ADC on 18f2420...
joseph20480
ADC on 18f2420...
PostPosted: Wed Jul 31, 2013 6:15 am     Reply with quote
I can't read a correct value with the adc...My code is extremely basic, i don't understand...
#include <18F2420.H>
#device ADC=10
#FUSES INTRC_IO,MCLR,NOWDT,NOWRT,NOLVP
#use delay(internal=8000000)
#use rs232(baud=9600, xmit=PIN_c6,rcv=PIN_c7,parity=N,bits=8,stop=1)
   int16 value;
   setup_oscillator(OSC_8MHZ);
   setup_adc_ports(AN0|VSS_VDD);
      set_adc_channel(0);
   for(;;)
      value=read_adc();
      printf("Value : %lu\n\r",value);
If someone see a big mistake... thanks in advance
CCS version 4.130
PostPosted: Wed Jul 31, 2013 6:36 am     Reply with quote
here's one...
According to typical ADC setup specs in datasheets, 'internal' is NOT recommended any speed over 1MHZ(unless in sleep mode).
Fine the ADC section of your PIC and there should be a chart with 'adc clock vs PIC speed'.some will be highlighted meaning 'do not use'.
hth
jay
joseph20480
PostPosted: Wed Jul 31, 2013 6:59 am     Reply with quote
You have right ! (Page 229)
I have replace
by
setup_adc(ADC_CLOCK_DIV_16);
But not better...
PostPosted: Wed Jul 31, 2013 9:13 am     Reply with quote
What's the ADC connected to ?
A basic test would be a simple voltage divider from Vss to Vdd, with a small 'filter' cap (say 1mfd), maybe giving say 2 volts input (measure with DVM).
'play' computer, do the math to see if the ADC reading is correct.
Also test at zero volts and Vss ( +5 ?).
You should read a fairly stable reading ( +-2-3 bits).
hth
jay
