ds18b20 glcd problem? Help!
Goto page Previous  1, 2
ezflyr
PostPosted: Tue Nov 22, 2011 4:48 pm     Reply with quote
The problem for me is that you've noted a number of observations based on your work with both Proteus simulations, and real hardware. That's a real problem because it's impossible to know from a distance which observations are relevant. You've introduced too many indeterminate variables into the equation. Frankly, unless you limit your discussion/troubleshooting to pure hardware you aren't going to get any help here. No one is going to want to help you chase a Proteus bug, or rely on observations made using a Proteus simulation.
I think you need to make up both circuits in "real" hardware, and verify that the problem exists in the real world. Stick to one type of temp. sensor, and keep things as simple as possible. Once you do that, we'll be able to help!
I've got a protoboard with the 16F877, a DS18b20, a 4X20 LCD, and a 128X64 GLCD, so I can test this myself in real hardware. But I'm not going to do that until you show me that you are at least as interested in solving this problem as I am.
Good Luck!
John
oburak90
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Nov 24, 2011 7:18 am     Reply with quote
i have some exam. i when finish all of them i build its on board. and try its. i take some photo. i want run the project succesfuly.. i write here after try its. Thanks...
Ömer Burak ÖZKESKİN
fkl
PostPosted: Thu Nov 24, 2011 7:32 am     Reply with quote
Hello
Please try to heat the sensor temperature above 54 ° C.
Correctly shows the temperature above 54 ° C?
PostPosted: Thu Nov 24, 2011 9:03 am     Reply with quote
fkl..
fyi..
My DS18B20-par sensors work fine up to +128*C. Used a heatgun to test them.
Page 2 of 2
