Need Help understanding CCS Example (EX_WAKUP.C)
haxan7
PostPosted: Sat Jul 27, 2013 6:25 am     Reply with quote
First line of interrupt function ext_isr declares a static variable and sets it false. So every time there is an external interrupt the function get called and every time button_pressed is false. How do the if conditions work if the variable is reinitialized everytime.
Can someone please explain to me how this code works?
Here is EX_WAKUP.C for your convenience.
// global flag to send processor into sleep mode
short sleep_mode;
// external interrupt when button pushed and released
#INT_EXT
void ext_isr() {
static short button_pressed=FALSE;
   if(!button_pressed)        // if button action and was not pressed
Most code deleted.
Reason: Forum rule #10 -
10. Don't post the CCS example code or drivers.
Forum Rules:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
PostPosted: Sat Jul 27, 2013 10:04 am     Reply with quote
You need to learn the C languange. It's initialized only once.
Go to the Wikipedia article on static variables:
http://en.wikipedia.org/wiki/Static_variable#Example
Look at the sample code in this section and read the comments:
An example of static local variable in C
haxan7
PostPosted: Sat Jul 27, 2013 11:02 am     Reply with quote
Thanks a million, i was confusing the static in c++ with static keyword in java.
