manual setting/clearing INTERRUPT BIT
danielz85
PostPosted: Wed Jan 02, 2013 7:48 am     Reply with quote
hi,
For timing accuracy, I wish to use TIMER2 interrupt flag in the main loop.
such that each time the interrupt is set, the mc performs some opertations, for instance print some value in this case...
However, it seems that the following simple code doesn't work. It prints non-stop the string even though it should roughly print it every second.
Can someone please tell me why?
#include <16F1783.h>
#bit  TIMER2IF=0x11.1
//#INCLUDE <stdlib.h>
#include "consts.c"
#fuses INTRC_IO, NOWDT, NOBROWNOUT, PUT,NOMCLR
#use delay(clock=1M)
#use rs232(baud=4800,xmit=pin_B7,rcv=pin_B6)
  setup_timer_2(T2_DIV_BY_64,200,16);
  while (TRUE)
   if (TIMER2IF==1)
      TIMER2IF==0;
      printf("abc");
asmallri
PostPosted: Wed Jan 02, 2013 7:54 am     Reply with quote
You have enabled a timer 2 interrupt but do not have a timer 2 interrupt handler. You are using polled mode to interrogate timer 2 status - this is valid. Simply remove the two interrupt enable lines.
Regards, Andrew
danielz85
PostPosted: Wed Jan 02, 2013 8:07 am     Reply with quote
problem solved
thanks asmallri
PostPosted: Wed Jan 02, 2013 8:16 am     Reply with quote
Use:
void main(void) {
   enable_interrupts(INT_TIMER2); //It is OK to enable this, but not
   //necessary. It _is_ needed if (for instance), you want this to wake
   //the chip
   //enable_interrupts(GLOBAL); //You must not enable this without
   //a handler
   while (TRUE) {
      if (interrupt_active(INT_TIMER2)) { //This tests the flag for you
         clear_interrupts(INT_TIMER2); //This clears the interrupt
         printf("abc");
The handler, is called, in the following situation:
Timer2 interrupt flag is set.
and Timer2 interrupt enable is set
and global interrupt enable is set.
If you do not have a handler present, you must ensure that all three of these do not happen. If they do, the code will call the non existent handler - crash......
Just leave the global flag off. You don't actually have to enable the individual interrupt for this test operation, but you _do_, if you want the interrupt to do other things (like wake the chip). Only 'enabled' interrupts will do this. Hence it is common practice to always enable any interrupt you are 'using'.
Mike Walne
PostPosted: Wed Jan 02, 2013 10:51 am     Reply with quote
  while (TRUE)
   if (TIMER2IF==1)
      TIMER2IF==0;
      printf("abc");
I would not expect the line preceeding your printf statement to have the effect of clearing the interrupt flag.
Hence the continuous printing.
Mike
