global variables
mhjccsinfo
global variables
PostPosted: Tue Jul 30, 2013 4:25 pm     Reply with quote
hi all
is it possible to give initial value to the global variables in their declarations/definitions ?
for example:
unsigned int16 minimum=12;
thanks
thanks and hope of success for you
Mohammad_Hosein
PostPosted: Tue Jul 30, 2013 5:07 pm     Reply with quote
yes...
easy to try ...
create a small program and then printout the listing to see how the compiler does it!
hth
jay
mhjccsinfo
PostPosted: Tue Jul 30, 2013 7:47 pm     Reply with quote
Thanks for your reply.
I have tested it before and it worked for me. But I have some halts in program execution and I guess this could be related. Also halts decreased when I delete these values. So as you said it's from somewhere else.
Mohammad_Hosein
PostPosted: Wed Jul 31, 2013 9:06 am     Reply with quote
do you have global CHAR vars with strings that might
OVERFLOW in runtime ??
mhjccsinfo
PostPosted: Wed Jul 31, 2013 11:26 am     Reply with quote
no
Mohammad_Hosein
PostPosted: Wed Jul 31, 2013 11:35 am     Reply with quote
If you can, post a small program that has the problem. Might be something 'silly' that you can't see because you've stared at it foe hours !
Also post compiler version.
hth
jay
mhjccsinfo
PostPosted: Thu Aug 01, 2013 10:39 am     Reply with quote
hth
jay
Thank you temtronic. My problem solved. I've changed my program structure and now it's working well. But i'm always surrounded by these "silly" matters Confused both in software and hardware.
Thanks again for your attention
Mohammad_Hosein
