CCP
in_nursery
CCP
PostPosted: Thu Aug 08, 2013 6:18 am     Reply with quote
Hi all
I have trouble to use CCP mode with the picdem with 18f87j11.
I must do something wrong but I don't see it
find a example of what I'm doing, but it don't capture anything!!!
#include <18F87J11.h>
#fuses INTRC_IO       //Osc interne
#fuses noprotect
#fuses nowdt
#use delay(internal=4000000) // inclure procédure de délais (delay_ms() et delay_us())
#use rs232( baud=2400, parity=n, xmit=PIN_C6, rcv=PIN_C7)
#include "LCD16x2.c"
// PORT A
#define BUTTON2      PIN_A5   // PIN_A5  button 2, active low input
// PORT B
#define BUTTON1      PIN_B0  // PIN_B0  button 1, active low input
// PORT D
#define LLED   PIN_D2   //
#define VAL_TRIS_D 0b11111111
//    Calcul de la fréquence du signal
int16 isr_ccp_delta1;
int16 current_ccp_delta1;
int16 frequency1;
float valueF1;
#int_ccp4
void ccp4_isr(void)
//   Frequence
   int16 current_ccp1;
   static int16 old_ccp1 = 0;
   current_ccp1 = CCP_4;  //
   isr_ccp_delta1 = current_ccp1 - old_ccp1;
   old_ccp1 = current_ccp1;
//#     PROGRAMME
void calculFrequence()
   disable_interrupts(GLOBAL);
    current_ccp_delta1 = isr_ccp_delta1;
   frequency1 = (int16)((1000000L + (int32)(current_ccp_delta1 >> 1))/ current_ccp_delta1);
// initialization
void PIC_init(void)
   set_tris_D(VAL_TRIS_D);
   setup_ccp4(CCP_CAPTURE_RE); // Capture front montant
   setup_timer_1(T1_INTERNAL);
//---- PIC init ------------------------------------------------
     setup_oscillator(OSC_4MHZ|OSC_INTRC);
   clear_interrupt(INT_CCP4);
     enable_interrupts(INT_CCP4);
//  M A I N   P R O G R A M
   //Initialisation
   PIC_init();
  while(true)
      calculFrequence();
       valueF1 = frequency1;
      lcd_gotoxy(1,1);
      lcd_putc("\fF");
      lcd_gotoxy(2,1);
      printf(lcd_putc, "%3.0f", valueF1); // affichage acii valeur int16.
thanks in advance
PostPosted: Thu Aug 08, 2013 2:54 pm     Reply with quote
Tell us:
1. What pin on the 18F87J11 is used to receive the input signal ?
2. Describe the input signal. What is the frequency ? What type of
signal is it (digital or analog) ? Is it a sine wave, square wave,
or other rectangular waveform ? Is it a simple periodic waveform or
is it complex ? What are the low and high voltage levels ?
What are the rise and fall times of the signal ? What device is providing
the signal ? In other words, tell us everything about the input signal.
3. If you are using an 18F87J11 development board that you bought,
post the manufacturer and part number or model number of the board.
And post a link to the web page for it.
4. Have you already tested the PIC and the board with a simple program
to prove that the LCD works ? Have you tested the board with an LED
blinking program to prove that the PIC is running at 4 MHz ?
5. What is the Vdd voltage of the PIC ?
6. What is your CCS compiler version ?
7. You said "it don't capture anything". Tell us what you see displayed
on the LCD. Is it nothing ? Or is it 0 Hz ? Tell us.
in_nursery
PostPosted: Thu Aug 08, 2013 3:08 pm     Reply with quote
pin RG3 => ccp4
It's 0-3V square wave signal.
yes it,s from microchip PICDEM PIC18
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en535770
with PIM 18F87J11
yes everything else is working fine it's the capture mode that don't work.
3.3V
4.134
it shows 0Hz
the program is running it only the capture value who is always 0.
thanks
PostPosted: Thu Aug 08, 2013 3:20 pm     Reply with quote
Right, but what is the frequency of the input signal ? And what device
is providing the signal ?
PostPosted: Fri Aug 09, 2013 2:41 am     Reply with quote
What compiler version?.
Try adding:
SETUP_PMP(PMP_DISABLED);
In your initialisation code.
It _should_ be disabled by default, but always when things don't work, start by making sure everything else on the pin that could conflict is turned off.
I'd suggest setting a flag in the interrupt to say it has been called, and only printing when this has happened. Otherwise you are repeatedly printing the same unchanged value.
in_nursery
PostPosted: Fri Aug 09, 2013 5:37 am     Reply with quote
Frequency 80 Hz with a function generator
in_nursery
PostPosted: Fri Aug 09, 2013 6:12 am     Reply with quote
It's done
#int_ccp4
void ccp4_isr(void)
   int16 current_ccp1;
   Flag_CCP=1;
Add Flag_CCP
while(true)
      If(Flag_CCp==1){
      calculFrequence();
      lcd_gotoxy(1,1);
      lcd_putc("\fF");
      lcd_gotoxy(2,1);
      Flag_ccp=0;
      } else {
      lcd_gotoxy(1,1);
      lcd_putc("\fNo CCP");
Always show No CCP never capture any value Evil or Very Mad
PostPosted: Fri Aug 09, 2013 7:55 am     Reply with quote
Have you actually verified the signal is arriving at the pin on the processor?.
The signal source is grounded to the board?.
in_nursery
PostPosted: Fri Aug 09, 2013 8:45 am     Reply with quote
yes to the 2 questions
I really don't know whats happened
