yasotha
RFID coding |
Posted: Mon Apr 09, 2012 2:20 am |
Good day everyone,
Here I've attached the coding I've done for RFID (read & display tags ID on LCD). I'm able to read all the tags id but then when I altered the coding where few tags should be displayed as 'user not found'. I'm not able to get the output. I'm not sure what went wrong in the coding...anyone please kindly help me.
#include <18F4525.h>
#include <string.h>
/*configuration*/
#FUSES HS //Crystal Osc (<= 4mhz)
#FUSES PUT //Power Up Timer
#FUSES NOBROWNOUT //Don't Reset when brownout detected
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,PARITY=N) //RFID io
#define button1 RB0 //button (active low)
#define led1 RA0 //led 1 (active high)
#include <flex_lcd.c>
char i,j;
char code[12];
char passa[12] = {"0010268629"};
char passb[12] = {"0008006531"};
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
set_tris_a(0x00);
set_tris_d(0x00);
set_tris_c(0xA0);
while (TRUE){
lcd_putc("\f ");
lcd_gotoxy(5,1);
printf(lcd_putc, " RFID ");
lcd_gotoxy(4,2);
printf(lcd_putc, " TESTING ");
delay_ms(2000);
printf(lcd_putc,"\f");
printf(lcd_putc, " PlEASE TOUCH ");
printf(lcd_putc,"\n");
printf(lcd_putc, " YOUR ID CARD ");
for(j=0;j<11;j++)
code[j]=i=fgetc();
printf(lcd_putc, "user ID:\n ");
printf(lcd_putc,code);
output_high(PIN_A0);
delay_ms(2000);
output_low(PIN_A0);
if(strcmp(code,passa))
printf(lcd_putc,"\f user name:\n Yasotha ");
printf(code);
output_low(PIN_A0);
lcd_putc("\f ");
else if (strcmp(code,passb))
printf(lcd_putc,"\f user name:\n Padmanathan");
printf(code);
output_low(PIN_A0);
lcd_putc("\f ");
output_low(PIN_A0);
printf(lcd_putc,"\f user name:\n not found");
printf(code);
lcd_putc("\f ");
Joined: 01 Jul 2010 Posts: 9568 Location: Greensville,Ontario
Posted: Mon Apr 09, 2012 7:12 am |
1) always add 'errors' to the USE RS232(....) directive when using the hardware UART.
2) go back to your working code and then make 1 change. See what happens.
3)this...
code[j]=i=fgetc();
...doesn't 'look right' to me..... |
Posted: Mon Apr 09, 2012 10:58 am |
Quote: | if(strcmp(code,passa))
Look up strcmp() in a C manual. What is the return value if the strings
match ? What return value are you checking for in your code ?
When you answer these questions you will solve the problem. |
Posted: Mon Apr 09, 2012 11:23 am |
as PCM wisely counsels ,
you seem to be ONE
short of being where you want to be |
yasotha
HI |
Posted: Wed Apr 11, 2012 10:42 am |
Hi, I don't really get the meaning. I have searched in c manual but I really don't understand. |
jeremiah
Posted: Wed Apr 11, 2012 11:21 am |
Tell us what the various output results for the strcmp function are. Type them out in a post. Then look at your IF statement with strcmp in it and try to figure out what the result will be. |
yasotha
hi.. |
Posted: Sat May 12, 2012 8:45 am |
Code: | #include <18F4525.h>
#include <string.h>
/*configuration*/
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,bits=8,PARITY=N,ERRORS) //RFID io
char i,j;
char code[11];
char passa[11] = {"0004870730"};
char passb[11] = {"0004877973"};
setup_adc(ADC_OFF);
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0xA0);
while (TRUE){
printf(lcd_putc, " RFID Wireless ");
printf(lcd_putc, " Door System ");
delay_ms(2000);
printf(lcd_putc, " Place your ID ");
printf(lcd_putc, " on the reader");
for(j=0;j<10;j++)
code[j]=i=fgetc();
printf(lcd_putc, "user ID:\n");
delay_ms(2000);
if(!strcmp(code,passa))
printf(lcd_putc,"\f user name:\n yasotha");
else if (!strcmp(code,passb))
i still cant find solution to compare two ID's. It displays all the ID's on LCD. any solutions?
strcmp if both value matches it gives 0. |
Posted: Sat May 12, 2012 4:58 pm |
You need to develop an attitude of "I will find the problem !", and then
learn to put in diagnostic code to help you see what the program is doing.
For example, you have two arrays. One has a password in it already.
The other array has a password that is typed in by the user. For some
reason, your strcmp() doesn't give the expected result. So, what to do ?
Answer: Put in diagnostic code to display the contents of both arrays
in hex, and also display the result from strcmp(). Then you can see
what is happening:
for(j=0;j<10;j++)
code[j]=i=fgetc();
delay_ms(2000);
// ====== Diagnostic code ==========
printf("\n\r");
printf("code[]= ");
for(i=0; i<11; i++)
printf("%x ", code[i]);
printf("\n\r");
printf("passa[]= ");
for(i=0; i<11; i++)
printf("%x ", passa[i]);
printf("\n\r");
i = strcmp(code, passa);
printf("strcmp result = %d \n\r", i);
Look for common problems such as missing the "0x00" byte on the end
of a string. Without that byte, it's not a string.
Also, get rid of this type of coding shown below. It's not normally done.
It's considered to be "messy", and it's not good for program maintenance
in the future. (Don't set two variables in the same line):
Quote: |
code[j]=i=fgetc();
Mike Walne
Posted: Sat May 12, 2012 5:06 pm |
Work on the KISS principle.
You're having a problem with strcmp().
So, get rid of everything else and just work on that one piece of code.
Mike |
