
      output_bit( PIN_D0, 0);
      output_bit( PIN_D0, 1);
this is main.h file which i have included
#include <18F6722.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC                    //Internal RC Osc
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES XINST                    //Extended set extension and Indexed Addressing mode enabled
#FUSES BBSIZ1K                  //1K words Boot Block size
#use delay(clock=8000000)
amit
PostPosted: Sun Mar 09, 2014 8:08 am     Reply with quote
i have version 4.038.
the LED does not glows at all with code that i have posted above.
If i swap position of output bit as shown below, the LED glows and does not gets OFF.
PostPosted: Sun Mar 09, 2014 8:33 am     Reply with quote
possible problem ....
99.9999% of PIC programmers do NOT use LVP, so change to NOLVP.
also
I always set to PUT, as it allows the PIC a little bit of time to get organized internally.
I didn't see anything else that's 'obvious' wrong...though I don't know why the 'code' button didn't work either!
hth
jay
Reason: User amit disabled BBcode in his profile.
Fixed.
- Forum Moderator
PostPosted: Sun Mar 09, 2014 2:58 pm     Reply with quote
These are both wrong.
Need to be 'setup_spi(FALSE);' etc..
These will prevent the pins for both SPI1, and SPI2 from being used for normal I/O. Haven't checked what pins they are on this chip, but won't help...
PostPosted: Sun Mar 09, 2014 3:34 pm     Reply with quote
And this is wrong. It will enable the extended instruction set which is
not supported. Your program will do crazy things. Change it to NOXINST.
amit
PostPosted: Tue Mar 11, 2014 7:07 am     Reply with quote
PCM Programmer,
Your suggestion worked i used NOXINST and it worked instantly, thankyou.
