RS232C communication using the PIC18F4550
Mally
PostPosted: Sun May 12, 2013 8:13 pm     Reply with quote
I hope to communicate with a PC and PIC18F4550 at RS232C.
But the PC does not receive anything.
PIC16F877A and PIC16F887 and PIC18F46K20 is OK.
#include <18F4550.h>
#include <stdlib.h>
#fuses HS,NOLVP,NOWDT,PUT
#use RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7)
   printf("test\n");
PostPosted: Mon May 13, 2013 12:32 am     Reply with quote
The obvious main problem is the clock.
You are not specifying the CPUDIV fuse value. The default will be CPUDIV4, do your chip will actually be running at 5MHz, not 20MHz.
Also, as shown, only the first three characters will ever print, as the code drops off the end before the transmission completes.
Finally repeat 50*, I must _always_ have 'errors' in a hardware RS232 declaration, unless I handle errors myself. Otherwise if the RX line is floating, or data is sent from the PC, the UART will become hung.
#include <stdlib.h>
#fuses HS,NOLVP,NOWDT,PUT,CPUDIV1 //fix the fuses
#use RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7,ERRORS)
void do_nothing(void)
   RS232_ERRORS=0;
//This does absolutely nothing, except to stop the compiler generating
//an error that RS232_ERRORS is not used....
   printf("test\n");
   do ;
   while (TRUE); //avoid the drop off the end, so the whole message is sent
Unless you have a hardware problem, or are using a very old compiler, this does correctly generate the message.
Mally
PostPosted: Mon May 13, 2013 1:16 am     Reply with quote
Thank you very much for taught me.
I tried the code that you have learned, but it did not receive on PC.
I think no problem is hard , because it is normal in other devices. Crying or Very sad
Compiler is not old. (ver 4.140)
This device need special configuration?
PostPosted: Mon May 13, 2013 2:33 am     Reply with quote
The code I posted works on a 4550, with a 20MHz crystal. Power attached, MCLR pulled up.
Hardware.....
ezflyr
PostPosted: Mon May 13, 2013 6:33 am     Reply with quote
Is your PIC actually running? Can you connect an LED to one of the I/O pins (thru a suitable current limiting resistor), and flash it at a known rate? Turn the LED On for one second and then Off for one second. Do this repetitively, and verify that the LED flashes, and does so at the correct rate. Until you can do this successfully, forget about RS232.
John
Mally
PostPosted: Mon May 13, 2013 8:07 pm     Reply with quote
Arrow
Mally
PostPosted: Mon May 13, 2013 10:37 pm     Reply with quote
Sorry.
It was with reference to the old compiler.
Thank you for your help.
Mally
Receive is abnormal
PostPosted: Tue May 14, 2013 7:47 pm     Reply with quote
Hello.
I was able to successfully send.
However, receive is abnormal.
It will be forever 1 Byte received.
I send "A" .
forever Returns "A" .
Other devices is normal.
#include <stdlib.h>
   char data;
    printf("test\n");
    while(1){
   data=getc();
   putc(data);
bkamen
Re: Receive is abnormal
PostPosted: Tue May 14, 2013 8:40 pm     Reply with quote
Mally wrote:
Hello.
I send "A" .
#include <stdlib.h>
   char data;
    printf("test\n");
    while(1){
   data=getc();
   putc(data);
you need to TEST to see if a char has been received EVERY time you think one might be in the buffer.
This is done via kbhit()...
so you should have something more like:
if ( kbhit() )  {
   putc( getc() );
Mally
PostPosted: Tue May 14, 2013 8:50 pm     Reply with quote
Thank you for your reply.
However, the result was the same. Sad
Why only abnormal at this device ...
PostPosted: Tue May 14, 2013 10:39 pm     Reply with quote
Your hardware is likely bad.
I installed vs. 4.140 and compiled the code that you posted on
"Tue May 14, 2013 5:47 pm" and programmed it into an 18F4550.
I'm using a PicDem2-Plus board (non-Rohs, red board version).
I have a 20 MHz crystal installed. I connected the board to my PC
with a 9-pin serial port cable. I opened a TeraTerm window and
starting typing the alphabet. (Local echo is disabled in TeraTerm).
It works. I get this displayed on the TeraTerm window:
test
    abcdefghijklmnopqrstu
Check your hardware. Get a new 18F4550.
Mally
PostPosted: Wed May 15, 2013 4:03 am     Reply with quote
It was successfully After the upgrade of MPLAB. Razz
PostPosted: Wed May 15, 2013 8:17 am     Reply with quote
Er. You didn't mention MPLAB anywhere.....
