Colin_Kyungu
Temperature logger |
Posted: Wed Aug 17, 2011 4:16 am |
Hi Guys,
Can someone help me please, i am trying to include Cotesta Tolentino's Temperature Logger on one of my project, i have tried modify the code to allow only one Ds18B20 but the simulation does not work accordingly.
help please
// I use the Temperature Logger - TNT_1.0 - by Cotesta Tolentino - cotestatnt@yahoo.com
#include "Tracker.h"
#include <LCD.C>
#include "onewire.c"
#define PERIOD 10
void init(void);
int16 time = 101;
int1 RST = 0;
//global variable in the " onewire.c" file
void init()
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
#int_TIMER1
void TIMER1_isr(void)
time++;
RST = 1;
//main function
int8 i, tmp = 0;
int16 sensData, celsius, fract;
int8 scratch[9];
unsigned char sign;
init();
lcd_init();
output_float(DQ); // Set as input. 4k7 pullup on bus.
//printf(lcd_putc,("I'm alive!\n"));
if (RST){output_toggle(LED); RST = 0;}
if ((!ow_reset())&&(time > PERIOD)) // If a device is present and it's time to send string
//printf(lcd_putc,("device present and \nready to send \nstrings\n"));
time = 0;
write_byte(0xCC); // Skip Rom command
write_byte(0x44); // Temperature convert command
output_float(DQ);
delay_ms(750); // Max. conv. time is 750mS for 12 bit
ow_reset();
if (!ow_reset())
//lcd_putc("temp conversion started\n");
write_byte(0xBE); // Read scratch pad command
for(i=0; i<2; i++)
scratch[i]= read_byte();
// raw sensor data (16bit)
sensData = make16(scratch[1], scratch[0]);
// check negative
if (bit_test(sensData, 15))
sign = '-';
sensData = ~sensData + 1;
} else
sign = '+';
fract = 0;
tmp = sensData&0xF; // obtain the fractional part nibble
celsius = sensData >> 4 ; // calculate the whole number part
if (tmp == 0xFF)
celsius = celsius + 1; // Calculate the fractional part
for (i=0; i<tmp; i++)
fract = fract + 0625;
lcd_putc("\f");
printf(lcd_putc,"Temp:%c%03lu.%04lu;", sign, celsius, fract);
printf ("\n"); // new line when end of all devices on the bus temperature readings is done
} // if ((!ow_reset())&&(time > PERIOD))
} // while (TRUE)
} // main
Onewire code
// Global variables
int8 dowcrc; // crc is accumulated in this variable
//calc_CRC - INTERNAL FUNCTION
//Purpose: To calculate an 8-bit CRC based on a polynomial and the series
// of data bytes
//Note: Polynomial used x^8 + x^5 + x^4 + 1 = 10001100
//Inputs: A pointer to an array of the data bytes and an int saying how many
// bytes there are in the data array
//Outputs: An int8 which is the calculated CRC
int8 calc_CRC(int8* data, int8 bytes)
#define CRC_POLY 0x8C
int8 shift_register = 0, i, datab, bits;
for(i = 0; i < bytes; ++i)
datab = *(data + i);
for(bits = 0; bits < 8; ++bits)
if(bit_test((shift_register ^ datab), 0))
shift_register = shift_register >> 1;
shift_register ^= CRC_POLY;
datab = datab >> 1;
return shift_register;
} //calc_CRC
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void)
int8 presence;
output_low(DQ);
delay_us(488); // Min. 480uS
output_float(DQ);
delay_us(72); // Takes 15 to 60uS for devices to respond
presence = input(DQ);
delay_us(424); // Wait for end of timeslot
return(presence);
// Read bit on one wire bus
int8 read_bit(void)
output_low(DQ);
delay_us(1); // Added, 1uS min. Code relied on 8051 being slow.
output_float(DQ);
delay_us(12); // Read within 15uS from start of time slot
return(input(DQ));
void write_bit(int8 bitval)
output_low(DQ);
if(bitval == 1) {
delay_us(1); // 1uS min. Code relied on 8051 being slow.
output_float(DQ);
delay_us(105); // Wait for end of timeslot
output_float(DQ);
int8 read_byte(void)
int8 i;
int8 val = 0;
for(i=0;i<8;i++)
if(read_bit()) val |= (0x01 << i);
delay_us(120); // To finish time slot
return val;
void write_byte(int8 val)
int8 i;
int8 temp;
for (i=0;i<8;i++)
temp = val >> i;
temp &= 0x01;
write_bit(temp);
delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
dowcrc = calc_CRC(x,8);
return dowcrc;
// Sends Match ROM command to bus then device address
int8 Send_SkipRom (void)//This code was changed from MATCH ROM to skip ROM
if (ow_reset()) return FALSE; // 0 if device present
write_byte(0xCC); // Match ROM
return TRUE;
#include <16F628A.h>
#device *=16
#device adc=8
#FUSES PUT //Power Up Timer
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(clock=4000000,RESTART_WDT)
#define DQ PIN_B3 // One Wire Bus pin assignment
#define LED PIN_A1 // Status LED
// Software usart will be used with "invert" option.
// so direct connect without interfaces to PC is available
#use rs232(baud=9600,parity=N,xmit=PIN_A4,rcv=PIN_A5,bits=8, invert) |
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,2007 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
#define use_portB_lcd TRUE
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined use_portB_lcd
#locate lcd = getenv("sfr:PORTB") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf81
#else
#locate lcd = 6
#define set_tris_lcd(x) set_tris_B(x)
#else
//#locate lcd = getenv("sfr:PORTD") // This puts the entire structure over the port
#ifdef __pch__
#locate lcd = 0xf83
#else
#locate lcd = 8
#define set_tris_lcd(x) set_tris_d(x)
#ifndef lcd_type
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
BYTE low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
//delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
//delay_us(2);
lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
BYTE i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
//delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
// delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
BYTE address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
//delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( BYTE x, BYTE y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
Joined: 01 Jul 2010 Posts: 9204 Location: Greensville,Ontario
Posted: Wed Aug 17, 2011 4:27 pm |
Have you got his code to work 'asis '? before you modified it ??
If you're using Proteus as the simulator, I can't help you, as I ONLY deal with real chips in the real world. Proteus is FULL of bugs, errors, flawed DRCs, etc.
I can tell you that there is working code, in the code library. I've modified it for 2 sensors and it seems reliable. |
Colin_Kyungu
Posted: Thu Aug 18, 2011 2:35 am |
Temtronic-I have only tried simulate it using Proteus and the value display on the LCD are wrong- i have got your point, let me tried it on the chips and see. |
asmboy
Posted: Thu Aug 18, 2011 2:57 pm |
I think you will find a warm reception for all who actually work with hardware - andthen come to a problem spot.
But with the Proteus? In terms of a real working system?
To steal from Willam Gibson - "There is no 'there' , there" ;-)) |
