7 segment seconds
kamillas
7 segment seconds
PostPosted: Sat Nov 12, 2011 6:56 am     Reply with quote
hello, I made a circuit 7segment display, and I want to display a rotation time (seconds) from 0 seconds to 60 seconds but I found a calculation problem, I have 01 seconds between each display, and when the the display shows the number 9 after it displays the number 0, not 10, 11, 13 ..... so help me
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use delay(clock=40000000)
void main(){
int unit,dec;
char display_digit[10]= {0xbF,0x6,0x5b,0x4f,0x66,0x6D,0x7D,0x7,0x7f,0x6F};
while (1)
OUTPUT_B(0x00);
OUTPUT_A(0xFF);
for (Dec=0;Dec<=5;++Dec)
 for (unit=0;unit<=9;++unit)
              OUTPUT_A(0x01);
              OUTPUT_B(display_digit[unit]);
              delay_ms( 100 );
              if (Dec==0)   output_high(PIN_A1);
              else  OUTPUT_A(0x02);
              OUTPUT_B(display_digit[dec]);
ERICOO
PostPosted: Fri Nov 25, 2011 12:47 pm     Reply with quote
YOU DELAYED FOR 100ms for the unit digit. where is your delay for tenth digit?
