modchip
stuck in programming |
Posted: Fri Jan 10, 2014 9:29 am |
hello everybody help please
i have to make a command in 15 valves
I'm using pic 18f452 at 20mhz
the fact is the way of opening this valves (i mean in programing not practice )
the problem is
each valve have a variable opening time from 0 to 9 like this
0= 0.00s
1=0.10s
2=0.14s
3=0.20s
4=0.28s
5=0.39s
6=0.54s
7=0.76s
8=1.10s
9=1.50s
s mean second this is the time that the valve must be keep open
other thing that all the valve have another parameter which is
how many opening time in one minute
this parameter can be between 00 and 64
Example for one valve that have the parameter :
3 = 0.20s and have 15 times opened in minute
so it will be have a square wave that have 15 on 1 logic and 15 off 0 logic
this square wave for the "1" logic 0.20s and the "0" logic is 3.8s
i have this equation (60/opening times ) - the opening time
so i m stuck how to program this by generate all 15 valves with each one have a particular opening time
excuse me for my bad english
please help _________________ hi forr all |
Mike Walne
Posted: Fri Jan 10, 2014 12:37 pm |
Create a 10ms tick with one of the hardware timers.
Set up an ISR which executes on each tick and sets a flag.
In main:-
1) Wait for the flag to set
2) Process each valve in turn
3) Reset the flag.
4) Loop back to (1).
With your 20MHz clock you should have loads of time.
Each of your valves has an on_time and an on_time_counter, also an off_time and an associated off_time_counter.
Start by turning all the valves off and preset the off_time_counters.
So for each valve on every tick:-
a) If Valve is off, decrement off_time_counter.
b) If Valve is on, decrement on_time_counter.
c) If Valve is off and off_time_counter == zero; turn valve on & preset on_time_counter.
d) If Valve is on and on_time_counter == zero; turn valve off & preset off_time_counter.
Repeat this process for all valves in turn.
You will, of course have to be careful about how you deal with zero on_time & pulse_rate.
Mike |
asmallri
Joined: 12 Aug 2004 Posts: 1646 Location: Perth, Australia
Posted: Fri Jan 10, 2014 2:23 pm |
If the valves are synced to some external event then you may want to use a faster timebase such as a 1ms time base instead of 10ms to minimize the error associated with synchronization. _________________ Regards, Andrew
modchip
thank you |
Posted: Sat Jan 11, 2014 4:05 am |
thank you Mike
that seems logic
as i undrestand i must do tow counter for each valve one for the opening delay and the other for the off time
and teh valves have tow parametre for each valve have a value between 0 and 9
and this one can be different for each valve
and other parametre for all valve is the impulsion per minute between 00 and 64 _________________ hi forr all |
Mike Walne
Posted: Sat Jan 11, 2014 5:31 am |
I was trying to keep things simple for you.
If you are going to control by timing you have to convert your parameters to times.
You knew that in your first post, you showed us the formula.
You also need to keep track of the status of each valve.
Store all the parameters as arrays, that way you process all the valves with the same code as you index through the array.
Mike
PS
You could get away with using just the one timer for each valve.
It changes from being on_timer to off_timer depending on valve status.
It's slightly more complex.
As a beginnere your real problem will be dealing correctly with zero parameters and not getting stuck when the timers reach zero. |
modchip
Posted: Sat Jan 11, 2014 8:33 am |
thank s a lot i will try this at week end and tell you _________________ hi forr all |
