blueseasd
| 18f87j50 usb problem (serial example) - Solved |
Posted: Mon Oct 15, 2012 4:37 pm |
I am using PIC18F87J50 USB demo board, MPLAB IDE 8.50 editor and Ccsc.exe (4.3.0.337) compiler, and created a USB project based on PICC Examples ex_usb_serial.c. The PIC works from the beginning by blinking LED0, but my PC did not recognize the USB.
I defined OSCILLATOR_FREQUENCY as 48000000, and I tried #FUSES PLL in different value but I believe it should be PLL3.
Anyone can tell me what I did is wrong? And could you please post a simple workable USB code for 18F87J50?
Thank you very much.
//******* My code ************************
#ignore_warnings none
#include <18F87J50.h>
#define OSCILLATOR_FREQUENCY 48000000
#FUSES NOXINST
#FUSES MSSPMSK7
#FUSES NOCPUDIV
#FUSES PLL3 //PLL PreScaler
#FUSES HS
#FUSES HSPLL
#use delay(clock=OSCILLATOR_FREQUENCY)
#use rs232(baud=9600,parity=N,xmit=PIN_C6, rcv=PIN_C7, bits=8,STREAM=DEBUG232,errors)
#define USB_CON_SENSE_PIN PIN_B5
#define LED1 PIN_E1
#define LED2 PIN_E0
#define LED3 PIN_E2
#DEFINE BUTTON PIN_B4
#define LED_ON output_low
#define LED_OFF output_high
#define LED0 PIN_E0
#define LED1 PIN_E1
#define BUTTON_PRESSED() FALSE //no push button on this hardware
#include "ex_usb_common.h"
#include <usb_cdc.h>
#include <stdio.h>
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states. Also lights LED1 based upon
// enumeration and status.
void usb_debug_task(void)
static int8 last_connected;
static int8 last_enumerated;
int8 new_connected;
int8 new_enumerated;
static int8 last_cdc;
int8 new_cdc;
new_connected=usb_attached();
new_enumerated=usb_enumerated();
new_cdc=usb_cdc_connected();
if (new_enumerated)
LED_ON(LED1);
LED_OFF(LED1);
if (new_cdc)
LED_ON(LED2);
LED_OFF(LED2);
if (usb_cdc_carrier.dte_present)
LED_ON(LED3);
LED_OFF(LED3);
if (new_connected && !last_connected)
uart_printf("USB connected, waiting for enumaration...\r\n\n");
if (!new_connected && last_connected)
uart_printf("USB disconnected, waiting for connection...\r\n\n");
if (new_enumerated && !last_enumerated)
uart_printf("USB enumerated by PC/HOST\r\n\n");
if (!new_enumerated && last_enumerated)
uart_printf("USB unenumerated by PC/HOST, waiting for enumeration...\r\n\n");
if (new_cdc && !last_cdc)
uart_printf("Serial program initiated on USB<->UART COM Port\r\n\n");
last_connected=new_connected;
last_enumerated=new_enumerated;
last_cdc=new_cdc;
// transmit to the host new dcd/dsr, it's value based on button.
void cdc_serial_state_task(void)
cdc_serial_state_t newState;
static cdc_serial_state_t lastState;
memset(&newState, 0x00, sizeof(newState));
newState.bRxCarrier = BUTTON_PRESSED();
newState.bTxCarrier = newState.bRxCarrier;
if (memcmp(&newState, &lastState, sizeof(newState)) != 0)
uart_printf("\r\nNew button state being sent: ");
//change in state, send it.
if (usb_cdc_serial_state(newState))
//state was sent ok, save it in memory so we don't resend it.
memcpy(&lastState, &newState, sizeof(lastState));
uart_printf("OK");
uart_printf("FAIL");
uart_printf("\r\n");
void main (void)
char c;
////////////////// Initialization PIC ////////////////////////////////////
set_tris_a(0xFF); output_a(0xFF); set_tris_b(0x00); output_b(0x00);
set_tris_c(0xA0); output_c(0xA0); set_tris_c(0xB8); output_c(0xF8); set_tris_d(0x00); output_d(0x00); set_tris_e(0x00); output_e(0x00); set_tris_f(0x1F); output_f(0x1F);
set_tris_g(0x03); output_g(0x03); set_tris_h(0x00); output_g(0x00);
// Verify if the PIC is running
output_high(LED0);
delay_ms(250);
output_low(LED0);
delay_ms(250);
HW_INIT();
LED_OFF(LED1);
LED_OFF(LED2);
LED_OFF(LED3);
uart_printf("\r\n\nCCS CDC (Virtual RS232) Example\r\n");
#if defined(__PCH__)
uart_printf("\r\nPCH: v");
uart_printf(__PCH__);
#elif defined(__PCD__)
uart_printf("\r\nPCD: v");
uart_printf(__PCD__);
#else
uart_printf("\r\n\PCM: v");
uart_printf(__PCM__);
usb_init_cs();
#if !(__USB_PIC_PERIF__)
uart_printf("USBN: 0x%X", usbn_get_version());
uart_printf("\r\n\n");
output_toggle(LED0);
usb_task();
usb_debug_task();
cdc_serial_state_task();
if (uart_kbhit())
c=uart_getc();
if (c=='\n') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
else if (c=='\r') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
else if (c=='!') {uart_printf(usb_cdc_putc,"HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-HELLO-WORLD-DONE");}
else {usb_cdc_putc(c);}
if (usb_cdc_kbhit())
c=usb_cdc_getc();
if (c=='\n') {uart_putc('\r'); uart_putc('\n');}
else if (c=='\r') {uart_putc('\r'); uart_putc('\n');}
else {uart_putc(c);}
delay_ms(250);
blueseasd
Posted: Mon Oct 15, 2012 6:04 pm |
The crystal frequency is 12 MHZ.
Thanks. |
jsafaie
Posted: Sat May 18, 2013 8:11 am |
hi blueseasd,
hope your problem has been solved.
I have a same problem with PIC18F87J50 USB demo board,
Could you give me a very simple and basic program for communicating some data between a PC and PIC ?
thanks in advance |
