IceMetal
Joined: 20 Nov 2008 Posts: 79 Location: white Plains, NY
| getch question |
Posted: Tue Mar 12, 2013 5:05 pm |
I have a dc motor and I want to add a pot as a feedback. The problem is the pot has set values from 0-255. How can I type them, it seems when I press 1, 49 shows up and when I press 2, 50 appears and so on.
| Code: | #include <16F88.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP, INTRC_IO
//#fuses HS, NOWDT, NOPROTECT, BROWNOUT, NOLVP
#use delay (clock=4000000)
#use rs232(baud=9600,rcv=PIN_B2, xmit=PIN_B5)
int16 data;
char value;
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_8);
printf("Please Set Value\r\n");
while(true)
set_adc_channel(0);
delay_us(10);
data=read_adc();
if(kbhit())
value=getch();
printf("it would stop at %u\r\n", value);
if(data>=value){
printf("the data is %lu\r\n", data);
delay_ms(200);
Mike Walne
Posted: Tue Mar 12, 2013 5:21 pm |
The ASCII value for '0' is 0x30 or 48 in decimal.
The ASCII value for '1' is 0x31 or 49 in decimal.
The ASCII value for '2' is 0x32 or 50 in decimal etc.
Does this answer your question?
Mike
EDIT
I think you may need to collect several characters followed by <ENTER>, then do a conversion.
OR convert on the fly, till you get <ENTER>. |
IceMetal
Posted: Tue Mar 12, 2013 5:24 pm |
| Mike Walne wrote: | The ASCII value for '0' is 0x30 or 48 in decimal.
Mike
EDIT
thanks but that was not the question the question is how can I type 1 and 1 would show up. |
Mike Walne
Posted: Tue Mar 12, 2013 5:41 pm |
I answered your question.
Subtract 48 from the ASCII value and you convert from ASCII to decimal!!
Mike |
IceMetal
Posted: Tue Mar 12, 2013 5:46 pm |
still I can not type 100 or 50, that does not work :( is there a way to type those numbers
if you are already angry you can ignore this post you dont have to answer |
Mike Walne
Posted: Tue Mar 12, 2013 6:00 pm |
No. I'm not angry, yet.
I also gave you 2 ways of how to deal with multiple digits.
This is NOT the ONLY way:-
1) Declare a variable say New_input which you set to zero.
2) When 1st character arrives convert to decimal.
3) Make New_input equal to decimal equivalent of 1st character.
4) Wait for next_character.
5) If next character is <ENTER> you exit.
6) Multiply New_input by 10.
7) Add decimal value of next_character to New_input.
8) Loop back to 4.
Mike
Edit you may have to filter out non-decimal characters etc.
CCS examples also show you ways to do same task.
There are built in 'C' functions to convert ASCII strings.
It's gone mid-night here, so I'm done for now. |
Joined: 01 Jul 2010 Posts: 9587 Location: Greensville,Ontario
Posted: Tue Mar 12, 2013 7:17 pm |
getch() only 'gets' one character at a time....
so like Mike says you have to loop to 'get' 3 characters to get 100.
but...
need to trap out if <100.
You can set a trap for the <cr>....
Yup..kinda complicated but....
always a but...
if you look over the examples in the EXAMPLES folder, you'll find an example that CCS supplies !!!
as well
learn to use the search engine here(or google using site:) and you'll find a few code snippets that others have created,located either in this forum or the code library.
All this is based that you're sending data to the PIC from a PC terminal program and that you're pressing the number keys..... |
IceMetal
Posted: Tue Mar 12, 2013 11:14 pm |
| I will try to figure out since no one is helping, people seems they love to rant here. |
Posted: Wed Mar 13, 2013 1:33 am |
We are suffering from a lot of posts where people want "answer's on a plate".
This is not a "teach you really basic programming" forum, it is meant to be to answer specific CCS problems.
Your question has nothing specifically CCS about it. It really is "nursery school" programming....
Two answers have already been posted. Last line of Mike's original post, then in detail in his later post.
He _has_ posted how to do it. Read, understand, try.
As a comment, you could actually learn this part much faster with a simple C on a PC. Type numbers, watch what their values are, understand how to handle multiple digits etc.. With an environment like this you in most cases would have the ability to 'watch' numbers as they come in, and see how the value needs to be converted, and built up to form the result. A much quicker learning tool than using the PIC to start. Once you are confident in some basic programming skills, then try the PIC.
Big problem, is that programming at a certain 'level' is a bit like trying to ride a bicycle you have to actually do it.
twidget
Joined: 21 Feb 2013 Posts: 32 Location: Orange County, California
Posted: Wed Mar 13, 2013 1:46 am |
And you thought I was rude.
What they are telling you is that you can’t just return the “number” you enter via RS232. RS232 returns what’s called an ASCII value. ASCII (American Standard Code) was developed from telegraphic codes. When sending messages, data (numbers, letters, etc) is transmitted in bit format (1’s and 0’s).
You would think that a ‘1’ entered via RS232 would return the number ‘1’ but in fact it returns the number “49”.
Why? Well, ASCII handles everything from numbers, letters, and “non-printing” control. It does this by way of a 7 bit look-up table (128 possible values). Each address from 0000000 – 1111111 is either a number, letter, or “non-printing” control. For example:
The number 6 is located at the 110110 address of the look-up table, values for the number 6 can be in any of the below form.
Binary Decimal Hexadecimal Octal
0110110 54 36 66 |
An easy way to ‘decode’ ASCII, when you’re only dealing with single digit numbers, is to subtract 48. That is because the number 48 in ASCII is 0.
If your trying to decode more than one digit, you have to decode one digit at a time.
I honestly don’t think anyone is going to help you after your last post, but fortunately you have a somewhat easy problem to solve. I spotted three examples fairly quickly just searching ASCII Decoding. |
Posted: Wed Mar 13, 2013 1:47 am |
If you're willing to type the value into the terminal program using hex
notation (00 to FF, instead of to 255), then here's a quick demo program:
#include <18F452.h>
#use delay(clock=20M)
#include <input.c>
int8 value;
value = gethex();
printf("\n\r");
printf("value = %x \n\r", value);
Here is a typical output of this program. If I type "12" into the terminal
window, the gethex() function echoes the numbers back to the terminal
so they are displayed on the first line. Then my program displays the
value that was received from gethex() with printf in the 2nd line.
Then I also typed in "77" and "FF" and got those back correctly as well.
| Code: | 12
value = 12
77
value = 77
ff
value = ff |
Mike Walne
Posted: Wed Mar 13, 2013 4:37 am |
| IceMetal wrote: | | I will try to figure out since no one is helping, people seems they love to rant here. |
A forum search shows you've been playing with PICs over four years, and asked questions on different topics.
You should, by now, know how it works here.
I was expecting the level of answers I gave to be more than adequate.
As another poster says "its kindergarten stuff".
My intention IS that you figure it out for yourself, with guidance.
I'm trying to help you learn, like I did a long time ago, the hard way.
I don't get angry, I just give up.
Bye.
Mike |
