idham85
SMS controller |
Posted: Sat Sep 03, 2011 5:47 am |
hello to all,
I'm trying to order a printer via SMS such a way that the printer prints the SMS received by the GSM. Indeed, I used GL865 Telit GSM module, a PIC16F877, a thermal printer. the communication between GL865 is via serial port. If the GSM received a message, the microcontroller will transfer the message to the printer via serial port. My problem is the program of the PIC.
I am looking for a full program or for example used in this application.
Help me please.
Thank you in advance
idham85
interface GSM |
Posted: Sat Sep 03, 2011 9:06 am |
I just want a code of the connection between PIC and GSM module. Receiving and sending messages between the two. |
idham85
Posted: Sat Sep 03, 2011 9:59 am |
Please I need code for PIC. Just the first part ie how to communicate between GSM and PIC such a way that I receive only SMS and save them.
I use PICC compiler |
Joined: 01 Jul 2010 Posts: 9149 Location: Greensville,Ontario
Posted: Sun Sep 04, 2011 5:06 am |
I don't have that GSM module and when I go to download the hardware PDF, IE8 doesn't unblock it but goes to new Google.....arrgh ,so I can't get the PDF!
In general though you'll need some 'MAX232' chips and some simple serial software.There are several examples on this forum,just use the 'search' option on the top of the screen.
Be sure that all hardware is compatible, especially voltage levels! You MUST have level translators if GSM is 3.3v and the PIC is 5v. |
fiolin
Posted: Sun Sep 04, 2011 2:51 pm |
I made a kind of sms's control remote with a gsm module and 16F886 pic. Before to start the pic program I've used hyperterminal in order to understand how works the incomming sms. In my case only I've used phone number and the text message in my program.
Here a little part if you send the sms On you turn on Led_out and if you send Off you turn off Led Out (pin_B4).
#include <16F876.h>
#byte PORTA = 0x05
#byte PORTB = 0x06
#device *=16
#device ICD=TRUE
#device adc=8
#use fast_io(A)
#use fast_io(B)
#FUSES XT //Crystal osc <= 4mhz
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES DEBUG //Debug mode for use with ICD
#use delay(clock=4000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,restart_wdt)
#include <stdlib.h>
#define led_out PIN_B4 //Led out
#define led_state PIN_B5 //Led monitor
#define IN_ONOFF PIN_B0 //When goes down send a sms
#define BUFFER_SIZE 60 //Buffer size you can adjust this size
char buffer[BUFFER_SIZE]; // buffer
char b=0x00; // Last characters recived
int xbuff=0x00;
short sms_mode=false;//It's a flag when is true read sms( lee_sms())
// Declaración de Funciones ///////////////////////////////////////////////////
void send_sms();//send sms routine
void lee_sms();
void inicbuff(void); // Limpia buffer
void demora(unsigned int repetir);//delay rutine
void verifica_ok (void);//checkl OK sending byl modem
void inicmodulo(void);
#int_RDA
RDA_isr()
if(kbhit()){
b=getc();
if(b=='+'){//first character of phone number
xbuff=0;//para que comience a escribir a la var buffer desde la 1º posición
sms_mode=true;
buffer[xbuff++]=b; // add character to the buffer vector
return 0;
// Programa principal
void main(void){
set_tris_A(0b00000000); //config port A
set_tris_B(0B10000011); //config port B
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
enable_interrupts(INT_RDA);
output_high(led_state);//enciende el led monitor de estado
output_low(led_out);//apaga el led de salida
inicbuff();
inicmodulo();
for(;;)
if(input(IN_ONOFF)==0)
delay_ms(200);
send_sms();
while(input(IN_ONOFF)==0);
if(sms_mode==true)//si sms_mode=true se pasa a la función lee_sms()
lee_sms();
sms_mode=false;
output_low(led_state);
}//for(;;)
}//main()
//Envia los comandos AT para inicializar el modulo sms
void inicmodulo(void){
printf("AT\n\r"); //
verifica_ok ();
inicbuff();
printf("ATE0\n\r"); //cancel echo mode
verifica_ok ();
inicbuff();
printf("AT+CPMS=\"SM\",\"SM\"\n\r");//Selecciono la mem sim para recibir y leer sms
verifica_ok ();
inicbuff();
printf("AT+CNMI=2,2,0,0,0\n\r");//los sms se envían directamente al puerto serie
verifica_ok ();
inicbuff();
printf("AT+CMGF=1\n\r"); //Habita el modo texto de los sms
verifica_ok ();
inicbuff();
//Funcion para envío de sms
void send_sms()
char in_state='D';
char out_state='D';
if(input(IN_ONOFF)==0) in_state='A';
if(bit_test(PORTB,4)==1) out_state='A';
output_high(led_state); //enciende el led
printf("AT+CMGS=\"xxxxxxxx\"\n\r");//here your cellphone number
printf("Inputs - Outputs\n\r");
printf("1 / 1\n");
printf("%c / %c\n",in_state,out_state);//here send state of inputs & outputs
putc(26);// envia ctrl + Z
demora(5);
verifica_ok();// compruebo si se envió el sms
return;
//Función para leer el sms recibido
void lee_sms(void){
char *ptr;
char r2_on[]="On";
char r3_off[]="Off";
char r4_estado[]="Estado";
printf("AT+CMGD=1\n\r");
ptr=strstr(buffer,r2_on);//busca la palabra On en buffer[]
if(strncmp(ptr,r2_on,2)==0){
output_high(led_out);//activa la salida
inicbuff();
send_sms();
ptr=strstr(buffer,r3_off);//busca la palabra Off en buffer[]
if(strncmp(ptr,r3_off,3)==0){
output_low(led_out);//desactiva la salida
inicbuff();
send_sms();
ptr=strstr(buffer,r4_estado);//busca la palabra Estado en el vector buffer
if(strncmp(ptr,r4_estado,6)==0){
inicbuff();
send_sms();//Si la encuentra manda un sms reportando el estado de entrada y salida
return;
//Pone ceros en toda la variable buffer
void inicbuff(void){
int i;
for(i=0;i<buffer_size;i++){
buffer[i]=0x00;
restart_wdt();
xbuff=0x00;
sms_mode=false;
return;
//Delay routine minim de 1 sec /
int i;
for(i=repetir;i--;)
restart_wdt();
return;
void verifica_ok (void){//esto la uso para comprobar el OK que envía el modem luego de enviarle algún comando AT
char *ptr;
char r1_ok[]="OK";
ptr=strstr(buffer,r1_ok);//busca la palabra OK en el vector buffer
if(strncmp(ptr,r1_ok,2)==0){
output_low(led_state);//me guio por el led para saber si el modem manda OK
return;
idham85
Posted: Sun Sep 04, 2011 4:12 pm |
Thank you very much for your help.
May you explain how this code and the connecting pins of Port.
I want to understand your code because it validated by the compiler for that I'll change it to suit my application. My application is to make communication between the PIC and the mobile phone as follows:
- The PIC enters a wait loop by sending the command "AT + CMGS" to the GSM receives an SMS in the PIC responds to a Command "+ CMGS"
-The PIC sends a command to receive the message and displays it on an LCD screen.
-Each SMS received by the PIC, it sends a confirmation message to the GSM.
May you help me please. |
fiolin
idham85
Posted: Mon Sep 05, 2011 3:59 am |
And me I'm sorry for my english because I'm tunisian and arabic is my mother language |
kamillas
gsm |
Posted: Tue Mar 13, 2012 10:22 am |
In this driver, I found the problem:
1 - Normally this program must receive a sms, on, or off to on or off an LED.
2 - What is the exact role of input input (IN_ONOFF), this button is used for what reason? ,
3-printf("Inputs - Outputs\n\r"); ????why?
4-printf("1 / 1\n"); ????
5-printf("%c / %c\n",in_state,out_state);// ??????????
6-ptr=strstr(buffer,r2_on) What is it? « ptr » , "strstr" ?
7-strncmp(ptr,r2_on,2)? what is it strncmp.
8-what is its role of fonction void demora() ,and , void verifica_ok (void)
9-I found that in all the GSM program, it is used this table (buffer[BUFFER_SIZE]) , this table buffer it is used for what reason
I found no clear explanation on the topics of GSM, I ask all programmers helped me on this subject, especially who applied this driver, I want to understand the operating principle, normally when the Module gsm receive sms, in this case it affects 1 in B4, but why the programmer used the routine send sms, in logic, I use another mobile for the word is sent to my mobile phone unit, so in this case we use in our program that the driver for read sms, what is right? ...... |
ezflyr
Posted: Tue Mar 13, 2012 12:43 pm |
Hi kamillas,
You are asking such basic 'C' questions, that it's hard not to conclude that this project is well beyond your (demonstrated) abilities with PIC processors and the CCS 'C' compiler. Seriously, at least half of your questions are readily answerable using Google or the forum search. If you consistently show an unwillingness to do any work, no one is going to bother to help you! There is at least one complete program in the forum archives that shows you how to switch LEDs On/Off under SMS control, authored by user 'Gabriel'. Did you find it?
Fundamentally, this is not a difficult task, but you've got to have a good handle on serial communications first, then string parsing, and then string manipulation. So far, you seem to be seriously lacking in the skills for all three tasks.
I don't offer these observations in a mean-spirited way, but rather as a friendly suggestion that you fundamentally change the way you go about your problem solving.
Good Luck!
John |
Gabriel
Famous! |
Posted: Tue Mar 13, 2012 2:35 pm |
Hey! Thats Me! .....
(insert Rasins Face meme image)
OMG: I am Famous!
;) _________________ CCS PCM 5.078 & CCS PCH 5.093 |
hadipic
Re: Famous! |
Posted: Tue Feb 17, 2015 4:35 am |
[/code]
/***********************send PDU sms*********************/
void GSM_Sent_PDU_Message(char *num,char *txt1,int1 center)
unsigned char i;
int16 tr_in;
int8 strlen_txt,strlen_msg;
const char se_iranceel[24]="079189390500410031000B81"; //989350001400
const char se_hamrahaval[22]="0691891901500031000B81";
//char str2[]={"AT+CMGF=0\r\n"}; //
//char str4[]={}; //
disable_interrupts(INT_timer3);
fprintf(gsm,"AT+CMGF=0\r\n"); //set PDU =0 txt =1 mode,send a Chinese sms
fprintf(gsm,"AT+CSCS=\"HEX\"\r\n");
//fprintf(gsm,"AT+CSMP=167,0,2,8\r\n");
fprintf(gsm,"AT+CSMP=17,169,0,8\r\n");
// strlen_msg=strlen_txt/2)-strlen_cen;
strlen_msg=strlen(txt1);
strlen_txt=28+strlen_msg; //
//fprintf(rs232,"number=%c0%c%c%c%c%c%c%c%cF%c\r\n",num[3],
// num[5],num[4],num[7],num[6],num[9],num[8],num[11],num[10],num[12]);
fprintf(gsm,"AT+CMGS=%d\r\n",(strlen_txt/2));
counter_read=0;
tr_in=0;
while(counter_read<=1 && tr_in++ < 0xfff1) // read all data
// output_high(PIN_D1); // signal ready to receive sms
delay_us(1);
delay_ms(40); //humity , temper ,batry
// sprintf(string," ÓÇá %d ãÇå %d ÑæÒ %d ",yar ,mon ,day);
// sprintf(string," ÓÇÚÊ %d ÏÞíÞå %d",hor,min );
// fprintf(gsm,"%S%c" txt1,26); // 0x1a => ctrl-z
if (center==0)
//strlen_txt=strlen_txt+8;
for (i=0; i<24;i++) fprintf(gsm, "%c",se_iranceel[i]);
//strlen_txt=strlen_txt+7;
for (i=0; i<22;i++) fprintf(gsm, "%c",se_hamrahaval[i]);
// 9053793576F5
// 09359753675
// 9053793576F5
fprintf(gsm,"%c%C%c%c%c%c%c%c%c%cF%c00081D",num[1], // 1d> 3 hours 47 >6 hours A7 one day
num[0],num[3],num[2],num[5],num[4],num[7],num[6],num[9],num[8],num[10]);
fprintf(gsm, "%X",(strlen_msg/2));
for (i=0; i<strlen_msg;i++) fprintf(gsm, "%c",txt1[i]);
fprintf(gsm, "%C",26);
counter_read=0;
while(counter_read<=16 && tr_in++ < 0xfff1) {delay_ms(1);} // read ok send sms
if(GET_OK(0X0E)) {
// printf (" sucsses");
// printf ("not sucsses")
//fprintf(gsm,"AT+CSCS=\"GSM\"\r\n");
//delay_ms(200);
enable_interrupts(INT_timer3);
int1 make_call(char*num,int8 num_ring)
//fprintf(gsm,"AT+CHFA: 1");//AT+CHFA: 0 hanset 1 aux
//fprintf(gsm,"ATL5"); // seting sound volum
//fprintf(gsm,"ATH"); // hang out
//fprintf(gsm,"ATA"); // answer
//fprintf(gsm,"ATDL"); // redial
int32 tr_in;
int8 i,temp;
fprintf(gsm,"ATD%c%c%c%c%c%c%c%c%c%c%c;\r\n",num[0],num[1],num[2],num[3],num[4],
num[5],num[6],num[7],num[8],num[9],num[10]);
//@pwav/music.wav \n
// @aATD09359753675;\r\n
//fprintf(gsm,"ATD05133490059;\r\n");
tr_in=0;
While(counter_read<=20 && ( tr_in++ < 0x1fffff*num_ring)) // read all data
delay_us(2);
for(i=0;i<num_buf_sms;i++)
fputc(Recieve_String[i],rs232);
// fprintf(rs232," %c=%U "Recieve_String[i],i);
// delay_ms(60);
if(Recieve_String[i]=='C' && Recieve_String[i+1]=='O') {temp=i;break;}
if (Recieve_String[1+temp]=='O'&&Recieve_String[2+temp]=='L' // +COLP: hang on number
&&Recieve_String[3+temp]=='P')
Return(1);
if(GET_OK(0X0E))
Return(1);
else return(0);
}[code]
Posted: Tue Feb 17, 2015 1:33 pm |
@hadipic: This post makes no sense. Why did you post it?
- You are posting in a thread that was silent for 3 years.
- There is no question or remark for why you posted the code.
- The code is incomplete.
- The code is difficult to read because you didn't use the 'code' buttons. |
