Average ADC result
sahu77
Average ADC result
PostPosted: Wed Jan 02, 2013 9:31 am     Reply with quote
how can read Average ADC result with high value & low value ?
sahu
PostPosted: Wed Jan 02, 2013 10:12 am     Reply with quote
hmm..
a rather 'generic' question..
no PIC type, compiler version ,ADC peripheral......
..making it hard to guess what you mean.
however...
simply put..
(high value + low value) /2
will give the average of those two numbers.
but...
do you have 8 bit ADC result, 10 bit, 12 bit, 32 bit.....?????
do you want integer result, floating point, int16 ????
You really need to supply more information as there are lots of correct answers to the question.
hth
jay
sahu77
PostPosted: Wed Jan 02, 2013 10:23 am     Reply with quote
temtronic wrote:
hmm..
however...
simply put..
but...
hth
jay
16f676
compiler version V4.057
i have 8 bit ADC result, 10 bit,
i want int16 or int32
sahu
Gabriel
PostPosted: Wed Jan 02, 2013 10:47 am     Reply with quote
you understand that you wont be getting 16 or 32 bit accuracy.
you can get close to 10 bit accuracy _formated_ in a 16/32 bit variable.
you cant produce 6 aditional bits of resolution by oversampling...
just FYI...
Edit: you can look at the LM35 driver i posted to get _an idea_ of how to do an average of ADC samples with Highest and lowest values...
if you read multiple samples do it in powers of 2 so that when you divide its faster..2,4,8,16 etc...
G
CCS PCM 5.078 & CCS PCH 5.093
Gabriel
PostPosted: Wed Jan 02, 2013 10:54 am     Reply with quote
   counter=0;                           // clear counter
   lowest=0xFFFF;                        // reset lowest
   highest=0;                           // reset highest
   while(counter<18)                     // Take 18 readings and average (16+highest+lowest)
      temporary=READ_ADC();               // take an ADC reading
        if(temporary<lowest)               // check if smaller than lowest
           lowest=temporary;               // save value if smaller
          if(temporary>highest)               // check if larger than highest
            highest=temporary;               // save value if larger
      temperature+=temporary;               // add the ADC values for averaging (Vout on LM35)
      counter++;
   temperature-=highest;                  // remove highest value
   temperature-=lowest;                  // remove lowest value
   temperature/=16;
that should put you on your way...
G.
gpsmikey
PostPosted: Wed Jan 02, 2013 6:18 pm     Reply with quote
You probably should also put provisions in there for clearing the "highest" and "lowest" values when you want. If nothing else, often strange readings get recorded when you power up/come out of reset. You are also going to need to make sure you have filtering on the sensor (at least a low pass) to help avoid strange noises from giving false high or low readings that then get logged in your limits variables.
mikey
mikey
Gabriel
PostPosted: Thu Jan 03, 2013 6:45 am     Reply with quote
Highest and Lowest get Reset before every Averaged reading:
so after each time you execute the code i posted, you should have a fresh value for high and low...
unless you mean somthing else and i didnt get it... which happens often.
... the code as posted also removed the highest and the lowest from the average, its an "olympic average"... which should provide some filtering...
however I agree, some external filtering depending on the application is generaly a good idea.
G.
sahu77
PostPosted: Thu Jan 03, 2013 9:24 am     Reply with quote
      counter++;
   temperature/=16;
G.
its right way reading 2 adc channel AN0 & AN1 ??
as u say !
  Function getchreading
  Calculate minivolts on selected channel
int16 getchreading(int channel)
   SETUP_ADC_PORTS(sAN0|sAN1);               // Select Analog channels on PIC
    SETUP_ADC(ADC_CLOCK_DIV_8);            // Select ADC conversion Clock
    delay_ms(40);                        // give some time for charge capicitor to stabilize
    int counter=0;                        // temporary counter
    signed int16 temperature=0;           // temporary adc_value variable
    int16 highest=0;                     // saves highest reading for filtering
    int16 lowest=0xFFFF;                 // saves lowest reading for filtering
    int16 temporary=0;
        int32 temp_result, adc_value, tlong;;
        set_adc_channel(channel); // Select Channel
        // Average ADC value
   delay_us(15);                        // small delay to settle
       temp_result-=temporary;               // substract the ADC values for averaging (adc i\p)
       counter++;
    temp_result+=highest;                  // remove highest value
    temp_result+=lowest;                  // remove lowest value
    temp_result/=16;                     // average by 16
        adc_value = temp_result
        tlong = (int32)ADC_value*5000; //Convert the result in millivolts
        tlong = tlong/1023; // 0..1023 -> 0-5000mV
   SETUP_ADC(ADC_OFF);                     // turn off ADC module
        return (int32) tlong;
  Function ProcessMains
  Reads Form AN0 ADC_Value and Reads Form AN1 ADC_Value
int ProcessMains(void)
   ch_0 = getchreading(0);
   ch_1 = getchreading(1);
.here do somthing ch_0 & ch_1
sahu
Gabriel
PostPosted: Thu Jan 03, 2013 9:58 am     Reply with quote
      temp_result-=temporary;               // subtract the ADC values for averaging (adc i\p)
check the function i posted (its even in your reply)... your math is inverted.
you probably haven't compiled this yet, or printed the results to terminal..
is it ADC_value or adc_value?
be consistent...
    int16 temporary=0;
Where do you use "temperature"?
    delay_ms(40);                        // give some time for charge capacitor to stabilize
are you sure that your ADC clock is correct for your chip+crystal combination?
read the Datasheet: TAD
you could simply do
temp_result*=5000; //Convert the result in millivolts
temp_result/=1023;
its already a 32bit var according to your declaration...
Compile, and TEST... print partial results to screen at different steps of the function... don't expect to get the right answer after you wrote a long function...
G.
PostPosted: Thu Jan 03, 2013 10:05 am     Reply with quote
As one other comment, the 'temp_result', is the sum of 16 readings after the highest and lowest have been removed. If you are going to multiply by 5000, then don't!. Get rid of the division by 16, and multiply the sum by 625, and then divide by 2046. Only one division needed, and you keep more of the numeric accuracy. Smile
sahu77
PostPosted: Thu Jan 03, 2013 10:54 am     Reply with quote
you probably havent compiled this yet, or printed the results to terminal..
be consistent...
    int16 temporary=0;
Compile, and TEST... print partial results to screen at diferent steps of the function... dont expect to get the right answer after you wrote a long function...
G.
now correct ?
    signed int16 temp_result=0;           // temporary adc_value variable
    int16 temporary=0;
       counter++;
    temp_result-=highest;                  // remove highest value
    temp_result-=lowest;                  // remove lowest value
    temp_result/=1023;
        return (int32) temp_result;
i'm not sure that my ADC clock is correct for chip (16f676)+internal osc combination?
sahu
ezflyr
PostPosted: Thu Jan 03, 2013 11:49 am     Reply with quote
Hi Sahu,
I know this is a truly radical suggestion, but have you considered actually
reading the Microchip datasheet for this information??
I wonder what designers and programmers did before the invention of
internet forums?
John
bkamen
PostPosted: Thu Jan 03, 2013 12:11 pm     Reply with quote
ezflyr wrote:
Hi Sahu,
internet forums?
No kidding.
Although, a mentor of mine outside of school back in my high school days used to say how schools don't teach how to process thought. (only memorization)
So it's really not surprising to see this more first hand with the advent of the internet forum.
And it's worse now -- you don't need to really "know" anything.. you can just ask Siri.
-Ben
Gabriel
PostPosted: Thu Jan 03, 2013 12:14 pm     Reply with quote
    int16 temporary=0;
... well if you where actually trying to code and compile and test your work, you would notice the 2 repeated semicolons after tlong.
also you would notice that you have declared temp_result as:
AND
Still wrong... your removing 16 samples instead of ADDING 16 samples
*straps rocket back pack*
Nothing to do here.....
G.
