aruna1
Strange issue with if statement |
Posted: Mon Dec 26, 2011 8:19 am |
Hi
I'm working on a battery charger circuit based on 12F683. I have encountered a strange issue. My compiler version is 4.084.
Problem is in the function charge_end().
Program is written such that at 2290 interrupt of timer 1, it will call charge_end() function. Then it evaluvate some if statements to check whther charge terminations are met.
Problem is that first if condition is not get evaluated. Code simply assume first if condition is true and then executes the statements under it.
I have checked value of k with print f function, even though calculated k is negative (ex. k= -2095), if statement becomes true.
That is it says -2095 > 200 is true!
int16 k=0;
k=(temp_mov_avg-prev_values[1]);
if(k>200)//dT/dt cutoff
printf("DT %Ld \r\n",k);
disable_interrupts (GLOBAL) ;
If statement become true no matter what is the k value is.
My project folder can be downloaded from following link
http://www.mediafire.com/?dqg3cbadu7ytr4z
Can someone point me the error?
Here is the code:
//#include "E:\My Electronic projects\usb charger\code\pwm2analog\pwm2analog.h"
#include <12F683.h>
#device adc=10
#FUSES NOMCLR //Master Clear pin used FOR I/O
#FUSES IESO //Internal External SWITCH Over mode enabled
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A0,bits=8)
void read_voltage();
void read_temperature();
void charge_end();
void init();
unsigned int16 loop_count=0;
int16 volt_mov_avg=0;
int16 temp_mov_avg=0;
int ac_count=0;
int16 prev_values[2]={0};
unsigned int16 volt_read[10]={0};
unsigned int16 temp_read[10]={0};
int16 initial_temp=0;
float temp=0;
#INT_TIMER1
void TIMER1_isr(VOID)
loop_count++;
if(loop_count%6==0)
ac_count++;
read_voltage();
read_temperature();
//printf("%.3f %.3f %Lu\r\n",volt_mov_avg,temp_mov_avg,loop_count);
//printf("%Ld %Ld %Ld %.3f \r\n",volt_mov_avg,temp_mov_avg,loop_count,temp);
printf(" %Ld %Ld\r\n",temp_mov_avg,prev_values[1]);
if(loop_count%2290==0)
if(loop_count>=230)
charge_end();
void charge_end()
int16 k=0;
else if(((prev_values[0]-volt_mov_avg)>=15)&&(volt_mov_avg>3100)) // -dV cutoff
//printf("-dV \r\n");
else if(temp_mov_avg-initial_temp>15)//dT cutoff
else if(temp_mov_avg>4500)// peak T cutoff
else if(loop_count>34351)// timer cutoff - 2.5h
prev_values[0]=volt_mov_avg;
prev_values[1]=temp_mov_avg;
void read_voltage()
int i=0;
//float temp=0;
set_adc_channel (3) ;
delay_us (10) ;
if(loop_count>=73)
for(i=1;i<10;i++)
volt_read[i-1]=volt_read[i];
volt_read[9]=read_adc();
while(!adc_done())
//printf("start\r\n");
//printf("%Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld %Ld\r\n\n",volt_read[0],volt_read[1],volt_read[2],volt_read[3],volt_read[4],volt_read[5],volt_read[6],volt_read[7],volt_read[8],volt_read[9],volt_read[10],volt_read[11],volt_read[12],volt_read[13],volt_read[14]);
volt_read[ac_count-1]=read_adc();
while(!adc_done())
for(i=0;i<9;i++)
temp=temp+volt_read[i];
//volt_mov_avg=(3.275*temp)/14336;
temp=temp*0.31933;
volt_mov_avg=(int16)temp;
volt_mov_avg=volt_mov_avg+10;
if(volt_mov_avg>prev_values[0])
temp=0.0;
int i=0;
//float temp=0;
set_adc_channel (1) ;
delay_us (10) ;
if(loop_count>=73)
for(i=1;i<10;i++)
temp_read[i-1]=temp_read[i];
temp_read[9]=read_adc();
while(!adc_done())
temp_read[(loop_count/3)-1]=read_adc();
while(!adc_done())
for(i=0;i<10;i++)
temp=temp+temp_read[i];
//temp_mov_avg=(327.5*temp)/14336;
temp=temp*3.1933;
temp_mov_avg=(int16)temp;
temp_mov_avg=temp_mov_avg+30;
temp=0.0;
void init()
int i=0;
for(i=1;i<11;i++)
volt_read[i-1]=0;
temp_read[i-1]=0;
delay_ms (2000) ;
delay_us (10) ;
initial_temp=read_adc();
temp=initial_temp*319.3359;
initial_temp=(int16)temp;
temp=0.0;
prev_values[1]=6000;
enable_interrupts (INT_TIMER1) ;
enable_interrupts (GLOBAL) ;
set_timer1(0);
setup_adc_ports (sAN0|VSS_VDD) ;
setup_adc (ADC_CLOCK_INTERNAL) ;
setup_timer_0 (RTCC_INTERNAL|RTCC_DIV_1) ;
setup_timer_1 (T1_INTERNAL|T1_DIV_BY_8); //overflow 262ms
setup_timer_2(T2_DIV_BY_1,9, 1);// 200kHz
setup_ccp1 (CCP_PWM) ;
set_pwm1_duty(37L);
setup_comparator (NC_NC) ;
setup_vref (FALSE) ;
setup_adc_ports (sAN1|sAN3|VSS_VDD) ;
init();
WHILE (1)
Posted: Mon Dec 26, 2011 9:22 am |
k cannot be negative.
You have it declared as int16. Needs to be declared as _signed int16_.
You are outputting it with &ld, which is for a signed number, but the number itself is treated as unsigned. So what displays as -2095, is actually F7D1 (in hex), which is 63441 in an unsigned number, and 63441, _is_ greater than 200.....
You need to be careful in switching types. If you are using %d, which expects a signed number, then you need to be giving it a signed number.
aruna1
Posted: Mon Dec 26, 2011 9:31 am |
aha
That means I should declare all variables by signed or unsigned ? Right?
Thanks. |
Posted: Mon Dec 26, 2011 9:41 am |
Values default to unsigned.
For everything you want to be treated as signed, (and that includes where you are doing arithmetic that can end up with a -ve result), then 'yes' they need to be declared as signed.
aruna1
Posted: Mon Dec 26, 2011 10:10 am |
it worked
many thanks  |
proweld
