matheusmestres28
| Problem with pic12f - Software or hardware? |
Posted: Mon May 13, 2013 1:43 pm |
Hello guys, I'm using pic12f1822 and an accelerometer in one of my applications and having some problems. Pic12f1822 isn't an available device in proteus, so I'm using pic12f683 to simulate my circuit and check if there is something wrong with my code or hardware. I had already built the circuit on the breadboard with 1822 and didn't worked, and I guess it's a software problem, maybe something with the serial communication settings. Can anyone help me??
Proteus points this error: "ADC conversion started before wait time has expired following previous conversion or channel change".
| Code: | #include <12f683.h>
#device adc=10
#FUSES NOWDT, INTRC, NOMCLR
#use rs232(baud=9600,xmit=PIN_A3)
float vx,ax,vy,ay,vz,az;
void printaccel(char ca,float a)
printf("A aceleracao no eixo %c e': %f \n\r",ca,a);
set_tris_a(0b00011000);
setup_adc_ports(ALL_ANALOG);
while(TRUE){
set_adc_channel(0);
delay_us(10);
vx = read_adc();
vx = vx*0.0048875855327468;
ax = (vx-1.65)*12.25;
printaccel('x',ax);
set_adc_channel(1);
delay_us(10);
vy=read_adc();
vy = vy*0.0048875855327468;
ay = (vy-1.65)*12.25;
printaccel('y',ay);
set_adc_channel(2);
delay_us(10);
vz=read_adc();
vz = (vz*0.0048875855327468);
az = (vz-1.65)*12.25;
printaccel('z',az);
Proteus circuit is in the link below:
http://img600.imageshack.us/img600/7231/simulationp.png[/url] |
gpsmikey
Posted: Mon May 13, 2013 2:18 pm |
Probably the best thing to do is get your hands on some real parts and test your circuit out. For many cases, Proteus seems to create more problems than it solves - see this link for more info:
http://www.ccsinfo.com/forum/viewtopic.php?t=47549
Especially in the area of fuses and timing, Proteus seems to miss (or ignore) the correct settings. I would double check the delay settings and A/D converter clock settings in the spec sheet - those can sometimes take a bit to make sure you have the right ones and if you don't have the A/D converter clock selected correctly, things don't work as expected (as I discovered myself some time ago )
mikey _________________ mikey
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Mon May 13, 2013 2:44 pm |
With respect to real hardware...
You're using a 5 volt PIC...is the accelerometer rated for 5 volts?
Which mfr/make/model ? Having 3 analog outputs is 'rare', most are digital...
Use 3 pots instead of accel unit...makes it easy to debug code/hardware issues.
hth
jay |
Posted: Mon May 13, 2013 2:57 pm |
Screaming problem is the serial pin....
A3, is _input only_.
matheusmestres28
Posted: Wed May 15, 2013 2:27 pm |
| temtronic wrote: | With respect to real hardware...
hth
jay |
Actually, the accelerometer is in a small board, which contains a Vin pin (3.3V to 16V). The circuit has an internal voltage regulator to 3.3V |
Posted: Wed May 15, 2013 2:36 pm |
| Quote: |
If you would simply download the 12F683 data sheet, and go to the
chapter on ADC and read the section on Acquisition requirements, and
look at their sample calculation and the result, then you would instantly
see the problem with your code and find the answer. |
matheusmestres28
Posted: Wed May 15, 2013 2:43 pm |
| Ttelmah wrote: | Screaming problem is the serial pin....
I have a doubt here.. PIN_A3 = GP3 or AN3??
One of my friends in lab told me PIN_A3 = AN3.
In pic 12f683 datasheet, AN3 = GP4 = I/O port, but GP3 = MCLR = input only.
Which of these is the correct one??
tyty |
asmboy
yes the adc problem is very clear,
as is the RS232 issue.
the amount of floating point, repeated code , is an awfully full load
for such a small memory model pic.
if you MUST use floating point (which i deeply DOUBT)
ccs does a very good job with function calls and could save much
memory for you. |
matheusmestres28
Posted: Wed May 15, 2013 2:49 pm |
| PCM programmer wrote: | | Quote: |
ok, I've already read it, but I'm going to read it again. My english isn't that good, so I must have misread something |
Posted: Wed May 15, 2013 2:58 pm |
I think I discovered the problem. There are two versions of the 12F683
data sheet that pop up on Google. (Assuming Google is used to find them).
In the "b" version of the data sheet, in 9.2 A/D Acquisition Requirements,
it shows Tacq = 19.72 μs.
In the "d" version, Microchip has changed it. Now Tacq = 4.67 us.
So your code would meet the spec for the "d" version, but it appears
that the Proteus model was likely made based on the "b" version value.
You can test this by changing your delay_us() statements after the A/D
channel change to be 20 us.
This likely explains the Proteus issue, but here I've violated our
belief on this forum that we should not be solving Proteus problems. |
matheusmestres28
Posted: Mon May 20, 2013 12:55 pm |
| PCM programmer wrote: | I think I discovered the problem. There are two versions of the 12F683
Thank you very much man, I'm sorry for the off topic question, but it was a problem related to ccs and I thought here was the best place to ask for it.
Really, thank you very much!! |
matheusmestres28
Posted: Mon May 20, 2013 1:13 pm |
ohh, btw, it worked fine when I did what PCM says, changed xmit to PIN_A4 and redefined my fuses to intrc_io instead of intrc only.
Now I'm going to try it on 12f1822.
Thank you very much guys |
