khaledki7
Can't make pwm |
Posted: Tue Mar 12, 2013 1:56 pm |
#include <18F452.h>
#use delay(clock=25000000)
#INT_TIMER1 // This function is called every time
void clock_isr() { // timer 1 overflows (65535->0), which is
output_toggle(PIN_B3);
void main() {
setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
set_timer1(0);
// output_high(PIN_B3);
while(TRUE);
Mike Walne
Posted: Tue Mar 12, 2013 5:46 pm |
I don't understand the question.
Are you wanting to:-
1) Create a PWM output using timer1?
OR
2) Create a PWM output using the built in hardware version?
Mike |
Posted: Tue Mar 12, 2013 7:49 pm |
PWM=Pulse Width Modulation.
Code: | output_toggle(PIN_B3);
Gives an approximate square wave with fixed 50% duty,
with no way to actually MODULATE it in your program.
At best it is a jittery square wave generator and nothing more. |
Posted: Tue Mar 12, 2013 11:09 pm |
I tested your program in hardware, with CCS compiler vs. 4.141. I don't
have a 25 MHz external oscillator, so I used a 20 MHz crystal. It works.
I see a squarewave signal on Pin B3, with a frequency of about 9.5 Hz.
The signal goes from 0v to 5v. I can see it on my oscilloscope. |
khaledki7
Posted: Wed Mar 13, 2013 1:39 am |
hi I want to make a 50HZ pulse but I can't make it
pleas help and thanks for reply |
khaledki7
Posted: Wed Mar 13, 2013 6:19 am |
hi thanks for your help and i make this code but the servo didn't work. Any answers?
#include <18F452.H>
#device adc=8
#define LEFT_SERVO_PIN PIN_B0
#define RIGHT_SERVO_PIN PIN_B1
//#define LONG_TIME 0.0150 // Longest pulse width high time
#include <servos.c>
int j;
j=0;
init_servos();
//for (j=0;j<=4;++j)
// set_servo(LEFT, FORWARD, j); // Go forward
// delay_ms(2000);
// set_servo(LEFT, BACKWARD, 3); // Go reverse
set_servo(LEFT, FORWARD, 4);
Mike Walne
Posted: Wed Mar 13, 2013 7:57 am |
Quote: | hi thanks for your help and i make this code but the servo didn't work. | What does not work?
In no particular order:-
1) Do you know that your servo is good?
2) Are there pulses appearing from the PIC pins?
3) Have you got servos which are compatible with the CCS servo drivers?
4) Have you checked, and double checked, your wiring?
5) Have you checked for accidental S/C and O/C?
6) Will your PIC run LED flasher code at the correct speed?
Mike |
Joined: 01 Jul 2010 Posts: 9503 Location: Greensville,Ontario
Posted: Wed Mar 13, 2013 8:08 am |
S/C = Short Circuit
O/C = Open Circuit
just in case anyone else is scratching their heads.....
jay |
Mike Walne
Posted: Wed Mar 13, 2013 9:12 am |
When you get as many S/Cs and O/Cs as I do, it's a pain to write out in full every time.
Mike |
Posted: Wed Mar 13, 2013 2:18 pm |
Don't call set_servo() continuously in a high-speed while() loop.
Just call it once, and it will work. See the example below:
#include <18F452.H>
#use delay(clock=4M)
#include <servos.c>
init_servos();
