PICoHolic
GPRMC GPS message decode |
Posted: Tue Jul 12, 2011 5:44 am |
#include <string.h>
#include <stdlib.h>
typedef struct _DateTimeInfo
int8 Day;
int8 Month;
int8 Year;
int8 Hour;
int8 Minute;
int8 Second;
} DateTimeInfo;
typedef struct _GPRMCInfo
char Valid;
DateTimeInfo DT;
float Latitude;
char N_S;
float Longitude;
char E_W;
float Speed;
} GPRMCInfo;
//copy string (pos n to pos m) from s2 to s1
char* StrnmCpy(char *s1, char *s2, size_t n, size_t m)
int8 i;
char *s;
for (s=s1, i=n, s2+=n; i<=m; i++)
*s++ = *s2++;
*s = '\0';
return s1;
// find c in s starting from pos st
int8 StrFnd(char *s, char c, size_t st)
int8 l;
for (l=st, s+=st ; *s != '\0' ; l++, s++)
if (*s == c)
return l;
return -1;
void GPRMC_decode(char *GPRMCStr, GPRMCInfo *RMCInfo)
int8 p1, p2;
char TempStr[16];
p1 = StrFnd(GPRMCStr, ',', 0); //find first comma
if (p1 == 6)
//check for valid packet:
if ( (StrFnd(GPRMCStr, 'A', p1+1) == 18) && (GPRMCStr[0]=='$')) //valid?
RMCInfo->Valid = 'A';
//Get time
p2 = StrFnd(GPRMCStr, ',', p1+1); //find next comma
RMCInfo->DT.Hour = atoi(StrnmCpy(TempStr, GPRMCStr, p1+1, p1+2)); //hour
RMCInfo->DT.Minute = atoi(StrnmCpy(TempStr, GPRMCStr, p1+3, p1+4)); //min
RMCInfo->DT.Second = atoi(StrnmCpy(TempStr, GPRMCStr, p1+5, p1+6)); //sec
//Get latitude & direction
p1 = StrFnd(GPRMCStr, ',', p2+1); //find next comma
RMCInfo->Latitude = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
RMCInfo->N_S = GPRMCStr[p2+1];
//Get longitude & direction
RMCInfo->Longitude = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
RMCInfo->E_W = GPRMCStr[p2+1];
//Get speed
RMCInfo->Speed = atof(StrnmCpy(TempStr, GPRMCStr, p1+1, p2-1));
//Get date
RMCInfo->DT.Day = atoi(StrnmCpy(TempStr, GPRMCStr, p1+1, p1+2)); //dd
RMCInfo->DT.Month = atoi(StrnmCpy(TempStr, GPRMCStr, p1+3, p1+4));//mm
RMCInfo->DT.year = atoi(StrnmCpy(TempStr, GPRMCStr, p1+5, p1+6)); //yy
else //not valid
RMCInfo->Valid = 'V';
drx2k
example |
Posted: Sun Jun 03, 2012 11:59 pm |
how to use this code? |
PICoHolic
Usage |
Posted: Thu Aug 02, 2012 5:27 am |
Interrupt routine for UART:
char GPSData[128];
unsigned int8 GPSDataPtr=0;
char c;
int8 GPSDataReady = FALSE;
int8 GPSmsgCount = 0;
#INT_RDA
void RDA_isr(void)
c = getc();
switch (c)
case '$':
GPSDataPtr = 0;
case '\n':
GPSDataReady = TRUE;
GPSData[GPSDataPtr++ & 0x7F] = c;
Somewhere in main():
if (GPSDataReady)
GPRMC_decode(GPSData, &MyGPRMCInfo);
if (MyGPRMCInfo.Valid == 'A')
#ifdef DEBUG_MODE
printf("\n\rTime: %d:%d:%d\n\r", MyGPRMCInfo.DT.Hour, MyGPRMCInfo.DT.Minute, MyGPRMCInfo.DT.Second);
printf("Date: %d/%d/%d\n\r", MyGPRMCInfo.DT.Day, MyGPRMCInfo.DT.Month, MyGPRMCInfo.DT.Year);
printf("Latitude: %f %c\n\r", MyGPRMCInfo.Latitude, MyGPRMCInfo.N_S);
printf("Longitude: %f %c\n\r", MyGPRMCInfo.Longitude, MyGPRMCInfo.E_W);
printf("Speed: %f knots\n\r", MyGPRMCInfo.Speed);
printf("Data saved!\n\r");
lan ahmad
Posted: Sun Oct 07, 2012 11:23 am |
Undefined Indentifier MyGPRMCInfo?
what is MyGPRMCInfo? |
PICoHolic
Posted: Sun Oct 07, 2012 12:55 pm |
It's a variable of type GPRMCInfo (the structure above)
Code: | GPRMCInfo MyGPRMCInfo; |
lan ahmad
Posted: Fri Dec 14, 2012 10:58 am |
PICoHolic wrote: | It's a variable of type GPRMCInfo (the structure above)
how i can define it?where? |
PICoHolic
Posted: Sat Dec 15, 2012 3:37 am |
It's already defined above!!
Just declare it before you use it! |
Jhonny
Posted: Sun Feb 09, 2014 8:01 am |
PICoHolic wrote: | It's already defined above!!
Dear Picoholic! Please describe for me exactly where and how to declare this "MyGPRMCInfo." The source would be great, but unfortunately, the compiler writes error:
"Undefined identifier MyGPRMCInfo" - Because of this, unfortunately can not use the code. (Please understand, I'm a beginner!) Thank you very much for your help!  |
PICoHolic
Posted: Sun Feb 09, 2014 12:52 pm |
I have already answered that. Scroll up.
Posted: Sun Feb 09, 2014 1:31 pm |
He wants to know where to put the declaration. Since the demonstration
code above is said to be "somewhere in main", then he can put the
declaration at the start of main(). That's all he wants to know.
Code: | void main()
Jhonny
Posted: Mon Feb 10, 2014 7:55 am |
Dear PCM programmer! That's right, you say! That's exactly what I wanted. Thank you very much for your help and for PICoHolic!  |
PICoHolic
Posted: Mon Feb 10, 2014 9:09 am |
Dear Jhonny, glad it works.
PS: in order to write a program in C for a microcontroller, a minimum knowledge in C language is required. Declaring a variable before using it is an extremely basic thing to know. Am I mistaken?
After all CCS forum is not a C language forum, it's a microcontroller programming forum using CCS C compiler. C language should be a prerequisite.
Cheers! |
JAM2014
Posted: Fri Jun 08, 2018 10:40 am |
Hi All,
Here is a modified version of PICoHolic's NMEA parsing routines that adds the NMEA checksum to the GPRMC structure.
#include <string.h>
#include <stdlib.h>
int8 Day;
int8 Month;
int8 Year;
int8 Hour;
int8 Minute;
int8 Second;
} DateTimeInfo;
char Valid;
DateTimeInfo DT;
float Latitude;
char N_S;
float Longitude;
char E_W;
float Speed;
int8 Checksum;
} GPRMCInfo;
int8 i;
char *s;
*s++ = *s2++;
*s = '\0';
return s1;
int8 l;
if (*s == c)
return l;
return -1;
int8 p1, p2;
int8 TempVal;
char TempStr[16];
if (p1 == 6)
//Get time
//Get speed
//Get date
//Get checksum
p1 = StrFnd(GPRMCStr, '*', 0); //find first asterisk
TempStr[0]='0';
TempStr[1]='x';
StrnmCpy(TempStr+2, GPRMCStr, p1+1, p1+2);
RMCInfo->Checksum = atoi(TempStr);
else //not valid
Jack |
