DS18S20 & DS18B20 Codes
Goto page Previous  1, 2, 3, 4
Post new topic   Reply to topic    CCS Forum Index -> Code Library
adrix
PostPosted: Sun May 13, 2012 4:44 am     Reply with quote
How can I make that the output would be 0,1 deg accuracy? I'm using DS18S20, so the division by 16 doesn't work.
Mike Walne
PostPosted: Sun May 13, 2012 5:26 am     Reply with quote
Of course it doesn't work.
I don't even use these parts, but I can read the data sheet.
Best ACCURACY is 0.5C.
DS18S20 is 9 bit RESOLUTION part.
LSB represents 0.5C, so that's the best it can do.
If you want better RESOLUTION, maybe use the DS18B20 which goes to 12 bits.
Each LSB is then 0.0625C, you get nearest 0.1C by rounding off.
But ACCURACY is still only 0.5C at best.
I'm assuming you understand the difference between ACCURACY and RESOLUTION.
Mike
stoyanoff
PostPosted: Tue Aug 21, 2012 1:06 am     Reply with quote
I have a problem. I tried your codes but the 18B20 returned very high temperatures - 85 degrees for example. The temperature in the room is not more the 25 degrees.
Where is the problem???
shaharyar
PostPosted: Wed Jan 09, 2013 1:23 pm     Reply with quote
Thanks jds-pic and scanan
the code worked like a charm with a single error Very Happy
cheers
yuripace
PostPosted: Tue Dec 31, 2013 4:15 am     Reply with quote
i have ds18b20.
all is working good at 5v.
at 3.23v temp is stucked to 127.93. I'm using 4,7k resistor connected to datapin on A0 pin of a pic16f876.
any suggestion?
Mike Walne
PostPosted: Tue Dec 31, 2013 9:02 am     Reply with quote
Are you using parasite power mode?
Mike
yuripace
PostPosted: Sat Jan 04, 2014 2:53 am     Reply with quote
on ds18b20 Pin1 connected to gnd, pin3 to 3.5v, DQ connected to A0 pin of pic16f876 with a resistor connected to vcc
yuripace
PostPosted: Sat Jan 04, 2014 4:03 am     Reply with quote
i'm trying different configuration. i'm using scanan code, pic16f876 and external 16mhz clock. I dont know why, now also 5v dont work, stucked at 85°.
1 - parasite power mode: pin 1 and 3 connected to gnd, pin 2 connected to A0 with a pullup resistor: result, 85°
2 - normal mode, pin 1 gnd, pin 2 dataline to A0 pin, pin3 VCC, no resistor result: -0,06
whats wrong?
#include <16F876.h>
#use delay(clock = 16000000)
#fuses HS, NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#include "flexlcd.c"
#include "1wire.c"
void ds18b20_init()
//for  10 bit resolution mod
   onewire_write(0xCC);
   onewire_write(0x4E);
   onewire_write(125);
   onewire_write(-55); //this should be done for proper working of DS18B20
   onewire_write(127);
   onewire_reset();
   onewire_write(0x48);
   delay_ms(15);
float ds1820_read()
 int8 busy=0, temp1, temp2;
 signed int16 temp3;
 float result;
 onewire_reset();
 onewire_write(0x44);
 while (busy == 0)
  busy = onewire_read();
 onewire_reset();
 onewire_write(0xBE);
 temp1 = onewire_read();
 temp2 = onewire_read();
 temp3 = make16(temp2, temp1);
 //result = (float) temp3 / 2.0;   //Calculation for DS18S20 with 0.5 deg C resolution
 result = (float) temp3 / 16.0;  //Calculation for DS18B20 with 0.1 deg C resolution
 delay_ms(200);
 return(result);
float temperature;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
ds18b20_init();
lcd_init();
while (1)
 output_high(PIN_B4);
 lcd_gotoxy(1,1);
 temperature = ds1820_read();
 printf(lcd_putc,"\nTEMP: %f ", temperature);
 output_low(PIN_B4);
yuripace
PostPosted: Sat Jan 04, 2014 4:28 am     Reply with quote
following this
http://www.ccsinfo.com/forum/viewtopic.php?t=40106&start=15
and changing the delay after the convert command to 700ms, now its working, tried at 5v, 4.5v and 3.5v Smile
electr0dave
PostPosted: Fri Aug 15, 2014 4:11 am     Reply with quote
The code below is based on "ds1820.c" made by hansolo.
I made some changes according to the datasheet to increase resolution (about 0.1 ° C): datasheet page 3.
I hope this can be useful for someone.
ds18s20.c
float ds1820_read()
 int8 c, SCRATCHPAD[8];
 int8 busy=0;
 signed int16 temp;
 float result;
 onewire_reset();
 while (busy == 0)
 onewire_reset();
 for(c=0;c<8;c++)
   SCRATCHPAD[c] = onewire_read();
 temp = make16(SCRATCHPAD[1], SCRATCHPAD[0]);
 result = (float) (SCRATCHPAD[7] - SCRATCHPAD[6])/(SCRATCHPAD[7]);
 result = (float) ((temp/2) - 0.25 + result);
 delay_ms(200);
 return(result);
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 4 of 4
