asmboy
small changes - larger aggravation -- |
Posted: Tue Jan 03, 2012 4:35 pm |
post install of 4.128 - command line version-
i don't know if i should laugh or cry.
suddenly in this version - the extension ".c" is explicit .....
as in the full source file name tagged with .C is required to compile.
( it didna used to be that way - but now - an improvement ??)
Another weird thing that is inscrutable and a real PITA
WHY would they change the FUSES in an older device file?
the 4.085 device files for the 18f4525
( of which i just ran afoul) define BORV28 as a valid fuse
Now in the "new improved" device header - ? only BORV27
is acceptable.
am i simply not in tune with the reason why header file content should suddenly need to be different?
I am getting a very bad feeling about how fuses are handled --
as altering long stable, defined - text descriptors does NOT seem like a clever way to advance usability, especially if i have to edit old files for bloody FUSES!!!
i suddenly realize the "misery pill" i have taken in order to compile for some new 18xxK parts and the feeling is a tad less than wonderful. |
Joined: 01 Jul 2010 Posts: 9154 Location: Greensville,Ontario
Posted: Tue Jan 03, 2012 8:16 pm |
There's something to be said about 'NOT" upgrading ! Whether it's hardware or software, I've found it's best to work with what you KNOW is good and solid and NOT take the 'Upgrade train'.
Just because it's 'new', 'more features','faster','better',etc. doesn't mean it really is, in the long run.
Having to debug 'this worked' before version xxx or 'that pin' used to do this...is a huge loss of time and money.
I feel your pain. Yeesh, I lost all of today(14 hrs) trying to get a Vinculum to be both 'host' and 'device'. Yes, technically possible, but I ain't got microscopes for eyes to tie a resistor to one of the 44 pins that's thinner than a human hair!
Yup, guess I'm getting old and losing patience on this microSMD stuff. |
asmboy
Posted: Wed Jan 04, 2012 11:09 am |
more of what i mean about fuses
CCS PCH C Compiler, Version 4.128 03-Jan-12 18:19
0000: GOTO 01A4
.................... #include <18f2450.h>
.................... //////// Standard Header file for the PIC18F2450 device ////////////////
.................... #device PIC18F2450
.................... #list
.................... #Fuses HS,NOFCMEN,NOIESO,PUT,BROWNOUT,BORV28,NOVREGEN,NOWDT,
.................... #Fuses NOPBADEN,NOLPT1OSC,NOMCLR,NOSTVREN,NOLVP,NODEBUG,NOPROTECT_0HIGH,
.................... #Fuses NOPROTECT_1,NOCPB,NOWRT,NOWRT1,NOWRTC,NOWRTB,NOEBTR,NOEBTRB,
0232: SLEEP
Configuration Fuses:
Word 1: 0C3F PLL12 CPUDIV4 USBDIV HS NOFCMEN NOIESO
Word 2: 1E16 PUT BROWNOUT BORV28 NOVREGEN NOWDT WDT32768
Word 3: 0000 NOPBADEN NOLPT1OSC NOMCLR
Word 4: 0088 NOSTVREN NOLVP BBSIZ2K NOXINST NODEBUG
Word 5: 4003 NOPROTECT_0HIGH NOPROTECT_1 NOCPB
Word 6: 6003 NOWRT NOWRT1 NOWRTC NOWRTB
Word 7: 4002 NOEBTR NOEBTRB
needless to say with these settings RS232 - use delay ,
and calculated timer rollovers && delays etc are trashed. |
Posted: Thu Jan 05, 2012 2:23 pm |
Are you saying that you changed from V4.078 to V4.128? A number of compiler changes has been accumulated through the years... |
asmboy
Posted: Thu Jan 05, 2012 2:39 pm |
4.085 actually
but the changes i NEED were new chip support -
finding a count-zero bug in array indices is not fun -
and what i was bitching about was not liking
changed params in old header files - that
break how fuses are interpreted in teh newer version ;-((
i think #fuses is one of the WEAKEST - most poorly
documented parts of the CCS compiler -
what i would LOVE to see is an expert setting like this:
i would prefer to leave out #fuses statements
and spec this as valid
#FUSEREG 0x30001 0x3A
#FUSEREG 0x30002 0x03
etc etc
i bet it can be done w/o a special #directive - SO
if the wiser heads here can pont the way - i would be grateful |
