Switch Case won't work
deltatech
PostPosted: Fri Feb 10, 2012 9:47 am     Reply with quote
Hi All, I am having a problem getting Switch Case to work I don’t know what I am doing wrong but i am sure CCS Gurus will know what is problem something very simple but I can’t figure it . Many thanks in advance for any help
what I am trying to do is Flash LED1 if PIN_5B goes high and flash LED2 If PIN5B goes Low . but it is not working
#include <16F877A.h>
#device adc=16
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
#define CAR_POWER PIN_B5
#define LED1 PIN_B4
#define LED2 PIN_B3
int1 last_button_1=FALSE;
   while( TRUE )
   switch (CAR_POWER)   {
   case 1:
          output_high (LED1);
          output_low (LED1);
  case 0:
          output_high (LED2);
          output_low (LED2);
tae
PostPosted: Fri Feb 10, 2012 10:00 am     Reply with quote
switch (CAR_POWER)
replace
switch (Input(CAR_POWER))
deltatech
PostPosted: Fri Feb 10, 2012 11:32 am     Reply with quote
tea you are a star many thanks it is working now Very Happy
