ekocakaya
Font for GLCD |
Posted: Mon Apr 22, 2013 4:18 am |
Hello friend,
for my 240x128 GLCD,
I need new fonts , big fonts , like 10x15 or 11x13,
anybody have code for it or an example, there is no sample for this font
everybody says use GLCD font creator but it is not suitable for CCS
waiting your helps |
Joined: 01 Jul 2010 Posts: 9519 Location: Greensville,Ontario
Posted: Mon Apr 22, 2013 5:01 am |
you should tell us which GLCD module you're using.
have you googled' your GLCD font creator' or similar query?
hth
jay |
Posted: Mon Apr 22, 2013 5:12 am |
The data tables it produces can be used with any compiler, with a bit of tweaking.
What _you_ have to do, is create your own output function to support the larger font. The example CCS supplied function (if that is the library you are using), shows exactly what you need to do. Loop through the byte patterns, and set bits if they are set in the data table. Obviously you have to switch to 16bit entries to give detailed fonts at the larger sizes..
You are aware that the standard CCS function allows you to use 2*, 3* etc., character sizes 10*14, 15*21 etc.?.
ekocakaya
hello |
Posted: Wed Apr 24, 2013 4:07 am |
My GLCD is 240x128 Winstar 240128B Model.
Yes I switched to the 16bit try some examples.
With using MikroC GLCD Font Creater program,
I can't figure its table to my CCS, anybody can you give me idea? |
ezflyr
Posted: Wed Apr 24, 2013 6:48 am |
As Ttelmah says, 'data-is-data', so the GLCD Font Creator program will work fine to generate font data for the CCS compiler. The output format is slightly different, but it's a minor tweak of the output to make it 100% compatible with the compiler.
I did a GLCD clock a while ago, so I used that program to create a large format font in the size of 14 x 21 pixels. I created characters for '0' to '9', a ':', a Space, and a '/'. If you want me to share the font data, just let me know. Of course, you'll also have to create a subroutine to display the new font data, but it's just a (fairly) trivial modification to the existing 5 x 7 routines supplied by CCS.
John |
Markdem
Posted: Thu Apr 25, 2013 5:59 am |
You can use my function with the output from the mikroC font creator.
You want to use the “Export for TFT and new GLCD” option.
You will need to remove the colour part out for your LCD. I will let you work that out.
void glcd_text(unsigned int16 x_origin, unsigned int16 y_origin, char* textptr, unsigned int16 fgcolour, unsigned int16 bgcolour)
unsigned int16 info_offset;
int chr_width;
int chr_bytes;
unsigned int16 chr_hight;
unsigned int16 chr_offset;
int i,j,k;
unsigned int16 x,y;
chr_hight = font[6]; //the hight is always stored in the 6th bit
while(*textptr != '\0')
if(*textptr == ' ') //found a space, we will just insert a few lines
x_origin = x_origin + 5; //move to the next chr position
info_offset = (((unsigned int16)*textptr - 33) * 4) + 8; //work out how far into the font array is the info about the current chr skipping the fist 8 byts in the table
chr_width = font[info_offset]; //the first byte contanes the width information, this is only how wide the chr is without padding
chr_offset = make16(font[info_offset+2], font[info_offset+1]); //The next two bytes contane the offset in the table to the bitmap of the chr
chr_bytes = chr_width / 8; //work our how many bytes wide the char is
if (chr_width % 8)
chr_bytes++;
x = x_origin; //save the start x position
y = y_origin; //save the start y position
for(i=0;i<chr_hight;i++) //loop thought vertical bytes
for(j=0;j<chr_bytes;j++) //loop thought horizontal bytes
for(k=0;k<8;k++) //loop though each bit
if(bit_test(font[chr_offset],k))
glcd_pixel(x,y,fgcolour); //bit is set, make the pixel the text colour
glcd_pixel(x,y,bgcolour); //bit is not set, make it the background colour
x++; //move to the next vertical line
chr_offset++; //move to the next byte
x = x_origin; //move the x origin to start drawing the next horizontal bytes
y++; //move down to the next row
x_origin = x_origin + chr_width + 1; //move to the next chr position
textptr++; //move to next char in string
