Strange PIC Behaviour
Goto page 1, 2  Next
Sid2286
PostPosted: Tue Aug 16, 2011 6:24 am     Reply with quote
I'm trying to run a simple program code on a bread board, it is behaving quite strange,
we i plug in the power supply it works ok!(blinking an LED) but when I reset it using a reset button, there is no response.
i'm using complier version 4.119, My program code is as follows:
#include <18F2520.h>
#device ADC=10
#fuses HS,NOLVP,WDT256,INTRC_IO
#use delay (clock=8000000)
#include <flex_lcd.c>
#include <stdlib.h>
      float volts;
      float f;
      int16 z; //should be signed int
      set_tris_c(0xFF);
      set_tris_b(0x07);
      PORT_B_PULLUPS(true);
      lcd_init();
      setup_adc_ports(AN0);
      set_adc_channel( 0 );
      delay_us(30);
       restart_wdt();
       output_high(Pin_C4);
       output_low(Pin_B7);
         z=read_adc();
         printf(lcd_putc,"\f%ld",z);
       output_low(Pin_C4);
       output_high(Pin_B7);
Is there something that I'm missing?
I updated the complier just couple of days back, prior to this I was using 4.093 which was working fine!
Please let me know if I ve to set some fuses or not!
Sid
asmboy
PostPosted: Tue Aug 16, 2011 7:47 am     Reply with quote
how does the 'reset button' connect to the PIC and what is the CIRCUITRY associated with that button?
PostPosted: Tue Aug 16, 2011 7:56 am     Reply with quote
Also (though probably not the cause of this), _just one oscillator fuse_. You can't have 'HS', and 'INTRC_IO'.
There seems to be a 'habit' appearing of people not looking at what the fuses do, and squirting extra ones at the code, with very unpredictable results....
Sid2286
PostPosted: Tue Aug 16, 2011 8:29 am     Reply with quote
The circuit for reset button is 10k pull up resistor along with 1k resistor in series to the button, while the other end is grounded! The circuit seems to be fine.
I guess i should check what Ttelmah suggest!
Sid2286
Not Solved
PostPosted: Tue Aug 16, 2011 11:01 am     Reply with quote
Tried without HS but thats not helping either...don't know what to do!
Please help!
W4GNS
PostPosted: Tue Aug 16, 2011 12:32 pm     Reply with quote
I would try removing components from the board, and then shifting a place or two on then re breadboarding, Breadboards are far from perfect, though I use them myself
PCWH 4.14
PostPosted: Tue Aug 16, 2011 12:56 pm     Reply with quote
Get rid of 90% of your code.
1. Don't set the TRIS. Let the compiler do it.
2. Don't enable Watchdog timer in a test program. Also don't set it
for a 1.024 second timeout when you have delays of 1 second in the
program. You're asking for WDT reset when you do that. You can
fix it by adding restart_wdt to the #use delay() statement, but you
don't need WDT in your program.
3. Put in all the proper fuses that help to prevent start-up problems,
such as PUT and BROWNOUT.
4. Don't use the PGC and PGD pins (B6 and B7) for external circuits
such as LEDs because these pins are used by your ICD debugger or
programmer.
5. Your comment says 'z' should be signed, but 'int16' is unsigned.
Also, the ADC returns an unsigned result, so there is no need for 'z'
to be a signed integer.
6. Don't put in large #include files like stdlib.h when you don't need it.
It just makes it take longer to compile the program.
Try a very simple program:
#include <18F2520.H>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
   output_high(PIN_C4);   // Blink LED
   output_low(PIN_C4);
Sid2286
PostPosted: Tue Aug 16, 2011 7:02 pm     Reply with quote
Thanks PCM!
I tried what you suggested! but it is still not working :( I even compiled the program that you recommended but that is also not working.
when I assemble on Breadboard it working fine with the supply, but as soon as i press reset button it hangs.
what are the chances of MCLR pin getting damaged.
I don't understand this problem.
PostPosted: Tue Aug 16, 2011 8:03 pm     Reply with quote
Does your MCLR circuit look like this ? Or is it different ?
                 +5v
                  > 10K
                  <         ___  Switch
To        1K      |        _|_|_
MCLR ---/\/\/\/------------o   o-----
pin                                 |
                                   --- GND
Have you looked at the MCLR pin with an oscilloscope to see that it's
normally at +5v, and when you push the button it goes down to a
solid 0 volts ? Then when you release it, it goes back to +5v ?
You said this is on a breadboard. Do you have a clean, stable +5v
for the Vdd on the PIC ? Do you have a 100 nF (0.1 uF) ceramic
capacitor between the Vdd pin on the PIC and ground ? It should be
placed very close to the PIC's Vdd pin.
Sid2286
No solutions yet
PostPosted: Tue Aug 16, 2011 11:46 pm     Reply with quote
PCM the circuit is just the same as you have shown..but I have some finding here....
When I program using an ICD or a Pickit 3 it works..but as soon as I disconnect the ICD or pickit3 it stops working....
How should I proceed?
Sid
PostPosted: Wed Aug 17, 2011 2:28 am     Reply with quote
Normal reason for that is ground, or power. Look three times more at your connections. Does the ground of the processor actually go to the ground of the board?. You _have_ a wiring problem somewhere.....
TMLtech
Re: No solutions yet
PostPosted: Wed Aug 17, 2011 2:31 am     Reply with quote
Sid
What kind of voltage you have MCLR- pin when the power is on? If you have oscilloscope measure that pin, maybe there is some glitch..
Sid2286
PostPosted: Wed Aug 17, 2011 2:33 am     Reply with quote
Everythings looks perfectly fine...capacitor at its place...everythings good!but as soon as i disconnect the board from the ICD or Pickit3 it stops working!
strange..
Sid2286
Still no Success!
PostPosted: Wed Aug 17, 2011 4:54 am     Reply with quote
I changed the IC and tried with another pic18f2520 and there I saw something as follows:
when I write a simple blink code such as
#use delay(clock=8M)
#include <stdlib.h>
      output_low(PIN_C0);
      output_high(PIN_C0);
it seems to work ok without ICD or Pickit3 but as soon as I write something for LCD as as:
#include <stdlib.h>
        lcd_init();
           printf(lcd_putc,"\f Hello\n world");
      output_low(PIN_C0);
everything crashes..there is no display on LCD and no blinking of LED. Please suggested something...I'm struggling for complete 1 week now :(
PostPosted: Wed Aug 17, 2011 7:08 am     Reply with quote
The suggestion has already been made - connection, connection, connection.....
Think for a moment what the ICD connection actually 'makes':
1) A ground connection.
2) A Vdd connection - also adds capacitance between grond and this pin.
3) An MCLR connection.
4) Pull _down_ connections to PGC, and PGD - these are required if the code is compiled for debug use, otherwise the chip won't run.
That your board doesn't work without the ICD, says that one of these connections is faulty in some way. Nothing else.
'Looking' good, is not a test. Get a meter, or oscilloscope, and actually _test_ the connections.
Goto page 1, 2  Next
Page 1 of 2
