[Error] CCS C display File not found
tienchuan
PostPosted: Sun Jun 16, 2013 5:06 am     Reply with quote
Dear all.
I have a project with directory
D:\WORK\ASTI\PCB\04.DU AN RD\05.LED MATRIX\03.CODE\LUU CODE\VERSION 1( 07-05-13)\CODE PIC18F4680\COUNTER MOI 14-06-13
but when i use CCS C Compiler to build code to hex, it had display NOT FOUND main c file.
I'm using CCS C version 4.140.
Pls show me way to fix it.
Begin Begin Begin !!!
PostPosted: Sun Jun 16, 2013 8:14 am     Reply with quote
You'll need to put inverted commas round the filename.
Spaces cannot be used in a filename passed as an argument to a function, without this. This is standard Windows. Problem is that space is a command separator in the Windows command line.
tienchuan
PostPosted: Sun Jun 16, 2013 8:39 am     Reply with quote
thanks u Ttelmah, I tried your way but it's still error,
when i change create new project in the same directory, it build ok:)
thanks u Smile
PostPosted: Sun Jun 16, 2013 10:33 am     Reply with quote
Double inverted commas, not singles.
It does work.
