Who can help me ? UART PIC18F4620 and ZigBee
Knight_FlyCn
PostPosted: Tue May 14, 2013 4:17 am     Reply with quote
#include <Coordinator.h>
#include "def_18f4620.c"
#include "slave_2_tx_rx.h"
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#bit CS     = 0xF80.4
#bit RST    = 0xF82.2
#bit INT_   = 0xF81.0
#bit WAKE   = 0xF82.1
#bit CS_Direction    = 0xF92.4
#bit RST_Direction   = 0xF94.2
#bit INT_Direction   = 0xF93.0
#bit WAKE_Direction  = 0xF94.1
INT TEMP;
INT COMMAND,adress_surport=0x01;
const int IP_request=0x00,ip_surport=0x10;
#INT_EXT
void ngat_RB0()
   temp = read_ZIGBEE_short(INTSTAT); // Read and flush register INTSTAT
   if ((temp&(1<<3))==(1<<3))
   {  rc0=rd3=!rd3;
      read_RX_FIFO();
      command=data_rx[0];
      switch (command)
      case IP_request:
         adress_surport++;
         PAN_ID_destination[0] = PAN_ID[0];
         PAN_ID_destination[1] = PAN_ID[1];
         address_short_destination[0] =   rfd_address_short[0];
         address_short_destination[1] =   rfd_address_short[1];
         PAN_ID_source[0] = PAN_ID[0];
         PAN_ID_source[1] = PAN_ID[1];
         address_short_source[0] = coord_address_short[0];
         address_short_source[1] = coord_address_short[1];
         data_tx[0]=ip_surport;
         data_tx[1]=adress_surport;
         write_TX_normal_FIFO();
   DISABLE_INTERRUPTS(INT_EXT);
   TRISB1=TRISB2=TRISB3=1;
   TRISC0=TRISD3=0;
    CS_Direction   = 0;     // Set direction to be output
   RST_Direction  = 0;     // Set direction to be output
   INT_Direction  = 1;     // Set direction to be input
   WAKE_Direction = 0;     // Set direction to be output
   rc0=rd3=1;
   Delay_ms(5);
   setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);  // Initialize SPI module
   pin_reset();                              // Activate reset from pin
   software_reset();                         // Activate software reset
   RF_reset();                               // RF reset
   set_WAKE_from_pin();                      // Set wake from pin
   set_long_address(ADDRESS_long_2);
   set_short_address(coord_address_short);       // Set short address
   set_PAN_ID(PAN_ID);                     // Set PAN_ID
   init_ZIGBEE_nonbeacon();                  // Initialize ZigBee module
   nonbeacon_PAN_coordinator_device();
   set_TX_power(31);                         // Set max TX power
   set_frame_format_filter(1);               // 1 all frames, 3 data frame only
   set_reception_mode(1); // 1 normal mode
   delay_ms(10);
   enable_int();
   pin_wake(); // Wake from pin
   enable_interrupts(INT_EXT);
   ext_int_edge(H_to_L);
   while (1)
I do not know what the above command made ​​the connection to the computer. To transfer data to and from RFD to Coodinator computer.
---> Who can help me ? what line code ?
Thinh
PostPosted: Tue May 14, 2013 6:00 am     Reply with quote
Without seeing what's in these files...
... it's nearly impossible to help you.
It appears that a Zigbee module is connected via SPI mode to a PIC and that 'something' interrupts the PIC on the B0 pin,triggering the ISR,'stuff' is done including...
...which may or may not be sending Zigbee data to the PC..
again, very very hard to figure out unless the 3 files are shown.
hth
jay
PostPosted: Tue May 14, 2013 6:08 am     Reply with quote
and the code is appalling.
What is the point of sitting in a loop continuously enabling an interrupt. Why is it ever turned off?. Then the 'form' suggests this has possibly been ported from another compiler, by someone who has little or no knowledge of CCS.
