OSA - RTOS for PIC controllers
Goto page Previous  1, 2, 3, 4, 5
Post new topic   Reply to topic    CCS Forum Index -> Code Library
skoberlink
PostPosted: Wed Jul 21, 2010 9:20 am     Reply with quote
So thanks again for helping me get it working. I've been playing with it and came across an issue. It's not a problem just something I'm curious about.
I have a task that I would like defined in another object file. This causes an error. Do task have to be defined in the main file? If not, how can I define them somewhere else?
Like I said not a big issue, just keeps my code neater in my opnion.
tester
PostPosted: Wed Aug 04, 2010 7:41 am     Reply with quote
Yes, the task should be defined in main():
void MyTask (void); // prototype
void main (void)
    OS_Task_Define( MyTask);
    OS_Task_Create(0, MyTask);
    OS_Run();
P.S. Don't forget, that CCS does not link object files correctly.
skoberlink
PostPosted: Mon Aug 09, 2010 9:59 am     Reply with quote
I'm having another problem that I don't quite understand. At this point i've run several simple test programs without any problems using OSA. I'm using OSA in a program now and the tasks are never entered. I tracked it down to that the OS_State.bEnable variable was never enabled. This seemed to get reset during the call to _OS_SET_STATE(); I'm not sure why this would be. Any suggestions?
#define OS_Sched()                                                               \
        _OS_temp = 0;                                                            \
        IF_NOT_IS_IN_CRITICAL_SECTION()                                          \
            if (_OS_CurTask >= (OST_TASK_POINTER)OS_TaskVars + (OS_TASKS-1))     \
                _OS_CurTask = (OST_TASK_POINTER)OS_TaskVars;                     \
            else        \
                _OS_CurTask++;                                                   \
        _OS_SET_STATE();                                                         \ //This resets the bEnable bit
        /* Skip empty descriptor              */                                 \
        if (!_OS_bTaskEnable || _OS_bTaskPaused) goto _LABEL_SCHED_CONTINUE;     \ //bEnable has been reset here so it doesn't enter the task, it just skips to the next loop
        IF_NOT_OS_CHECK_DELAYS_GOTO_SCHED_CONTINUE;                              \
        _OS_JumpToTask();                                                        \
        _OS_SaveRetAddr();                                                       \
    _LABEL_SCHED_CONTINUE:;                                                      \
tester
PostPosted: Tue Aug 10, 2010 9:30 am     Reply with quote
Does the bEnable flag become set after OS_Task_Create?
Do you use OS_Task_Stop or OS_Task_Delete services?
Is OS_TASKS set properly?
skoberlink
PostPosted: Tue Aug 10, 2010 9:36 am     Reply with quote
The bEnable flag is set in both OS_state and OS_CurTask after the call to OS_Task_Create(). It is reset in OS_state but not in OS_CurTask after the call to OS_SET_STATE.
I do not use OS_Task_Stop or OS_Task_Delete
OS_TASKS is set to 1 currently as I am converting code over one task at a time. There is only 1 task being created and run.
tester
PostPosted: Tue Aug 10, 2010 9:51 am     Reply with quote
Can you send me your project? (e-mail: osa at pic24.ru)
chargedneuron
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Thu Apr 14, 2011 11:34 am     Reply with quote
I was attempting to give this RTOS a try but I get the following error when I compile their tutorial #1;
Improper use of a function identifier
*** Error 117 "tutor1.c" Line 178(31,32): Improper use of a function identifier
*** Error 117 "tutor1.c" Line 179(31,32): Improper use of a function identifier
I am using compiler 4.096.
The command on that line is;
OS_Task_Create(0, Task_T1); // Tell to OS that Task_T1 and Task_T2 will
    OS_Task_Create(1, Task_T2); // be called by scheduler
the origin of that command is in OSA_Pic18_CCS.h as;
/* Create task                                                          */
#define OS_Task_Create(priority, TaskName)                          \
        _OS_Task_Create(priority, (OST_CODE_POINTER)TaskName);      \
#define OS_Task_Create_M(priority, TaskName)                        \
        OS_Task_Reserve(TaskName);                                  \
Any suggestions as to how to correct this? My thanks in advance.
"Trouble? I call it sport!" - Hyde - The League of Extraordinary Gentlemen
chargedneuron
PostPosted: Thu Mar 22, 2012 1:25 am     Reply with quote
After working with one of the designers. it turns out that the PIC18 Specific header required a fix.
Bill24
PostPosted: Fri Sep 07, 2012 7:13 am     Reply with quote
I am testing OSA version3 using a PIC18F46K80 and CCS compiler version 4.135
The example worked with very little fuss. I had to change to location of OSA.h to get it to run.
Looking through the code, to define a task eg
OS_Task_Reserve(Task_Rolling);       // Define tasks
Some code is called as follows:
/* Create task by indirect address                       */
#define OS_Task_Reserve(TaskName)                    \
        if (_pcl & 1) TaskName();
Could someone please tell me what this does and how it works.
I am intrigued.
future
PostPosted: Sun Sep 23, 2012 8:03 am     Reply with quote
It tells the compiler to not remove the function otherwise it will not get into the final code.
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 5 of 5
