raflab
problem with int_rda and int_ext |
Posted: Thu Aug 18, 2011 4:10 am |
When I receive the data from the serial port using int_rda !! I can't use the data named x in the main program to complete the desired scenario !! the external doesn't work anymore !!! I don't know why ?! I try to set to 1 PIN_A2 when RB0=0 !! when I change the state of RB0 I execute the principal operation .. Please help me Thanks
#include <16F628A.h>
#FUSES LP //Low power osc < 200 khz
#FUSES NOMCLR //Master Clear pin used for I/O
#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,bits=8)
#include <stdlib.h>
#include <string.h>
#use delay (clock=4000000)
#use rs232 (baud=9600, xmit=pin_b2, rcv=pin_b1, parity=N, stop=1)
#define so 10 // définir les adresse mémoir EEPROM qu'on va les utiliser
#define mo 15
#define sf 20
#define mf 25
unsigned char send[5],c[5],select[5],chaine1[20],chaine2[20],str1[20],str2[20]; // déclaration d'une chaine de caractères d'une taille maximale 20
unsigned int16 j,w,s=0,x1=0,y1=0,x2=0,y2=0,a1=0,b1=0,a2=0,b2=0,tmp_on=0,tmp_off=0; // déclaration d'un entier non signé de longueur 16 bits
unsigned int z=0,x=0,count=0;
int calcul(int16 m,int16 n)
int16 Res;
Res=2*((m*60)+(n/1000));
return Res;
#int_timer1
void timer1(){
//disable_interrupts(int_timer1);
count++;
#int_ext
void ext_isr()
// DISABLE_INTERRUPTS(INT_ext);
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);
output_high(pin_a2);
output_low(pin_a1);
#int_rda
void reception(){
z=0;
//disable_interrupts(int_rda);
//if(kbhit()){
count=0;
gets(select);
x=atoi(select);
EXT_INT_EDGE(H_TO_L);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_256);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
setup_vref(FALSE);
set_timer1(0);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
set_timer0(60);
// TODO: USER CODE!!
a1=read_eeprom(so);
b1=read_eeprom(mo);
a2=read_eeprom(sf);
b2=read_eeprom(mf);
a1=a1*1000;
a2=a2*1000;
tmp_off=calcul(b1,a1);
//tmp_on=calcul(b2,a2);
enable_interrupts(INT_EXT);
//enable_interrupts(int_timer0);
enable_interrupts(int_timer1);
enable_interrupts(GLOBAL);// autorisé tout les intérruptions
enable_interrupts(INT_RDA);
switch(x){
case 1:{
printf("%lu\r",a1); // time of LED lighting in seconds
printf("%lu\r",b1); // time of LED lighting in minutes
printf("%lu\r",a2); // time of LED switched off in seconds
printf("%lu\r",b2); // time of LED switched off in minutes
x=0;
case 2:{
j=2;
strcpy(c,"2");
if(input(pin_b0))
printf("%s\r","F");
while(input(pin_b0)&& j==2) // boucle pour passer au mode config si on l'est pas deja
//delay_ms(1000);
gets(c);
j=atol(c);
output_high(pin_a1);
output_low(pin_a2);
if(input(pin_b0)&& j!=8)
printf("%s\r","F");
if(j!=8){
printf("%s\r","C");
output_low(pin_a1);
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);}
while(z==0 && j!=8 ){
gets(send);
printf("%s\r",send);
s=atol(send);
if(s==4){
gets(chaine1); // acquisition des nouveaux valeurs
gets(str1);
gets(chaine2);
gets(str2);
x1=atol(chaine1); // conversion chaine -> entier long
y1=atol(str1);
x2=atol(chaine2);
y2=atol(str2);
printf("%s\r",chaine1); // renvoyer les valeurs reçu pour une confirmation de l'utilisateur
printf("%s\r",str1);
printf("%s\r",chaine2);
printf("%s\r",str2);
gets(select);
w=atol(select);
if (w==1) {
a1=x1;
a2=x2;
b1=y1;
b2=y2;
write_eeprom(so,a1);
write_eeprom(mo,b1);
write_eeprom(sf,a2);
write_eeprom(mf,b2);
a1=a1*1000;
a2=a2*1000;
z=1;
z=0;
z=1;
x=0;
case 3:{
j=3;
strcpy(c,"3");
if(input(pin_b0)==0)
printf("%s\r","C");
while(input(pin_b0)==0 && j==3) // boucle pour passer au mode config si on l'est pas deja
gets(c);
j=atol(c);
if((input(pin_b0)==0) && j!=9 )
printf("%s\r","C");
if (j!= 9)
printf("%s\r","F");
x=0;
if((input(pin_b0))){
while(count<=tmp_off){
output_high(pin_b4);
output_high(pin_b5);
output_high(pin_b6);
output_high(pin_b7);
output_low(pin_a2);
count=0;
while(count<=tmp_on){
output_low(pin_b4);
output_low(pin_b5);
output_low(pin_b6);
output_low(pin_b7);
output_low(pin_a2);
count=0;
output_low(pin_a1);
asmboy
Posted: Thu Aug 18, 2011 8:10 am |
Can you reconfigure your circuit to free up
pin B1 and B2 for the HARDWARE USART?
Using a software should always be the LAST resort IMHO
as it is susceptible to #int interference during reception
AND has the added disadvantage of using more program code space.
I think revisiting what pins do what in your circuit -
would go a long way toward making your life better -
and your code SMALLER too. |
Posted: Thu Aug 18, 2011 12:42 pm |
#include <stdlib.h>
#include <string.h>
Can you see a problem with your oscillator fuse ?
This means you are likely not running this program in real hardware.
(Unless you're changing the fuse manually in the programmer).
Quote: | #int_rda
void reception(){
z=0;
//if(kbhit()){
count=0;
gets(select);
x=atoi(select);
Don't get a string in #int_rda. It interrupts once per character. Don't sit
in the routine and wait for chars to come in. What if they don't come in ?
What happens to your program ? It locks up. Also, gets() expects a
carriage return character (0x0D) to mark the end of the string. What if
you don't receive it ? Again, your program is locked up in the #int_rda
routine forever. Also, don't use functions like atoi() inside #int_rda
because they can take a lot of time to finish.
Look at the CCS example file, Ex_sisr.c, which shows how to use #int_rda
to make a circular buffer. It shows how to get just one character inside
the #int_rda routine and put it in a buffer. Then you get chars from the
buffer outside of the #int_rda routine, in your main() program.
Also:
CCS has an example of how to use INT_RDA interrupts to get a string.
Look at the bget_string() function (buffered get_string) in this file:
Quote: |
c:\program files\picc\examples\ex_zmd.c |
