asmboy
16f1509 no apparent RS232 support [solved] |
Posted: Tue Jul 23, 2013 4:26 pm |
#include <16f1509.h>
#Fuses XT,NOWDT,PUT,NOMCLR,NOPROTECT,NOBROWNOUT,NOIESO
#Fuses NOFCMEN,NOWRT,NOSTVREN,NODEBUG,NOLVP
#use delay( clock=2097152 ) // using power of 2 Xtal
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#include <stdlib.h>
#byte RCSTA = 0x19D
#byte TXSTA = 0x19E
#bit SPEN = RCSTA.7
#bit TXEN = TXSTA.5
#bit SYNC = TXSTA.4
MAIN() {
output_a (0); output_b (0); output_c (0);
set_tris_a (0b11111110); // - all INPUT OUT= A0,
set_tris_b (0b11111111); // all input
set_tris_c (0);
setup_adc_ports( NO_ANALOGS );
setup_adc( ADC_OFF );
#use rs232(baud=9600, rcv=PIN_B5, xmit=PIN_B7, ERRORS )
SPEN=1; // output TX pin does not go high w/o this added
TXEN=1; // hail mary per Datasheet
SYNC=0; // hail mary per Datasheet
while (1){
delay_ms(250);
output_toggle (pin_A0); // accurate delay observed on this pin
printf ( "Hello World\r" ); //output message does not happen
} // do while end
} // main end
the SPEN and TXEN manipulation were required just to get the TX pin to go to the idle HI state , ( cribbed from the data sheet as well as SYNC)
PIN_A0 clock nicely at the expected rate.
This compiles under 4.141 and 5.005 -no errs or warns -
but neither version ever transmits any data from PIN B7
BTW: if i FORCE_SW and CLR tris B.7 - software transmit is possible
but useless in this application. the hardware support is simply not there!!
and YES been reported to CCS
bummer ........
