options in " #use rs232 " pre-processor directive
small_chick
PostPosted: Fri Jul 27, 2012 6:30 pm     Reply with quote
I've read options in " #use rs232 " pre-processor directive, it mentions two follow options: UART1 and UART2 for the chips first and second hartware uart. This means some chips have more than one uart hardware.
I'm using PIC16F887, it seems that this chip has only one uart hardware, is it right ?
Thanks!
gpsmikey
PostPosted: Fri Jul 27, 2012 6:32 pm     Reply with quote
Is it really that difficult to look through the datasheet for that chip ?
Or is it as you commented before that you are lazy?
mikey
mikey
small_chick
PostPosted: Fri Jul 27, 2012 7:39 pm     Reply with quote
gpsmikey, you are fun! Very Happy
I've read datasheet, but it doesn't mention "uart hardware"! It just mentions EUSART asynchronous mode and EUSART synchronous mode ! This means two uart hardware???
PostPosted: Sat Jul 28, 2012 2:47 am     Reply with quote
Look at the table, right at the front of the data sheet. Top of page 2. It lists each peripheral, and how many of each are present.
It is there for a reason.....
small_chick
PostPosted: Sat Jul 28, 2012 6:09 am     Reply with quote
thank you very much,Ttelmah! Very Happy
small_chick
PostPosted: Sat Jul 28, 2012 6:12 am     Reply with quote
everybody, I'd like to ask you one more problem. I need to calculate arcsin value of a variable, would you mind recommending me some ways ? Thanks ! Very Happy
jeremiah
PostPosted: Sat Jul 28, 2012 6:45 am     Reply with quote
There's a listing for it in the compiler manual. Check under the asin() function.
