LED won't switch off!
Mounty
PostPosted: Mon Jul 29, 2013 3:26 am     Reply with quote
I have an LED attached to RA6 on a 16F628A (via a resistor of course).
I want it to come on when
output_high(PIN_A6);
Is executed, but it's on all the time, even when I put
output_low(PIN_A6);
Near the beginning of main().
Any ideas guys?
PostPosted: Mon Jul 29, 2013 5:15 am     Reply with quote
several but the first one is that you've not disabled any/all other internal peripherals that use PIN_A6.
The default use of an I/O pin is not always set to digital I/O.
IE: pins used for the ADC are typically defaulted for ADC use.
Kinda backwards in my opinion as 'in the beginning' there were only digital ins and outs...no 'fancy' peripherals like UARTS,ADC,comparators,timers,etc.
hth
jay
Mounty
PostPosted: Mon Jul 29, 2013 7:58 am     Reply with quote
hth
jay
Thanks. I'll look into disabling other features on the pin.
dyeatman
PostPosted: Mon Jul 29, 2013 11:26 am     Reply with quote
Mounty,
Since you didn't tell us your CCS version and show any initialization code
(fuses etc.), we don't know what oscillator you are using. It's hard to be
sure but, it's likely your fuses.
Google and Forum Search are some of your best tools!!!!
Mounty
PostPosted: Mon Jul 29, 2013 1:00 pm     Reply with quote
dyeatman wrote:
Mounty,
Hi, no worries I just moved the LED onto RB6 and it works perfectly now.
Cheers.
