flex_lcd driver error
PAPALUJA
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Sun Feb 12, 2012 10:03 am     Reply with quote
I just found out about flex_lcd.c driver. The only problem is that it does not compile with success as lcd.c does. The compile result is error 128 "flex_lcd.c" line 28(1,43):A #DEVICE required before this line. I did not change the code so the lines are the same as the author's. If I try to use it in the main project as #include file, I don't get any display on the LCD. Please help out I need to submit the project asap for my electronic engineering studies. Confused
C CCS FOREVER!
PostPosted: Sun Feb 12, 2012 10:13 am     Reply with quote
It.s best to show us your code as well as telling us your compiler version and PIC being used.
PAPALUJA
PostPosted: Sun Feb 12, 2012 12:18 pm     Reply with quote
hi temtronic
The code is a CCS C code that I simply picked to simulate the driver.I am acually using PIC C COMPILER from CCS
Here is the code:
//// EX_LCDKB.C ////
Code deleted.
Reason: Forum rule #10
10. Don't post the CCS example code or drivers.
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
C CCS FOREVER!
PostPosted: Sun Feb 12, 2012 12:22 pm     Reply with quote
First you CANNOT post CCS copyrighted code here !!!! It's against the forum rules AND everyone here has it, so there is no need to show it anyway.
2nd, you say 'simulate'. Does this mean you're NOT using real hardware ???
PAPALUJA
PostPosted: Sun Feb 12, 2012 1:54 pm     Reply with quote
I'm sorry for violating forum rules as I've just joined the forum I REALLY dont know where the rules are at in the forum.
I firstly compiled flex_lcd.c driver with the result as shown on the post and then lcd.c driver with successful results. I then included the flex driver in the test code provided to test flex_lcd.c driver. The text was not displayed on lcd as I was using PROTEUS ELECTRONICS for simulation. The same was done with ldc.c driver and the text was displayed on the lcd. The same results are obtained even if I use hardware which is ACE CCS DEVELOPMENT KIT.
Once again I apologise for violating forum rules. I'll locate them and go through them thoroughly.
C CCS FOREVER!
PostPosted: Sun Feb 12, 2012 2:08 pm     Reply with quote
The problem is NOT with flex_lcd, you are doing something incorrectly.
If you included the file in your main and it compiled, but you got
no display, you have an error of some kind (h/w or s/w).
First, tell us what version of CCS compiler you are using. The
version number will be in the form 3.xxx or 4.xxx and will be found
at the top of your .LST file.
Second, show us your main project that compiles with <flex_lcd.c>
included.
BTW, forum rules are at the top of the Discussion forum listing.
PAPALUJA
flex_lcd.c driver error
PostPosted: Sun Feb 12, 2012 2:23 pm     Reply with quote
I am using CCS PCM C Compiler, Version 4.104
C CCS FOREVER!
PAPALUJA
PostPosted: Sun Feb 12, 2012 2:59 pm     Reply with quote
wow!!!! I figured out the problem. I wrote #include <pic 16f877a.h> in the flex driver file by mistake. Maybe I thought I was writing on my main code. What a nice driver. It's so simple and straight forward. Thanx guys a lot. Can anyone tell me why the keypad does not change the lcd text for for ex22.c CCS example? Is the problem with the kbd.c driver or what?
C CCS FOREVER!
