Problem with string copy function (strcpy)
tienchuan
PostPosted: Wed Mar 27, 2013 7:05 pm     Reply with quote
Hi all.
I have a problem when using strcpy to copy one string to another string.
In my project used :
-- CCS C PCH ver 4.140
-- Pic18LF4680
And here is my code:
0. setup fuses, init variables
#include <18LF4680.h>
#include <def_18f4680.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
#device *=16 ADC=10
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#priority rda,timer0,timer1
#use fast_io (B)
#use fast_io (D)
#include <LCD_TM.c>
#include <font.c>
#include <matrix_control.c>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
unsigned int8 str_rs232[16]="";
unsigned int8 str_mod[16]="";
unsigned int8 str_pla[16]="";
unsigned int1 flag_rs232=0;
1. Interrupt rda code:
#int_rda
void ngat_rs232()
   char c;
   c=getc();
      switch(c)
         case '$':
               index=0;
         case '*':
               if((str_rs232[0]=='M')&&(str_rs232[1]=='O')&&(str_rs232[2]=='D'))
                  index=0;
                  flag_mod=1;
         case '#':
               if((flag_mod==1)&&(index==16))
                  flag_mod=0;
                  index=0;
                  flag_rs232_ok=1;
         default:
               str_rs232[index]=c;
               index++;
      }  // end of switch
}        // end of int_rda
2. And main program:
   trisb=0;
   trisd=0;
   trisc=0x80;
   trise=0;
   trisa=0;
   enable_interrupts(int_rda);
   //enable_interrupts(int_timer0);
   //enable_interrupts(int_timer1);
   enable_interrupts(global);
   //setup_timer_0 (RTCC_DIV_256| RTCC_INTERNAL);
   //set_timer0(200);
   //setup_timer_1 (T1_DIV_BY_8| T1_INTERNAL);
   //set_timer1(3035);
   //buffer_full=0;
   printf("*******************************************************\n\r");
   printf("* Nhap chuoi ki tu\ so can hien thi                   *\n\r");
   printf("* Bat dau chuoi bang ki tu : *                        *\n\r");
   printf("* Ket thuc chuoi bang ki tu : Enter                   *\n\r");
        if(flag_rs232)
              strcpy(str_mod,str_rs232);
              printf("%s",str_mod);
              flag_rs232=0;
   } // end of while
}     // end of main
My problem is in copy "str_rs232" string to "str_mod" string is errors.
If i do follow after , that is right:
        if(flag_rs232)
              //strcpy(str_mod,str_rs232);
              printf("%s",str_rs232);
              flag_rs232=0;
Pls show me errors in my code and show me a way to fix it.
thanks all.
Regards.
p/s: my code was shorted, only extract some necessary for my problem Smile
Begin Begin Begin !!!
FvM
PostPosted: Thu Mar 28, 2013 12:26 am     Reply with quote
The interrupt function doesn't build correct strings because it misses to write a delimiting null character. It also might write beyond the string limits.
The usual solution is to write received data to a circular buffer and do all further processing on the main level.
