while
wahid
while
PostPosted: Fri May 03, 2013 6:16 pm     Reply with quote
I have a question PIC C compile.
  how to exit the while loop condition because the break problem unconditionally
PostPosted: Fri May 03, 2013 6:28 pm     Reply with quote
sorry, but this does not make sense for me.
IS the unconditional way out of while
if (condition) break;
is the conditional way.
also return;
IF you not in main();
PostPosted: Fri May 03, 2013 7:47 pm     Reply with quote
jeremiah has an example of breaking out of a while loop here:
http://www.ccsinfo.com/forum/viewtopic.php?t=47894&highlight=break&start=11
PostPosted: Sat May 04, 2013 3:25 am     Reply with quote
This is actually nothing to do with 'PIC C', but is just standard C...
You have three things in a while loop.
First, the standard 'exit' condition evaluated each time the loop executes.
Then 'continue', which forces this evaluation to occur immediately.
Finally 'break' which exits the loop without testing the exit condition.
Both continue, and break, can themselves be executed with a test.
You have already been given examples of using 'break' with tests. The other method is using 'continue', so:
int1 loop=TRUE;
   while (loop)
       //do what you want
       if (some exit condition)
           loop=FALSE;
           continue;
       //and more of what you want
Here, a 'test' changes the looping condition to 'FALSE', and forces an immediate re-test of the loop condition.
wahid
PostPosted: Sat May 04, 2013 9:44 am     Reply with quote
my problem I use a 4 * 4 keypad and display. Each button has a function and this function when the data REGARDLESS while loop and complaint in this button.
example temperature value button button to happiness
PostPosted: Sat May 04, 2013 11:30 am     Reply with quote
then post that code and lets look at it's structure.
wahid
PostPosted: Sat May 04, 2013 6:32 pm     Reply with quote
such as phone button click button gives 3la result on screen when button function with while
when I click given function but when I click has another button without complaint while not.
thank you
