Project
amani
Project
PostPosted: Sun May 12, 2013 6:19 pm     Reply with quote
hi
plz can any one help me in my project work ?
i need to know how to program Pic 16F877 with Rs232 & LCD
PostPosted: Mon May 13, 2013 5:39 am     Reply with quote
CCS is kind enough to supply working, example code for both RS-232 and LCD interfaces !
The examples are in the 'EXAMPLES' folder that was created when you installed PCM.
Also PCM programmer has added a 'flex_LCD' driver to the code library here.It is easier to setup and use though both work fine with the 16F877.
You should spend a few hours looking over the examples, as CCS has created code for most of the projects you're likely to build.
And...try the 'search' function on this site..you'll find LOTS of postings about both subjects 'rs232 and LCD'.
hth
jay
Gabriel
PostPosted: Mon May 13, 2013 7:13 am     Reply with quote
What are you trying to achieve?
you want to display the incoming serial data on the LCD?
you want to display data both on LCD and Serial?
G.
CCS PCM 5.078 & CCS PCH 5.093
