L3GD20 problem in reading values *** Locked - No progress
Goto page 1, 2, 3  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
rajm
PostPosted: Mon Apr 29, 2013 10:27 pm     Reply with quote
hi
I have got Pololu minIMU-9V2, in which I'm trying to read gyroscope values. When i connect my sensor its always showing X=-1, and when i disconnect my sensor its showing X=10223 0r X=10877. Since it has got pull up resistor i didn't connect external pull up resistor.
my code is
#Include <18f4550.h>
//#use delay(xtal=20Mhz)
//#fuses NOWDT,HS
#fuses HS,MCLR,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=2000000)
#use i2c(Master,sda=PIN_B0,scl=PIN_B1)
#define LCD_ENABLE_PIN PIN_C2
#define LCD_RS_PIN PIN_C1
#define LCD_RW_PIN PIN_C0
#define DATA_PORT  PORTD
#include <lcd.c>
#define gyro_ADD_R 0xD3
#define gyro_ADD_W 0xD2
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int16 x=0;
int8 xM=0,xL=0;
void writeRegister(int8 reg,int8 value)
    i2c_start();
    i2c_write(gyro_ADD_W);
    i2c_write(reg);
    i2c_write(value);
    i2c_stop();
void init_gyro()
writeRegister(CTRL_REG1,0b00001111);
writeRegister(CTRL_REG2,0b00001000);
writeRegister(CTRL_REG3,0b00001000);
writeRegister(CTRL_REG4,0b10110000);        //10110000
writeRegister(CTRL_REG5,0b00000000);
lcd_gotoxy(1,1);
printf(lcd_putc," L3GD20");   // l3g4200d
init_gyro();
while(true)
    i2c_start();
    i2c_write(0XD2);
    i2c_write(0x28);
    i2c_start();
    i2c_write(0XD3);
    xL=i2c_read();
    xM=i2c_read(0);
    x=make16(xM,xL);
    i2c_stop();
    printf(lcd_putc"\f");
    lcd_gotoxy(1,2);
    printf(lcd_putc,"x=%Ld",x);
    delay_ms(50);
kindly help me to overcome this problem.
regards
PostPosted: Mon Apr 29, 2013 11:10 pm     Reply with quote
//#fuses NOWDT,HS
What is the frequency of your external crystal or oscillator ?
rajm
PostPosted: Tue Apr 30, 2013 12:23 am     Reply with quote
in my pic demo board it is 4mhz..but i dont know how to see in datasheet..
PostPosted: Tue Apr 30, 2013 11:24 am     Reply with quote
Then why do you have #use delay() set for 2 MHz ? The #use delay()
frequency tells the compiler the PIC oscillator speed. Then the compiler
can correctly setup the internal delay routines and hardware modules.
PostPosted: Tue Apr 30, 2013 11:43 am     Reply with quote
and 'HS'....
vrs
PostPosted: Tue Apr 30, 2013 5:26 pm     Reply with quote
#include "C:\Users\semerci\Desktop\dddd\imu.h"
#include <flexLCD.C>
#int_SSP
#use i2c(master, SDA=PIN_C4, SCL=PIN_C3)
void  SSP_isr(void)
#define gyro_ADD_R 0b11010111
#define gyro_ADD_W 0b11010110
/*#define CTRL_REG1 0x20
#define L3G_DEVICE_AUTO 0
#define L3G4200D_DEVICE 1
#define L3GD20_DEVICE   2*/
// SA0 states
#define L3G_SA0_LOW  0
#define L3G_SA0_HIGH 1
#define L3G_SA0_AUTO 2
// register addresses
#define L3G_WHO_AM_I      0x0F
#define L3G_CTRL_REG1     0x20
#define L3G_CTRL_REG2     0x21
#define L3G_CTRL_REG3     0x22
#define L3G_CTRL_REG4     0x23
#define L3G_CTRL_REG5     0x24
#define L3G_REFERENCE     0x25
#define L3G_OUT_TEMP      0x26
#define L3G_STATUS_REG    0x27
#define L3G_OUT_X_L       0x28
#define L3G_OUT_X_H       0x29
#define L3G_OUT_Y_L       0x2A
#define L3G_OUT_Y_H       0x2B
#define L3G_OUT_Z_L       0x2C
#define L3G_OUT_Z_H       0x2D
#define L3G_FIFO_CTRL_REG 0x2E
#define L3G_FIFO_SRC_REG  0x2F
#define L3G_INT1_CFG      0x30
#define L3G_INT1_SRC      0x31
#define L3G_INT1_THS_XH   0x32
#define L3G_INT1_THS_XL   0x33
#define L3G_INT1_THS_YH   0x34
#define L3G_INT1_THS_YL   0x35
#define L3G_INT1_THS_ZH   0x36
#define L3G_INT1_THS_ZL   0x37
#define L3G_INT1_DURATION 0x38
int16 x=0;
int8 xM=0,xL=0;
int8 yM=0,yL=0;
int8 zM=0,zL=0;
 { lcd_gotoxy(6, 1);
   printf(lcd_putc, "1");
    i2c_start();  lcd_gotoxy(6, 1);printf(lcd_putc, "test1");
    i2c_write(gyro_ADD_W);lcd_gotoxy(7, 1);printf(lcd_putc, "test11");
    i2c_write(reg); lcd_gotoxy(8, 1);printf(lcd_putc, "test11");
    i2c_write(value);lcd_gotoxy(9, 1);printf(lcd_putc, "test1");
    i2c_stop();lcd_gotoxy(10, 1);printf(lcd_putc, "test11");
    lcd_gotoxy(0, 1);
   printf(lcd_putc, "i2cstart çıkış");
    delay_ms(50);
void init_gyro()
{    printf(lcd_putc, "\f");
   lcd_gotoxy(0, 1);
   printf(lcd_putc, "i2cstart test");
writeRegister(L3G_CTRL_REG1,0b00001111);
   lcd_gotoxy(0, 2);
   printf(lcd_putc, "i2cstart tes");
writeRegister(L3G_CTRL_REG2,0b00001000);
   lcd_gotoxy(0, 3);
writeRegister(L3G_CTRL_REG3,0b00001000);
   lcd_gotoxy(0, 4);
writeRegister(L3G_CTRL_REG4,0b10110000);        //10110000
   lcd_gotoxy(10, 1);
   printf(lcd_putc, "tamam");
writeRegister(L3G_CTRL_REG5,0b00000000);
set_tris_c(0xFE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_CLOCK_DIV_2);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_spi(SPI_SS_DISABLED);
   enable_interrupts(INT_SSP);
   lcd_gotoxy(0, 1);
   printf(lcd_putc, "ekran deneme");
   lcd_gotoxy(0, 2);
   printf(lcd_putc, "ekran deneme2");
   lcd_gotoxy(0, 3);
   printf(lcd_putc,"ekran deneme3");
   lcd_gotoxy(0, 4);
   printf(lcd_putc, "6543210987654321");
   init_gyro();
   lcd_gotoxy(1,1);
    i2c_start();
    i2c_write(0b11010110 );
    i2c_write(L3G_OUT_x_H);
    i2c_start();
    i2c_write(0b11010111);
    xL=i2c_read();
    xM=i2c_read(0);
    i2c_stop();
    i2c_start();
    i2c_write(L3G_OUT_y_H);
    i2c_start();
    yL=i2c_read();
    yM=i2c_read(0);
    i2c_stop();
    i2c_start();
    i2c_write(L3G_OUT_z_H);
    i2c_start();
    zL=i2c_read();
    zM=i2c_read(0);
    i2c_stop();
    x=x+1;
    if (x=1)
//    x=make16(xM,xL);
    lcd_gotoxy(1,2);
    printf(lcd_putc,"\%Ld ",x); //x=%Ld
    lcd_gotoxy(0, 3);
    printf(lcd_putc,"\%d  \%d  \%d",xm,ym,zm);
    lcd_gotoxy(0, 4);
    printf(lcd_putc,"\%d  \%d  \%d",xl,yl,zl);
    x=0;
    xM=0,xL=0;
    yM=0,yL=0;
    zM=0,zL=0;
PostPosted: Wed May 01, 2013 5:31 am     Reply with quote
Dear user 'vrs',
Why are you posting this code? Without any comments we don't know what to do with it.
Are you the same person as the original topic starter 'rajm'? I do suspect so because you did also post in Rajm's other thread, but without any comments we don't know.
See Rajm's other thread where Ttelmah made some comments on the SSP interrupt. These same comments do apply here.
Then, why did you post the code?
Is it not working and do you want us to have a look at it?
If yes, then tell us what is working and what is not. What is the result you expected to get and what are the (wrong) results you do get. You are the one with the real hardware in front of you. We can't read minds so need all the clues you can give us.
ALWAYS post your compiler version number!
This line is wrongly generated by a wizard in the old compiler versions, so at least we know you have an old compiler, but how old?
The correct code should be:
setup_spi(FALSE);
or in the newer versions:
setup_spi(SPI_DISABLED);
    if (x=1)
This is such a beginner's mistake... I suggest you get your C book and fix it yourself.
The code as posted can not be tested by us because the file imu.h is missing. Now we don't know which processor you are using.
For example the original Ramj code was using a PIC18F4550 which requires the NOPBADEN fuse if you want too use PortB for digital I/O.
vrs
PostPosted: Wed May 01, 2013 5:54 am     Reply with quote
Minumuv9 to read the value from the sample.
if(x=1) to test. I forgot to delete it.
code is incorrect. minimuv9 can read from from the value.
to to be an example. to Rajm
vrs
PostPosted: Wed May 01, 2013 6:01 am     Reply with quote
using pic 16F877.
codes are added for illustration.
To read the value from minimu9v2.
working.
I do not know English. I am writing the message using Google Translate.
PostPosted: Wed May 01, 2013 10:22 am     Reply with quote
Hi vrs,
Thank you for sharing your code.
Always nice when someone who doesn't speak English makes the effort to share his knowledge.
rajm
PostPosted: Wed May 01, 2013 10:41 pm     Reply with quote
hi
Thank you for your help. I don't know whether program updated by vrs will work for my sensor. For what purpose the void SSP_isr(void) is used ?
How to display these in 2x16 lcd? Its enough if it displays one after other on same line in lcd.
regards
vrs
PostPosted: Thu May 02, 2013 5:02 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=50012&highlight=minimu9
here's the last I wrote the code is running.
LCD 4 x 16
row 2 gyro x y z
line 3 acce x y z
line 4 magn x y z
Values are not regulated. is intended to represent the screen.
You do the arrangements.
I ran into the hardware. Not on computer.
I did the installation to 16F877. I used 4.7k pullup resistor.
errors to be passed to the new ccs c.
rajm
PostPosted: Fri May 03, 2013 12:36 am     Reply with quote
hi
You wrote the code for gyro in the above post, then how it display all the three sensor values in LCD. I have changed that gyro code for my gyro sensor L3GD20, but it shows result as -1 -1 -1 and it is not changing when i change the sensor. How to overcome this?
regards
rajm
PostPosted: Fri May 03, 2013 2:27 am     Reply with quote
hi vrs
explain about first #include and int8 line in the last coding you wrote in above link..
regards
vrs
PostPosted: Fri May 03, 2013 2:49 am     Reply with quote
#include "C:\Users\semerci\Desktop\dddd\lcdddd.h"
#include <16f877a>
#include <imu.C> \\
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3,fast)
int8 konum=0, hesapH=0,hesapL=0;
signed long hesap=0;
void writeRegister(int8 reg,int8 value,int tur)
    i2c_start();
    i2c_write(tur);
    i2c_write(reg);
    i2c_write(value);
    i2c_stop();
void init_gyro()
writeRegister(L3G_CTRL_REG1,0b11101111,gyro_ADD_W);
writeRegister(L3G_CTRL_REG2,0b00000000,gyro_ADD_W);
writeRegister(L3G_CTRL_REG4,0b0010000,gyro_ADD_W);
void init_acce()
writeRegister(LSM303_CTRL_REG1_A,0x47,acce_ADD_W);
writeRegister(LSM303_CTRL_REG4_A,0b00101000,acce_ADD_W);
void init_magn()
writeRegister(LSM303_SR_REG_M, 0b00000001,magn_ADD_W);
writeRegister(LSM303_IRA_REG_M,0b01001000,magn_ADD_W);
writeRegister(LSM303_IRB_REG_M,0b00110100,magn_ADD_W);
writeRegister(LSM303_IRC_REG_M,0b00110011,magn_ADD_W);
writeRegister(LSM303_CRA_REG_M,0b10010000,magn_ADD_W);
writeRegister(LSM303_CRB_REG_M,0b10000000,magn_ADD_W);
writeRegister(LSM303_MR_REG_M, 0b00000000,magn_ADD_W);
int a;
void Hesapla_Yaz(int adresR,int adresW) //adresR=device Read adres,adresW =device write adres
int i;a=1;int b=0;char c;
   for ( i=40;i<46;i+=2)  //40=0x28  xHbit, 42=0x2b yHbit, 44=0x2d zHbit
    b=i;   //b=hbit, b+1=lbit. acce,gyro xHbit=0x28 xLbit=029
      if (adresR==magn_ADD_R)
         konum=2;
         b=i-37;//magnetometer xLbit=3 xHbit=4,yLbit=5 yHbit=6,zHbit=7,zHbit=8
         c="m";
      i2c_start();i2c_write(adresW);i2c_write(b);i2c_start();i2c_write(adresR);hesapH=i2c_read(),i2c_read(0);i2c_stop(); //hesapH=device x or y or z hbit
      i2c_start();i2c_write(adresW);i2c_write(b+1);i2c_start();i2c_write(adresR);hesapL=i2c_read(),i2c_read(0);i2c_stop(); //hesapL=device x or y or z Lbit
      hesap=make16(hesapH,hesapL);//hesap =long variable
      if (adresR==acce_ADD_R)
         konum=3;//lcd line
               hesap=hesap>>4; //Accelerometer: one 12-bit reading (left-justified) per axis
         c="a";
      if (adresR==gyro_ADD_R)
      c="g";
         konum=4;
   Lcd_gotoxy(konum+8, 1); printf(lcd_putc,"\%c",c);Lcd_gotoxy(1, 1); printf(lcd_putc,"satirlar=");//lcd 2x16 for konum=1 or 2
   Lcd_gotoxy(a, konum); printf(lcd_putc,"\%Ld",hesap);
   a=a+6; //lcd row
   set_tris_c(0xFE);
   /*setup_adc_ports(NO_ANALOGS);
   setup_vref(FALSE);
   enable_interrupts(GLOBAL);*/
   lcd_gotoxy(1, 1);
   printf(lcd_putc, "minimu9 v2");
   lcd_gotoxy(1, 3);
   printf(lcd_putc, "KARAMAN/ERMENEK");
   lcd_gotoxy(1, 2);
   printf(lcd_putc, "pic 16f877");
   lcd_gotoxy(1, 2);
   printf(lcd_putc, "4x16 lcd");
   init_gyro();
   init_acce();
   init_magn();
   hesapla_yaz(gyro_ADD_R,gyro_ADD_W); //only gyro
   hesapla_yaz(acce_ADD_R,acce_ADD_W); //only accelometer
   init_magn(); //not work Without this.//compas for
   hesapla_yaz(magn_ADD_R,magn_ADD_W);//compas
imu.c dosyası
// SA0 states
#define LSM303DLH_DEVICE   0
#define LSM303DLM_DEVICE   1
#define LSM303DLHC_DEVICE  2
#define LSM303_DEVICE_AUTO 3
// SA0_A states
#define LSM303_SA0_A_LOW  0
#define LSM303_SA0_A_HIGH 1
#define LSM303_SA0_A_AUTO 2
#define LSM303_CTRL_REG1_A       0x20
#define LSM303_CTRL_REG2_A       0x21
#define LSM303_CTRL_REG3_A       0x22
#define LSM303_CTRL_REG4_A       0x23
#define LSM303_CTRL_REG5_A       0x24
#define LSM303_CTRL_REG6_A       0x25 // DLHC only
#define LSM303_HP_FILTER_RESET_A 0x25 // DLH, DLM only
#define LSM303_REFERENCE_A       0x26
#define LSM303_STATUS_REG_A      0x27
#define LSM303_OUT_X_L_A         0x28
#define LSM303_OUT_X_H_A         0x29
#define LSM303_OUT_Y_L_A         0x2A
#define LSM303_OUT_Y_H_A         0x2B
#define LSM303_OUT_Z_L_A         0x2C
#define LSM303_OUT_Z_H_A         0x2D
#define LSM303_FIFO_CTRL_REG_A   0x2E // DLHC only
#define LSM303_FIFO_SRC_REG_A    0x2F // DLHC only
#define LSM303_INT1_CFG_A        0x30
#define LSM303_INT1_SRC_A        0x31
#define LSM303_INT1_THS_A        0x32
#define LSM303_INT1_DURATION_A   0x33
#define LSM303_INT2_CFG_A        0x34
#define LSM303_INT2_SRC_A        0x35
#define LSM303_INT2_THS_A        0x36
#define LSM303_INT2_DURATION_A   0x37
#define LSM303_CLICK_CFG_A       0x38 // DLHC only
#define LSM303_CLICK_SRC_A       0x39 // DLHC only
#define LSM303_CLICK_THS_A       0x3A // DLHC only
#define LSM303_TIME_LIMIT_A      0x3B // DLHC only
#define LSM303_TIME_LATENCY_A    0x3C // DLHC only
#define LSM303_TIME_WINDOW_A     0x3D // DLHC only
#define LSM303_CRA_REG_M         0x00
#define LSM303_CRB_REG_M         0x01
#define LSM303_MR_REG_M          0x02
#define LSM303_OUT_X_H_M         0x03
#define LSM303_OUT_X_L_M         0x04
#define LSM303_OUT_Y_H_M         -1   // The addresses of the Y and Z magnetometer output registers
#define LSM303_OUT_Y_L_M         -2   // are reversed on the DLM and DLHC relative to the DLH.
#define LSM303_OUT_Z_H_M         -3   // These four defines have dummy values so the library can
#define LSM303_OUT_Z_L_M         -4   // determine the correct address based on the device type.
#define LSM303_SR_REG_M          0x09
#define LSM303_IRA_REG_M         0x0A
#define LSM303_IRB_REG_M         0x0B
#define LSM303_IRC_REG_M         0x0C
#define LSM303_WHO_AM_I_M        0x0F // DLM only
#define LSM303_TEMP_OUT_H_M      0x31 // DLHC only
#define LSM303_TEMP_OUT_L_M      0x32 // DLHC only
#define LSM303DLH_OUT_Y_H_M      0x05
#define LSM303DLH_OUT_Y_L_M      0x06
#define LSM303DLH_OUT_Z_H_M      0x07
#define LSM303DLH_OUT_Z_L_M      0x08
#define LSM303DLM_OUT_Z_H_M      0x05
#define LSM303DLM_OUT_Z_L_M      0x06
#define LSM303DLM_OUT_Y_H_M      0x07
#define LSM303DLM_OUT_Y_L_M      0x08
#define LSM303DLHC_OUT_Z_H_M     0x05
#define LSM303DLHC_OUT_Z_L_M     0x06
#define LSM303DLHC_OUT_Y_H_M     0x07
#define LSM303DLHC_OUT_Y_L_M     0x08
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
Page 1 of 3
