SPI on dsPIC 33FJ128GP802 doesn't work
cassioriguela
PostPosted: Tue Nov 22, 2011 10:44 am     Reply with quote
Hello my friends,
I have a problem with SPI. I did a test code so i'm writing a byte on SPI and getting nothing on scope. In addition, my writedata function get hangs on SPI1TBF bit.
My code:
#include "main.h"
#BYTE SPI1CON = 0x242
#BYTE SPI1BUF = 0x248
#BYTE SPI1STAT = 0x240
#BYTE SPI1CON2 = 0x244
#BIT DISSCK = SPI1CON.12
#BIT DISSDO = SPI1CON.11
#BIT MODE16 = SPI1CON.10
#BIT SMP    = SPI1CON.9
#BIT CKE    = SPI1CON.8
#BIT SSEN   = SPI1CON.7
#BIT CKP    = SPI1CON.6
#BIT MSTEN  = SPI1CON.5
#BIT SPRE4  = SPI1CON.4
#BIT SPRE3  = SPI1CON.3
#BIT SPRE2  = SPI1CON.2
#BIT PPRE1  = SPI1CON.1
#BIT PPRE0  = SPI1CON.0
#BIT SPI1EN  = SPI1STAT.15
#BIT SPI1RBF = SPI1STAT.0
#BIT SPI1TBF = SPI1STAT.1
#BIT SPISIDL = SPI1STAT.13
#BIT SPIROV = SPI1STAT.6
void writeData(unsigned char data)
   SPI1BUF = data;
   while(SPI1TBF)
      fprintf(COM,"DEBUG...\r\n");
   int a = 0;
   int b;
   char d = 0x50;
   SPI1EN = 0;
   DISSCK = 0;
   DISSDO = 0;
   MODE16 = 0;
   SMP = 1;
   CKE = 0;
   CKP = 1;
   SPRE4 = 1;
   SPRE3 = 1;
   SPRE2 = 0 ;
   PPRE1 = 1;
   PPRE0 = 0;
   SPI1EN = 1;
   MSTEN = 1;
   SPI1CON2 = 0;
   SPISIDL = 0;
   SPIROV = 0;
        setup_wdt(WDT_OFF);
        setup_timer1(TMR_DISABLED);
   set_tris_b(0b1111001011111111);
      fprintf(COM,"Main...\r\n");
      writeData(d);
Can someone help me ? .Thanks guys !
cassioriguela
PostPosted: Wed Nov 23, 2011 5:09 am     Reply with quote
Someone can help, please ?
PostPosted: Wed Nov 23, 2011 5:32 pm     Reply with quote
The reason you got no replies is, most of us don't have the PCD compiler.
The few people that do have it, don't want to use direct register settings.
I am just trying to explain why you don't get any replies.
cassioriguela
PostPosted: Thu Nov 24, 2011 5:50 am     Reply with quote
Hello PCM,
Thanks for reply.
I'm using direct register settings because my spi_setup and #use spi doesn't work. Anyway, Thanks.
PostPosted: Thu Nov 24, 2011 12:20 pm     Reply with quote
Check the errata sheets for the chip. I seem to remember there is one to do with this bit....
