string pointer question
koenbielen
PostPosted: Fri Mar 29, 2013 6:50 am     Reply with quote
void printdatatoserialport( char *str)
void main (void)
printdatatoserialport("HELLO WORLD");
printdatatoserialport("Line 2");
printdatatoserialport("BYBY");
fprintf(NETWERK,str);
Error 90 "test.c" Line 2476(35,36): Attempt to create a pointer to a constant
is there a way to solve this problem?
Mike Walne
PostPosted: Fri Mar 29, 2013 8:22 am     Reply with quote
Try this link.
http://www.ccsinfo.com/forum/viewtopic.php?t=48456&start=
It might either help or explain.
Mike
PostPosted: Fri Mar 29, 2013 8:41 am     Reply with quote
Easiest one for what he wants is just:
#device PASS_STRINGS=IN_RAM
Add this to your code immediately after the processor define file is loaded. This will tell the compiler to generate a 'RAM buffer' for const strings, and automatically transfer them using this (which then allows pointers to be constructed).
The thread Mike points to and it's links will explain 'why'.
