How to generate pwm signal on the pin c5 ?
mahdifahime
PostPosted: Sun Jan 06, 2013 12:58 pm     Reply with quote
I want to generate pwm signal on the pin C5 but I can't. Crying or Very sad
Please help me.
#include <16F72.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=14000000)
void main(){
int data;
delay_ms(50);
setup_timer_2(T2_DIV_BY_1,254,1);
setup_ccp1(ccp_pwm);
while(1){
   data=data+5;
   if(data==255){data=0;}
   delay_ms(50);
   set_pwm1_duty(data);
Version: 4.128
PostPosted: Sun Jan 06, 2013 1:52 pm     Reply with quote
hmmm..according to my PIC16F72 datasheet, the CCP1 pin is RC2 NOT RC5....
mahdifahime
PostPosted: Sun Jan 06, 2013 2:11 pm     Reply with quote
I understand that the CCP1 pin is RC2 but I want to use RC5 instead of RC2
PostPosted: Sun Jan 06, 2013 2:42 pm     Reply with quote
In that case ,you'll have to write your own PWM code.
Details you'll have to work out are frequency (Hz...KHz), resolution(# of bits) and range (0%-100% PWM).
I'm pretty sure CCS does supply an example in the 'examples' folder of the compiler.
Simplest software PWM doesn't use an ISR which means nothing else can be done. Using an ISR allows for 'multitasking'. Choice is yours.
hth
jay
mahdifahime
PostPosted: Sun Jan 06, 2013 3:03 pm     Reply with quote
But i saw that generate pwm on portb or portc or porta. How to generate!!!!!??????
Even in language basic can generate pwm on port sightly
PostPosted: Sun Jan 06, 2013 3:27 pm     Reply with quote
You cannot, on this chip.
Many of the later chips with things like the ECCP module, support 'pulse steering', allowing you to route the CCP signal to specific other pins, but the 16F72, _only_ supports one hardware PWM output, on pin C2.
As others have said, you can (at a much lower frequency) perform software PWM on any pin. There is an example for servo control in the code library, but all will involve a lot of processor time.
You have read something incorrect, or incorrectly.
mahdifahime
PostPosted: Sun Jan 06, 2013 11:14 pm     Reply with quote
It mean I can't do it?
PostPosted: Sun Jan 06, 2013 11:34 pm     Reply with quote
Use software PWM on pin C5. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=37807&start=3
