Access to ROM const
Pekub
Access to ROM const
PostPosted: Wed Nov 23, 2011 10:50 am     Reply with quote
I tried use ROM constant in my program.
Please, can someone explain me what is the right way to access a ROM constant ?
#include <18F26K22.h>
#device CONST=ROM
const int8 yy = 10;
int8 xx;
xx = 100;
if(xx < yy) // doesn`t work
if(xx < (int8)yy) // it work`s
Thank`s
Peter
PostPosted: Wed Nov 23, 2011 1:25 pm     Reply with quote
You didn't give a full test program or your compiler version, so I made
a test program and tested it with vs. 4.127. It works. I got this output
in the MPLAB simulator:
Print this if 100 is NOT less than 10.
Test program:
#device CONST=ROM
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
const int8 yy = 10;
int8 xx;
xx = 100;
if(xx < yy)   // Is (100 < 10) ?
   printf("Print this if 100 is less than 10. \r");
   printf("Print this if 100 is NOT less than 10. \r");
Pekub
PostPosted: Thu Nov 24, 2011 3:56 am     Reply with quote
O.K. It`s work.
But try this one:
int8 xx;
const int8 Table[2] = {10, 50};
xx = 100;
if(xx < Table[0])
   Led_PrgEE_On();
    Led_PrgEE_Off();
PostPosted: Thu Nov 24, 2011 2:13 pm     Reply with quote
Again, you didn't post your compiler version.
But it works for me. The program below gives this output in MPLAB
simulator. It's correct:
LED off
#device CONST=ROM
int8 xx;
xx = 100;
if(xx < Table[0])
   printf("LED on \r");
   printf("LED off \r");
Pekub
PostPosted: Sat Nov 26, 2011 4:02 am     Reply with quote
I tried it maybe 20 times with V 4.127, V 4.122,
but it doesn`t work.
#device CONST=ROM
#fuses INTRC,,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=16000000)
   int8 xx;
   xx = 100;
   if(xx < Table[0])
      output_high(PIN_B2); // LED On
      output_low(PIN_B2);  // LED Off
   while (1)
I dont`t understand assembler, but there is a difference between these methods:
.................... if(xx < (int8)Table[0])
00052: CLRF FF8
00054: SETF FF7
00056: MOVLW FE
00058: MOVWF FF6
0005A: CLRF FEA
0005C: MOVLW 06
0005E: MOVWF FE9
00060: CLRF 0B
00062: MOVLW 02
00064: MOVWF 0A
00066: MOVLB 0
00068: BRA 0004
0006A: MOVF 06,W
0006C: SUBWF 05,W
0006E: BC 0076
.................... output_high(PIN_B2);
00070: BCF F93.2
00072: BSF F8A.2
.................... if(xx < Table[0])
00052: CLRF FF8
00054: SETF FF7
00056: MOVLW FE
00058: MOVWF FF6
0005A: CLRF FEA
0005C: MOVLW 06
0005E: MOVWF FE9
00060: CLRF 0B
00062: MOVLW 02
00064: MOVWF 0A
00066: MOVLB 0
00068: BRA 0004
0006A: MOVF 07,F
0006C: BNZ 0074
0006E: MOVF 06,W
00070: SUBWF 05,W
00072: BC 007A
00074: BCF F93.2
00076: BSF F8A.2
PostPosted: Sat Nov 26, 2011 5:26 am     Reply with quote
OK.
What is happening is quite interesting. It appears that if the CONST=ROM device statement is present, it is making the compiler treat the returned value from the table fetch, as a 16bit value, even if it is defined as an 8bit value...
So the extra test, is testing if the the top byte returned is non zero, and if it is, then the value must be larger than an int8 value, so skips the rest of the test....
It doesn't happen if you explicitly type cast, _or_ if you swap the variables. So:
   if(Table[0] > xx)
Works fine.
It is a bug, and should be reported, but is very simple to program round.
PostPosted: Sat Nov 26, 2011 5:35 am     Reply with quote
It's present at least for CCS C V4.120 until V4.127. V4.112 is still O.K.
You can cause even more confusion by extending the table to 4 bytes, which makes CCS C treating Table[] as a long quantity.
Once more exceeding all (bad) expectations...
const int8 Table[4] = {10, 50, 51, 52};
15:                if(xx < Table[1])
  0090    6AF8     CLRF 0xff8, ACCESS
  0092    68F7     SETF 0xff7, ACCESS
  0094    0EFD     MOVLW 0xfd
  0096    6EF6     MOVWF 0xff6, ACCESS
  0098    6AEA     CLRF 0xfea, ACCESS
  009A    0E06     MOVLW 0x6
  009C    6EE9     MOVWF 0xfe9, ACCESS
  009E    6A0F     CLRF 0xf, ACCESS
  00A0    0E04     MOVLW 0x4
  00A2    6E0E     MOVWF 0xe, ACCESS
  00A4    0100     MOVLB 0
  00A6    D7B8     BRA 0x18
  00A8    5209     MOVF 0x9, F, ACCESS
  00AA    E107     BNZ 0xba
  00AC    5208     MOVF 0x8, F, ACCESS
  00AE    E105     BNZ 0xba
  00B0    5207     MOVF 0x7, F, ACCESS
  00B2    E103     BNZ 0xba
  00B4    5006     MOVF 0x6, W, ACCESS
  00B6    5C05     SUBWF 0x5, W, ACCESS
  00B8    E206     BC 0xc6
16:                   printf("LED on \r");
