leevise
DS1302 display error |
Posted: Wed Nov 23, 2011 7:26 am |
hello guys
I make a test code that uses the ds1302.c driver and lcd.c driver with PIC18F4520. After I set the time and data, it displays wrong time and data.
As follows is my code. I can't find where I'm wrong in this code, and pls help me !!
#include <18f452.h>
//#device ICD=TRUE
#fuses HS,NOWDT,PUT,NOPROTECT
#use delay (clock = 20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=N,bits=8)
#define PORTA 0xF80
#define PORTB 0xF81
#define PORTC 0xF82
#define PORTD 0XF83
//=============LCD PIN=============
#define LCD_ENABLE_PIN PIN_A5 // RA
#define LCD_RS_PIN PIN_A2 //RS
#define LCD_RW_PIN PIN_A3 //
//=============DS1302 PIN===========
#define RTC_SCLK PIN_E2
#define RTC_IO PIN_E1
#define RTC_RST PIN_E0
#include <ds1302.c>
#include <lcd.c>
byte day,mth,year,dow,hour,min,sec;
lcd_init();
rtc_init();
rtc_set_datetime(22,11,11,03,9,10,33);
//rtc_set_datetime(day, mth, year, dow, hour, min,sec);
while(true)
rtc_get_date( day, mth, year, dow);
rtc_get_time( hour, min, sec );
printf(lcd_putc,"\f\%2d/\%2d/\%2d\n",day,mth,year);
printf(lcd_putc,"\%2d:\%2d:\%2d",hour,min,sec);
/*rtc_get_time(hour,minute,second);
rtc_get_date(day,mth,year,dow) ;
printf(lcd_putc,"%2u/%2u/%2u\n%2u:%2u:%2u",day,mth,year,hour,minute,second);
//delay_ms(1000);
I modified somewhere in ds1302.c driver as follow:
void rtc_set_datetime(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min,BYTE sec)
write_ds1302(0x86,get_bcd(day));
write_ds1302(0x88,get_bcd(mth));
write_ds1302(0x8c,get_bcd(year));
write_ds1302(0x8a,get_bcd(dow));
write_ds1302(0x84,get_bcd(hr));
write_ds1302(0x82,get_bcd(min));
write_ds1302(0x80,get_bcd(sec));
The 1602LCD display the data and time:
44/11/12
40:10:28
Where wrong ? |
Posted: Wed Nov 23, 2011 1:53 pm |
Post a link to the schematic of your PIC and ds1302 circuit.
You can use a free image hosting website to host your schematic image:
http://www.imageshack.com/
Then you can give us the link to it. |
leevise
Posted: Thu Nov 24, 2011 12:11 am |
PCM programmer wrote: | Post a link to the schematic of your PIC and ds1302 circuit.
Sorry, I can't open this web, it is very slow when I want to open it.
Pls who can support a new upload web for my schematic.
Thank you very much!
My schematic set as follow:
DS1302 pins
pin1 Vc2-------5V, pin2&pin3------Crystal, pin4---GND
pin8 VC1 ------battery , pin6------IO, pin7------SCLK
pin5------Rst
PIC18F4520 pin
RE0-------RST ,RE1---------IO,RE2-------SCLK
Posted: Thu Nov 24, 2011 2:16 pm |
Quote: |
pin1 Vc2-------5V, pin1 & pin2------Crystal
Here you claim to have pin 1 used for both Vcc2 and the crystal.
That's not correct.
What is your CCS compiler version ? |
leevise
Posted: Thu Nov 24, 2011 7:21 pm |
PCM programmer wrote: | Quote: |
That's not correct.
Sorry, I wrote wrong, it should be pin2&pin3-----crystal.
My CCS compiler version is 4.110.
My schematic upload :http://ul.to/znrd51p6 |
Posted: Thu Nov 24, 2011 7:44 pm |
Your schematic shows capacitors on the crystal. The ds1302 data sheet
says specifically not to do this:
Quote: |
OSCILLATOR CIRCUIT
The DS1302 uses an external 32.768kHz crystal. The oscillator circuit
does not require any external resistors or capacitors to
operate. See page 5:
http://pdfserv.maxim-ic.com/en/ds/DS1302.pdf |
leevise
Posted: Fri Nov 25, 2011 3:05 am |
PCM programmer wrote: | Your schematic shows capacitors on the crystal. The ds1302 data sheet
Quote: |
OSCILLATOR CIRCUIT
Thank you ! I will take out 2 capacitors. But I ask a new question:
Someone told me, if add the capacitor for DS1302, they will enhance the time precision. Is this right? |
Posted: Fri Nov 25, 2011 3:35 pm |
I never heard of it in this application. It's not recommended by Maxim.
Use the specified crystal (32.768 KHz, 6 pf load). |
leevise
Posted: Sat Nov 26, 2011 6:11 pm |
PCM programmer wrote: | I never heard of it in this application. It's not recommended by Maxim.
I take out those capactors, it also doesn't work, the LCD display
44/ 2/ 0
0: 0: 0
The clock also doesn't run! |
Joined: 01 Jul 2010 Posts: 9165 Location: Greensville,Ontario
Posted: Sat Nov 26, 2011 7:58 pm |
You may have damaged the chip !
Have you tried writing and reading known data to the RAM on the DS1302 ?
If that test works, then I suggest the RTC part of the chip is defective.
If it fails, then the whole chip is defective.
Someone who has that chip may be able to confirm that the 1302 'driver' does work, I only have the 1307 here.
Also can you confirm the LCD works correctly by displaying "Hello World" on it ? |
leevise
Posted: Sun Nov 27, 2011 11:35 pm |
temtronic wrote: | You may have damaged the chip !
I test my LCD ,this part code works. and I use other's code test the RTC ,it is very good ,so i think the LCD and DS1302 are ok.
I found the DS1302's crystal doesn't work . yesterday ,i disconnected the 2 capacitors(6pf) with DS1302 ,then the crytal didn't start. today so i had to connect the 2 capacitors(6pf) ,however, Ds1302' crystal still doesn't start.
1) why the crystal cann't start ?
2) Is my code defective?
I cann't solved it ,pls help me . I think everybody run his demo used my code in order to checking my code .
Also who can give me a successful demo code with DS1302 ?. |
