SFR bit setting
aroonkriss
SFR bit setting
PostPosted: Sun Dec 30, 2012 9:49 pm     Reply with quote
Hi all,
I need to set individual bits in SFRs. I tried the following code but it didn't work.
#byte U1MODE=getenv("SFR:U1MODE")
#byte U2MODE=getenv("SFR:U2MODE")
#use rs232(baud=9600,parity=N,xmit=PIN_C13,rcv=PIN_C14,bits=8,stream=UART1)
#use rs232(baud=2400,parity=N,xmit=PIN_F5,rcv=PIN_F4,bits=8,stream=UART2)
bit_set(U1MODE,10);  // to enable the alternate pins for uart1
bit_clear(U2MODE,15); // to disable the uart
I checked the uart2 part, it was communicating even though I disabled the enable bit.
I need to use the alternate pins of uart1. So I need to set the 'altio' bit of u1mode register.
PLEASE HELP ME. ANY HELP WOULD BE APPRECIATED.
I dream world peace
aroonkriss
SFR bit setting
PostPosted: Sun Dec 30, 2012 11:13 pm     Reply with quote
I used the following code and it worked.
#word U1MODE=0x20C
#word U2MODE=0x216
#bit  ALTIO = U1MODE.10
#bit  U2EN = U2MODE.15
#bit  U1EN = U1MODE.15
But I wish to know what was my mistake with the earlier code. Thanks in advance.
I dream world peace
PostPosted: Mon Dec 31, 2012 2:11 am     Reply with quote
Allows you to set a bit in a variable, but is _limited to the size of the variable_.
maps a _byte_ variable at the address - 8 bits
#word U1MODE=getenv("SFR:U1MODE")
maps a _word_ variable at the address - 16 bits
You can't access 'bit 10', in a byte sized variable.
If you code:
Then look at the assembler:
....................    bit_clear(U2MODE,15);  // to enable the alternate pins for uart1
No instruction is generated, since you are trying to access a bit beyond the end of the variable.
However code as:
#word U2MODE=getenv("SFR:U2MODE")
The assembler is then:
....................    bit_clear(U2MODE,15); // to disable the uart
0130:  BCLR.B  217.7
Which is accessing the seventh bit in the byte after 'U2MODE'.
As a more 'elegant' route, why not use the compiler's knowledge of bits:
#bit UART_ALTIO=getenv("BIT:ALTIO")
#bit UART2_ENABLE=getenv("BIT:U2MODE.UARTEN")
   UART_ALTIO=TRUE;
   UART2_ENABLE=FALSE;
Or use the compiler's ability to handle this for you:
#use rs232(baud=9600,parity=N,UART1A,bits=8,stream=UART1)
//select UART1 on alternate pins (1A)
    setup_uart(FALSE,UART2); //turn off UART2
