pic12f1822 decoding holtec code
gl17
PostPosted: Tue Jul 23, 2013 2:17 pm     Reply with quote
Hi all.
I have a pic12f1822 (with internal RC osc) board with a signal line connected to PIN_A3
I need to decode holtec HT6012 transmitter code.
it looks like so (first 250us "П" pulse is synchro, others are data)
Additional problem - it's a radio channel, and without transmitting it looks so at pin_A3 (sorry haven't good oscilloscope at home) (bottom - transmitter works)
I tried to do it using timer1 directly, like so
//setup_timer1=1us
//call checkCode after first pulse
unsigned int32 checkCode(void)
   unsigned int8 lastState = 0;
   unsigned int8 i;
   unsigned int32 code;
   unsigned int16 timerValue;
   int1 state;
   state = 0;
   putc(0x66);
   while (1) {
      if (get_timer1() > 0x1388) {code = 0xA0000000;break;} // >5ms are passed
      if (input(IN) != state) { //PIN state changed
         timerValue = get_timer1();
         set_timer1(0);
         state = !state;
         i++;
         if ((timerValue > byte_time_low0) & (timerValue < byte_time_low1)) {
                              // lastState = 0: none, 1: _--250, 2: __-500 ,3: -_250 , 4: --_500
                               // in hex == { 0, 1, z } trinary state of pin
                              // __-__- 1   _--_-- 0   __-_-- z
                                       // == 11, 00, 01 half-bits in transmission (LSB 1st)
            if (state == 1) {       //1: _--250
               if (lastState == 0) {lastState = 1;}
               else {code = 0xA0000000;break;} //bad code
            else { // state == 0    //3: -_250
               if (lastState == 0) {code = 0xA0000000;break;} //bad code
               else {
                  if (lastState == 2) {
                     lastState = 0;
                     code = (code << 1) | 0x01;  //
                  } //good code
         else {
            if ((timerValue > byte_time_high0) & (timerValue < byte_time_high1)) {
               if (state == 1) {       //2: __-500
                  if (lastState == 0) {lastState = 2;}
               else { // state == 0    //4: --_500
                  else {
                     if (lastState == 3) {
                        lastState = 0;
                        code = (code << 1) | 0x00;  //
                     } //good code
            else { // bad byte time
   if (i==49) {break;}
   return code; //error if timeout, or error time_packet, or error packet len
it doesn't works, looks like i don't have enough time between pulses.
and i'm feeling i'm doing something really wrong
any ideas how to solve it briefly and elegant ?
PostPosted: Tue Jul 23, 2013 5:12 pm     Reply with quote
HOLTEC decoder IC interfaced to pic?
these have limiters/ signal cleaner circuit and barrel shiffter.
gl17
PostPosted: Tue Jul 23, 2013 6:22 pm     Reply with quote
no additional IC's (
signal from RF circuit goes directly at pin
PostPosted: Tue Jul 23, 2013 7:12 pm     Reply with quote
best of luck with the recovered signal Very Happy Very Happy Very Happy
gpsmikey
PostPosted: Tue Jul 23, 2013 11:10 pm     Reply with quote
Without a decent front end to recover that signal, I think you are for an exercise in frustration - the old "garbage in - garbage out" applies here with a signal that looks that ratty.
mikey
mikey
PostPosted: Wed Jul 24, 2013 8:42 am     Reply with quote
BTW: 40 years of my career has been involved with RF .
and the recovered signal you show looks for all the world like its either :
1- unfiltered direct conversion output, with low signal input
or
2- heterodyne IF system well below limiting
or
3- slight frequency mismatch between TX and your RX
And on second thought , even the Holtec receiver chip will not be of much use with that signal as an input.
Either way , you will find no joy as you attempt reliable data recovery.
Your RF link is way too crappy, and no PIC code is gonna make it right.
you can take it to the bank .
Sad Sad
